Question about GE Profile Spectra JGBP90 Gas Kitchen Range
I have a XL44 JGBP90MEB6BC range. I am constantly getting F7 E6 error. After reading several posts, they all tell me its control panel or a key pad problem. My questions is how do I remove the control panel?
6ya staff
SOURCE:
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: control panel shows F7 and contantly alarming or beebing
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Oct 20, 2007
fridgetech
Craig Shelton
  • 473 Answers
SOURCE: panel is showing f7 and flashing e6 57 56 58 5a
F7 is a stuck key. Usually you can't get a key unstuck. Best thing to do is replace the keypad / user interface. Here are some of GE's error codes:
GE
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring
Posted on Dec 02, 2008
fixyourboard
Fix Your Board
  • 310 Answers
SOURCE: I have an electric range, model # J SP42SOK4SS.
This means the controller is sensing a stuck key, which may be due to an actual stuck key or a problem with the controller. There is a way to diagnose which is the cause if you are comfortable tearing into the unit, or a repair tech can quickly diagnose for you. If you need a controller, you might consider having us rebuild it for you.
Regards,
Bruce
www.fixyourboard.com
Posted on Oct 10, 2009
jonniewalker
Starnley Johnwells
  • 1031 Answers
SOURCE: GE range displaying codes F7 E6
F7 E6 shows that Function pad button stuck or Bad clock try to Unstick Button or Replace Clock also if persist then check the connections to the contol panel
Posted on Oct 18, 2009
Anonymous
  • 82 Answers
SOURCE: i have a ge xl44 gas range. the oven knob has come off
You will need to locate your full model #, usually open the bottom drawer and you can see it on the chassis on the right or left side. Try searspartsdirect.com type your model in and it will give you a parts breakdown and about the best assembly view your going to get. Sometimes there is more to be desired but this should help. Please rate this post.
Posted on Dec 14, 2009
F7 dC
Well first of all you determine if problem is with the Key Panel or Control by:
This error code F7 means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC)......
Post comments for more help or information........
Good Luck!!
Mar 26, 2010 | GE Ovens
I need Please a solution to F1 Error Code on GE/Kenmore electric ovens Model # 911.4658815 Thanks E-mail: [email protected] I have the same model number. 9114658811 and plugged in the stove for the...
To my understanding error code F1 would indicate a faulty control board, possibly thermistor control. The only recourse is to have this replaced.
This of course would require a fair familiarity of electrical/electronic components/circuitry and safety procedures, use of a DVM and possibly a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Kenmore 46123 Stainless Steel Electric...
The cotrol panel blinks F7 E6 AND DOES NOT TURN ON AT ALL THE OVEN ALSO ONE BURNER IS OUT
f-7 mean stuck button on key pad or stuck relay on oven control. if the problem started while oven was in use replace oven control board. if problem started while oven was not in use replace key pad . because control board shorts when oven is running then this error comes up. but if the error is both f7 e6 then, F7 E6 shows that Function pad button stuck or Bad clock try to Un-stick Button or replace Clock also if persist then check the connections to the control panel
-------- for any other codes :--- Code Condition Check/Repair F0 and F1 Failed Thermistor Control Replace Electronic Range Control (ERC) F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F3 Open oven temperature sensor circuit Replace oven temperature sensor F4 Shorted wire (Oven temperature sensor) Locate and correct F7 A = Function pad button stuck or
B = Bad clock Un-stick button or
Replace Electronic Range Control (ERC) F8 Component Failure Replace Electronic Range Control (ERC) F9 Program w/ door circuit Check wiring . ------ for getting required parts you can get it from ---- www.repairclinic.com or from www.partselect.com --------- if not familiar with replacing part a local repair technician familiar with your brand /model is advisable as its normal problem and gets solved after replacing the required part .and yes its worth getting repaired. ----- This will help. Thanks please keep updated.please do rate the solutionif helped.thank you for using fixya.
Oct 25, 2009 | Kitchen Ranges
GE JGBP85WEB5WW - F7 / E9 Error codes
Well first of all you determine if problem is with the Key Panel or Control by-
This error code means Function pad button stuck or Bad clock: Unstick button or Replace Electronic Range Control (ERC).
Good Luck!!
Aug 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
F7 error code
Hi
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
check out more detail here
http://www.fixya.com/howto/h155060-dreaded_f7_error
hope this helps
Aug 14, 2009 | GE Profile JTP56 Electric Double Oven
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
Constant beeping and F7 is displayed
Hi tahitian,
The error code F7 means that the Function key is shorted or stuck. To fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Dec 16, 2008 | Magic Chef 31000 Gas Kitchen Range
Panel is showing f7 and flashing e6 57 56 58 5a
GE
Code
Dec 01, 2008 | GE Profile 30" Self-Cleaning Slide-In...
Control panel shows F7 and contantly alarming or beebing
Oct 20, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Dead control panel
No F7 or E7 in my tech sheet could it be a F1 F1 Failed transistor in control If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad let me know thanks
Jan 22, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
154 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Kitchen Range Expert? Answer questions, earn points and help others
