Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
I have a poulan 2375 le, how much gas and oil do i need to mix?
  • 3 Answers
The correct gas/oil mixture is 40:1.. NOT 50:1.
Posted on Nov 13, 2010
    Brigadier General:
  • 4,088 Answers
50:1 is the fuel to oil ratio. Be sure to use fresh gas, a modern synthetic chainsaw oil, and mix in it's own container. Be sure to shake the container thoroughly just before adding to the tank to prevent oil starvation. Don't make up more than a gallon at a time unless sawing is your business. Hope this helps!
Posted on Oct 24, 2010
SOURCE:
Describe your Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Problem Need gas to oil ratio for poulan prolink pp335 weed eater
I found the manual for this model weed eater, according to the manual the mixture...
and I quote "This engine is certified to operate on unleaded gasoline. Before operation, gasoline
must be mixed with a good quality synthetic 2-cycle air cooled engine oil designed to be
mixed at a Ratio of 40:1 ...."
and I quote once more from the manual "Helpful Tip. To obtain
correct oil mix ration, pour 3.2 ounces of 2 cycle synthetic oil into one gallon of fresh gas."
Hope that helps,
If you like I can send the manual via email if you need it.
:) happy weed thrashing
Aug 12, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
Lost my manual for my Poulan wild thing 2375 chainsaw and I want to fill it up with oil and fuel.
Fill the oil tank at the front of the saw with a non fling chain oil, or as thick an oil as you can get, fill the fuel tank with a 25-1 fuel oil mix, use a good, well known brand of two stroke oil designed to be used in chainsaws.
Jul 15, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Do you add the oil first or the gas first?
If you're talking about mixing two-cycle oil with gas for a two stroke motor, always mix it in a gas can then pour it in the weed eater. It's easier to put the oil in the gas can first then fill it with gas to get the two mixed well.
Jun 16, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the gas/oil mixture for the poulan wild thing chain saw please?
Use a quality 2-cycle air-cooled engine oil. Poulan recommends a good quality 2-cycle air-cooled oil designed to be mixed at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 onces of oil with 1 gallon of unleaded gasoline). When mixing fuel, follow the instructions printed on the container. Always read and follow the safety rules relating to fuel before fueling your unit.. Be Safe!
Sep 25, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the oil to gas mix? Paulan xt-200
Poulan motors usually use a 40:1 mix ratio.
That is 3.2 oz of 2-cycle oil to 1 Gallon (128 oz) of gas.
Be sure to not use gas with more than 10% Ethanol.
Jun 06, 2010 | Poulan/Weed Eater No. Te475 952711797 17"...
What is the correct gas/oil mix for the Poulan Pro 295 chainsaw?
50:1 according to this:
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/c2b3efd6af050e6b88256f77001bfbdd?OpenDocument
I suspect the manual says 40:1, but if properly adjusted it will operate better on 50:1.
I gallon of premium fuel to 2.6 ounces of quality 2-cycle oil = 50:1.
I gallon of premium fuel to 3.2 ounces of quality 2-cycle oil = 40:1.
HTH David;
Lou
Feb 10, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
What is the gas/oil mixture for poulan wild thing chain saw? Thank You Roger
I have a manual for that saw that says the mix is 40:1- 3.2 oz. of oil to 1 gal of gas .
Dec 09, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a new wild thing poulan chainsaw that idles ok but bogs down when giving it gas ..it has good fuel
make sure your using high octane (no ethunal) and fresh oil mix no older than 6 mouth (oil mix) if it st-ell happens try to adjust the high side with it at full throttle un tell it smooths out. good luck
Oct 13, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
275 people viewed this question
Top Poulan Garden Experts
roeb
dannydoesita
Marvin
Marvin
Are you a Poulan Garden Expert? Answer questions, earn points and help others
