Question about Whirlpool Side by Side Refrigerator Ice and Water Filter
Whirlpool - Side By Side - Refrigerator - Model: GSS26C4XXY00 For unknown reason the water dispenser stopped working..........Main water valve is on...........It appears to be making ice properly...............I can hear the solenoid activate when I press the water dispenser arm..........
SOURCE:
fridgetech
  • 473 Answers
SOURCE: Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Posted on Oct 14, 2007
  • 121 Answers
SOURCE: in door ice dispenser does not work but the water dispenser does.
the module on the icemaker may be bad or the emitter-recever
Posted on Nov 29, 2008
  • 12 Answers
SOURCE: Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Posted on Dec 01, 2008
  • 11 Answers
SOURCE: Whirlpool Side By Side not making Ice, but water dispenser works
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Posted on Mar 16, 2009
Sea Breeze
  • 4656 Answers
SOURCE: whirlpool refrigerator ice dispenser no longer workds
Ok, I show parts that are available for that model, sounds like the control board is defective for your dispenser, or possibly the Ice maker control board. It also could be a break in the wiring or the control itself. Below is a break down for those parts, wiring and the control behind the push to dispense ice or water. Hope it is not that control because some places don't provide that part. Now if it's a connection problem that we can find, I will do mu best to help you solve this.Could you insure the model number is correct as this is very important? [email protected]
Posted on Jun 05, 2009
The water dispenser will sometimes drip and doesn't stop. It doesn't stop by pulling forward on the lever, I have to push it in as though I'm dispensing more water and that usually stops it. If I don't...
There may be several reasons for this like a leaking water control valve, air in water lines or you may just need to replace the dispenser water line with a kit Part Number 8201537 Try unplugging the dispenser power on rear of refrigerator and tell me if that stops the flow. let me know, Sea Breeze
Apr 20, 2010 | Whirlpool 25.2 cu. ft. Side-by-Side...
Ice maker works but water dispenser stopped working
There sould be a set of water control valves on rear of refrigerator and where the water comes into refrigerator dispenser and ice maker. When one goes bad you replace both. You can test the windings in each coil or test for voltage while someone presses dispense water.I will ty to locate one set with your model number. Sea Breeze
Mar 20, 2010 | Refrigerators
In-door water dispenser drips water
replace water filling valve as it probable has dirt between valve seat
Nov 20, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
My ice maker has stopped working, the water continues to dispense thru the door yet the ice has stopped
Most likely the water control valve on the rear of the refrigerator is defective for the ice maker side of the valve. Try filling the ice maker with tap water and let freeze. If the ice drops and cycles and does not refill then the water valve is the problem. If the ice maker does nothing when you try this the ice maker is the reason. Send me your model number and I can tell you the parts that need replaced. Let me know, Thanks, Sea Breeze
Nov 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a whirlpool side by side refridgerator about a year or more ago the water dispenser stopped working and now the ice cube dispenser also stopped working it is no longer making ice into the container....
Your water line into the refrigerator is probably plugged up. First, check at the cut-off valve where the house water connects to the refrigerator water line. Mineral deposits often form in these small valves and can block the water flow.
The other possibility is a blocked water line within the refrigerator. Plastic weedeater line works very well to clean out these lines.
Oct 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker not working ; water dispenser ok
The reason could be several different possibilities. the water control valve for the ice maker no longer works or one of the many components inside the ice maker is needing replace or adjusted. Go to link below and enter model ED5VHGXM into model search. Click on photo #12 ice maker and you get a breakdown of of all the parts. Let me know, Sea Breeze
http://servicepartstec.blogspot.com/
May 18, 2009 | Whirlpool ED5VHGXM Side by Side...
Water dispenser stopped working.
if your ice maker works fine then its going to be your solinoid valve thats bad oin the dispenser.
Apr 05, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a 12 year old Whirlpool side-by-side refridgerator (ed20db) with water and ice dispenser. I have not used the water dispenser for years, but for some reason when I hit the lever yesterday, it did...
you have a possible water valve that is not shutting off all the way on the water dispensing side, it has 2 coils, one for ice and one for water. the other possibility is the dispenser tank is frozen, from being too cold in the refr. section and thats causing water pressure to continue running even when not pushing the lever. let the unit warm up slighty on the refr side and see if you can get water to flow properly.
if not working after warming up, then you might have to replace the water inlet valve.
Dec 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Water dispenser not working
You need to replace your inlet valve. It is located in the back. Your water line is connected direcly to it. You should be able to order one online with your model number. Good luck.
Dec 21, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Side by Side Refrigerator Ice and Water Filter Logo
178 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
