Question about Husqvarna Designer I
After lowering the feed teeth I am unable to raise them manually with the dial. They do raise with a mechanical "clank" as I begin to sew. The feed teeth are on the extreme right off the slot openings. Shouldn't they not be centered in the slots?
  • 201 Answers
If you have been embroidering, the feed teeth will raise themselves next time you do regular sewing with a clunking noise - not really loud, but you can hear it. The feed teeth on my Des.1 are on the far right-hand side too so I think that this normal. So long as they are not fouling on the coverplate slots and the material is being fed properly by the feed teeth, your machine is fine.
Posted on Oct 26, 2010
SOURCE:
Singer 4423- brand new. Followed youtube tutorial, lowered feed dogs (buttonhole setting) with no problem; now unable to raise them. Followed suggestions to another user with the same problem- no luck
go google and type in --user manual for singer sewing machine model 4423---and download the pdf version
you could always talk to the singer shop for advice or join a sewing club to get expert tips to get the best out of your machine
Mar 22, 2017 | Singer Sewing Machines
I lowered the feed dogs for the first time to free motion quilt. Now I cannot raise them. Moving the button to the rights has no effect at all.
Some machines need the dial put in a certain position, try moving it about as you try to move the feed dogs. The presser foot must always be up.
Nov 02, 2015 | Sewing Machines
Does this model have a feed dog that can be lowered for free motion quilting?
    A set of feed dogs typically resembles two or three short, thin metal bars, crosscut with diagonal teeth, which move back and forth in slots in a sewing machine's needle plate. Their purpose is to pull ("feed") the fabric through themachine, in discrete steps, in-between stitches.
    Feed dogs - Wikipedia, the free encyclopedia
    https://en.wikipedia.org/wiki/Feed_dogs Wikipedia
Oct 25, 2015 | Sewing Machines
The sewing teeth were down for quilting, I cant make them come up again for sewing, wheel turns but teeth dont move, any suggestions?
Look at the presser foot and imagine they are at the center of a clock. Now look at 4:00. There is a horizontal wheel (dial) on the free arm that needs turning.
The feed teeth are lowered when you turn the dial on the front of the free arm to the left . Turn the dial to the right if you wish to raise the feed teeth. The feed teeth will raise as you begin to sew.
Look at #12 on page 2 here: http://new.husqvarnaviking.com/sitefiles/clientsite/57/57c874e2-c4de-4acc-a703-3d47b01f941b.pdf
Feb 22, 2015 | Husqvarna Interlude 445 Sewing Machine
Viking sapphire 835 feed teeth won't raise back up after sewing buttons
The Sapphire will not raise the feed untill it makes one or two stitches after it has been lowered. Good luck
Jan 28, 2015 | Sewing Machines
Error e4 on sewing machine toyota 5090 flashes e4 and is a piece of ****,
Unable to locate a manual for your machine. You might try contacting a Toyota dealer or Toyota support. You may try totally rethreading from the beginning again. Make sure everything is correctly set before beginning to sew, ie presser foot lowered, stitch length & stitch width are set, the bobbin winder is deactivated, feed dogs are in raised position...
Sep 10, 2014 | Sewing Machines
Why is feed dog not moving material?
your feed dog has a button to lower or raise the teeth, The lower is like for stand still sewing and some way your teeth has gotten lowered Run your fingers across them and find the button to make them stand up again. You can feel the difference. hope this helps
Aug 28, 2014 | Singer Sewing Machines
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
How to raise and lower feed dogs
If you do not have a button or lever near the teeth under the plate then you should have a raised plate
Apr 04, 2010 | Kenmore 11101 Mechanical Sewing Machine
Husqvarna 950E, the feed teeth will not lower. I move the dial and they stay raised. Even when the embroidery attachment is on. Can I manually lower the feed teeth?
If the machine has been taken apart it may have been reassembled improperly so that the dial on front of freearm is interfering.
Also, try removing the needle plate. If the teeth touch the side of the plate they may not drop properly.
Aug 29, 2009 | Husqvarna Designer I
Sewing Machines Logo
255 people viewed this question
Top Husqvarna Sewing Machines Experts
radcal
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
