Question about RTO PasLode 900420 Impulse Framing Nailer
Hi .my im350 nail gun isnt working gas and battery ok and gun is cleaned.light on green .but when depresssed makes strange noise and lights on fire from fan end?
  • RTO Master
  • 43,501 Answers
Here is a tip that I wrote about the Paslode nailers and the problems that can come up with them.
I also have a link to the Paslode manuals which contain Paslode cleaning and troubleshooting guides.
If you need parts for your Paslode, there also is a link for a site that sells the Paslode nailer parts.
Paslode Cordless Nailer Problems
heatman101
Posted on Mar 06, 2011
  • Craig Allan
    Craig Allan Mar 17, 2015
    Any idea why nail gun starts making loud noise after a few shots
SOURCE:
I have a new im65a pasloade nail gun that has only fired a couple of hundred nails and after standing for about 16 months the gun does not seem to be firing the fan comes on the green light flash the
your gas has expired , look at bottom of canister check the date. buy new gas also make sure cap on gas canister is down all the way till it snapps new gas doesnt come with cap down all the way
Apr 24, 2012 | Senco Air Tools & Compressors
Paslode im350/90ct green light goes red when applied to surface and wont fire
Unplug. Check that you don't have a nail jammed in the end of it.
Apr 03, 2012 | RTO Air Tools & Compressors
When i put thew gun to wood there isnt a noise and wont fire a nail.when i lift off the fan comes on. what could the problem be.the gun is clean and all orings are in good condition.tried the piston on...
ok, start with checking gas delivery ,then with total clean. If still malfunction, check the setting of lower probe(part 66). I've owned my guns for 11 years and do all my own servicing. Most if not nearly all problems are caused by dirty components...cheers
Jul 06, 2011 | RTO PasLode 900420 Impulse Framing Nailer
Paslode IM350 90CT Nail Gun gun light green gas full battery charged fan works gun wont fire
Try a different gas cartridge and make sure the top of the cartridge is snapped tightly onto the cartridge body.
Jun 23, 2011 | Air Tools & Compressors
I have a paslode airless framer that wont fire. New batterry & fuel cell. It make the noise but wont fire
Hello harderconstr, I have that nail gun myself, and when it's working good it is a great tool to have.
Here are a few suggestions.
1. Remove the battery, make sure that you don't have a nail jammed in the the firing chamber, that has happened to mine before.
2. Adjust the depth tension on the end of the gun. You should have an alen wrench to loosen the adjuster at the tip. Slide the adjuster away from the gun, ( out ) as far as it will go and then tighten it back down. Reinstall the battery and try it again. You can re-adjust the tension after you see if this helps the problem. The adjuster on my gun was worn and I needed to adjust the tension to get it firing again.
3. I also got a new battery for my gun, and what I found was I really had to slide the battery in pretty hard to get it to click in place. Also, when you hold the gun in your right hand, the thumb side of the handle should have a very small LED light, red means it's not ready to fire, green means it is ready to fire. Make sure you have a green light.
I hope this helps you my friend!
Jan 09, 2011 | RTO Paslode #650027 2500CT Placement Nail
Paslode 350 wont fire
Probably needs cleaning. You`ll need two new o`rings.
Aug 19, 2009 | RTO PasLode 900420 Impulse Framing Nailer
CLEANED NAIL GUN EVERY THING SOUNDS OK BUT NOT FIRING CHANGED GAS
Pull the top off and clean the spark plug with a carb cleaner spray.
Check gas canister ...make sure it's not empty..
Do you get a green blinking light on the unit?
K
Apr 10, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Paslode im350
Stuart - this sounds like an air problem - you should perform the following test. With the air nailer close to the compressor you must monitor the airpressure after the gun fires. it sounds like the air is not gettting through diapram fast enough or there is a blockage in line. Blockage in line is not suspected for the following reason . It sounds like the air hose is holding enough air to fire 2-4 nails and then you must wait for the line to fill up again and then it fires ok. The pressure regulator out to the line controls this and they do fail. try this test and report back to me - I know I can solve this for you as I have extensive background in compressor and the like.
Oct 22, 2008 | Itw Devilbiss Itw Paslode Cnp 65Y Coil...
Hitachi Framing Gun Not Firing - Bad Battery?
Does the fan run and the light blink ont he nailer? I have one that I just bought. I put in the wrong type of nails and got one stuck. I had to take the front apart to clear it and now the damm thing wont fire. The green light blinks and the gas cartridge is basically full, even the fan does run after I release the push lever, but no fire???
I wonder if yours is the same as mine did fire for a couple nails first just fine then got jammed...
I will try to charge the battery more.... MAybe like yours it needs a strong charge for the spark...
Russ
Sep 28, 2008 | Hitachi NR90GR Cordless Round Head Gas...
RTO PasLode 900420 Impulse Framing Nailer  Logo
1,458 people viewed this question
Top RTO Air Tools & Compressors Experts
John Trevino
J. Bradshaw
Are you a RTO Air Tool and Compressor Expert? Answer questions, earn points and help others
