Question about Hoover Washing Machines
The bearing has gone on my hoover vhd 8142, how can i get at it to replace it.
2 Suggested Answers
SOURCE:
kapishtech
  • 2272 Answers
SOURCE: hoover vision HD 1400 AAA,
Check if the inner drum is spinning without noise when you turn it on manually.If the same noise is heard then it can be drum center bearing,that is out of alignment/.The other possibility can be the timer ,it must be getting short causing the noise. Check out.keep updated. Thanks.
Posted on Sep 18, 2010
I have a Hoover VHD Sensor Dry 1400 AAA that trips the house fuse each time I turn it on. What should I do?
disconnect from the power outlet and call an technician to find the short or earth leakage problem
Feb 20, 2018 | Hoover Washing Machines
Hoover VHD sensor Dry shows Eo8 vibrate badly and stops any suggestions please regards Peter
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/specific-faults/3070-hoover-vision-hd-washing-machine-fault-codes.pdf
Mar 09, 2015 | Hoover Washing Machines
Hoover vision hd
the bearing are gone
Jan 18, 2014 | Washing Machines
My Hoover vhd 8142 washer wont turn. Some clothes got stuck in the doorway and when it spun it twisted everything up and pulled the seal off the door. We managed to get the seal back on. We put a load in...
Sounds Like the friction on the belt.If the drum got stuck the motor & belt keep turning plus the drum may of been pulled to an off set angle distorting the alinement's of the belt to the wheel that turns the drum.
Oct 01, 2017 | Hoover Washing Machines
I have HOOVER vhd 8143db80 when it went into its final spin, it started screaming. So I've taken the back off,I've noticed a lot of black carbon/metal dust on the pulley wheel. I've turned the...
That could be two things. Belts scream when they slip and are worn out. An bearings scream when they are dry or worn.
Your machine seems a bit obscure, as Google doesn't seem to know that model?
HOOVER vhd 8143db80 Google Search
VHD812
https://service.hoover.co.uk/manuals/VHD812.pdf
Feb 19, 2018 | Hoover Washing Machines
My Hoover VHD 1400 aaa has the front concrete weight off
This weight helps to balance the machine. needs to be put back on or replaced. Machine will not operate properly without it.
Mar 28, 2011 | Hoover Washing Machines
Hoover visionHD vhd 842-80 will not complete its cycle (does not spin) lights flashing are 1200 &time saver button
Mine done the exact same thing and it was the bushes that went not the pump, so you can change them your self if you can
Nov 07, 2010 | Hoover Washing Machines
Washing Machines Logo
194 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Poppa Maddo
Poppa Maddo
jimorris77
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
