Question about Zenith Computers & Internet
I have a Zenith model CD15MNTCI from 1991. It comes on and the colors are fine, but there is a slight wave/distortion that make the picture look funny. Sometimes it is worse than others. Any idea what causes this and how i can fix it?
  • fad126 Oct 26, 2010
    This is not a monitor for a computer. It is from 1991. It was used for a video game store display unit. However, it is not a TV. See initial post for model number.
    Is there any way to tell which one is failing? Which section of the circuit board would I look at? Is the a fairly common problem and an easy fix?
  • 2,567 Answers
Sounds to me like a failing capacitor in the power section of the circuit board.
Posted on Oct 26, 2010
  • Mohamed Omran Oct 26, 2010
    You should check the section of the circuit board which is directly fed from the AC power source. You should be able to see several electrolytic capacitors. These should be tested & any one of them that is found to be faulty should be replaced. You will have to possess at least basic soldering skills in order to be able to complete this job.
    President:
  • 1,851 Answers
This problem comes up when you are using the monitor at a slightly higher resolution or refresh rate setting that the monitor can handle. Try to lower down both of the settings (start - settings - control panel - screen - settings) and check the results. In case the picture looks better, increase STEP BY STEP resolution and refresh rate (one at a time) in order to get the best result. Keep in mind that if a setting is out of range that the monitor can handle the screen will be black. AT THIS CASE DON"T DO ANYTHING, after 15 seconds the screen will come back at the previous setting. Sorry your monitor it too old and I can't find the official settings for resolution and refresh rate. However the official settings are not guarantee that are still working since the monitor has too many hours "on duty".
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Oct 24, 2010
SOURCE:
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Lcd looks a red wave line it look like it's out
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 29, 2010 | Hitachi 51GWX20B 51" Rear Projection...
Wavy horizonal disturbance in picture
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 07, 2010 | Televison & Video
Wave & three colors
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Apr 07, 2010 | Panasonic PT-51HX41 51" Rear Projection...
My tv is blurry, showing green and red waves...zenith d61w25
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic2_bing.gif,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Sep 01, 2009 | Zenith D61W25 61" Rear Projection...
Zenith R57W46 bottom bowing and color off and double lettering
Projection TV sets have two very common problems listed below.
*Screen Looks 3-D
*Colors wont align
Mar 28, 2009 | Zenith R57W46 57" Rear Projection...
Picture Problem
In that set its usually a bad picture tube. The lines you are seeing are called retrace lines. You can take it to a shop and they may be able to rejuvenate the tube
Mar 13, 2009 | Televison & Video
Follow up to JUL 9th distorted picture question
That would be the convcergence ICs and feed resistors that need replacement. Can you reply to this same post and verify that your model is the R56W36? I will then post the correct ICs and feed resistors for your model as well as a link where you can get replacement ICs and resistors with free instalation instructions with pictures.
Jul 14, 2008 | Zenith R56W36 56" Rear Projection...
Green wave-like color distortion over reds
do you happen to have any speakers of any size within about 3 feet in any direction of the tv?? move them if so, I have large speakers about 5 feet from my tv at home and i still get some distortion once in a while with red and dark green streaks.
Aug 15, 2007 | Sony WEGA KD-34XBR970 34" TV
Screen full of moving colored lines
I would suspect bad solder connections allowing a ground to "float" It is a common problem with the model P42W24BX which I believe uses similar circuitry as your model. An experienced repair shop should be able to get you fixed up.
Dec 18, 2006 | Zenith P42W46X 42 in. Plasma EDTV
Computers & Internet Logo
102 people viewed this question
Top Zenith Computers & Internet Experts
ATS dude
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Zenith Computer and Internet Expert? Answer questions, earn points and help others
