Question about Dryers
I need to see the wiring diagram for the power cord hookup on a Maytag Atlantis MDE6200 AYW dryer. I'm trying to hook up to a used dryer, but one of the 3 original posts is broken off and it was rewired somehow. I need to see how the wires were originally hooked from the machine to the posts so that I can use a wire nut to correctly hook up directly to the cord where the post was broken
  • 3,074 Answers
This may help Tim:
http://www.ezdiyelectricity.com/?p=221
Posted on Oct 24, 2010
6ya staff
SOURCE:
Need to know the correct 3 prong power supply cord to use for a Maytag Atlantis dryer.
Hi fredmcmur227...
There are many different pattern plugs and recepticals.
It is impossible to tell you which power cord to buy.
What you will need to do is find out what the receptical for the dryer looks like and match the receptical with the power plug your going to purchase.
I will also include a link to show you how to hook up a 3 prong wire power plug.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Jul 11, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
I have a maytag atlantis dryer and im trying to hook it up to a 4 prong hookup and there is only 3 wiring connections on this dryer
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Dec 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
How do we change a 4 wire pigtail to a 3 wire? The 3 wire doesn't have color coded wires?
Hi.
Here is a tip that shows you how to hookup your 3 prong dryer plug...if you don't have colors the black wires are interchangable...
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
Aug 18, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Trying to hook up three wire plug, witch wires go where? maytag atlantis mde6400ayw
the red and black go to terminals marked L1 and L2 polarity isnt an issue here,and the white or bare is the N terminal or neutral connection,if its non color coded cord as in gray insulated then the 2 outside conductors are the 2 hot wires L1 & L2 and the center is N neutral
Jan 09, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
I need a power cord for a maytag neptune dryer for use in a mobile home, or a diagram to hook up the one I have.
This is the 4 wire connection for the mobile home connection.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 04, 2009 | Maytag Dryers
Can you tell me how to hookup the three wires of 3 prong cord to the back of dryer that came with 4 wires(4 prong)? Which one goes where? I only have 3 prong plugs at my house. Thank you.
The following link explains how to connect a power cord to your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Now keep in mind, some newer appliances REQUIRE a 4-prong plug in order to work properly. You may consider having a four-prong outlet installed to accomodate your dryer.
You can try these steps by referring to to section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, please let me know. I hope this helps you.
Jul 05, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
Apr 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Changing power cord from 4 to 3 prong
See this link and read the article carefully - if your dryer already has a 4 wire cord, it should be replaced with same type.
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/replacing-power-cord-dryer.htm
Apr 13, 2009 | Maytag Neptune MDE6700A Electric Dryer
LDE312 Dryer electrical cord hookup
Your cord wiring, while not 100% correct was not the problem.
The green wire should have gone outside the terminal cover to the grounding screw.
There is a thermal fuse next to the high limit thermostat you replaced. Check it for continuity.
Remove the wires and use a VOM set for ohm.
No reading is a bad fuse.
Also check the door switch for continuity.
No reading when closed is a bad door switch.
Mar 20, 2009 | Maytag Dryers
Dryers Logo
109 people viewed this question
Top Dryers Experts
Marvin
Marvin
jimorris77
