Question about OKI MICROLINE 395 Matrix Printer
How do i change the character pitch on an okidata microline 395?
6ya staff
SOURCE:
Desmond Pillay
  • 40 Answers
SOURCE: How to disable the Okidata from printing double space
Try reseting to factory defaults.
Power unit on while holding down "tear" and "FF Load" buttons.
Hope this helps
Dezzi
Posted on Dec 31, 2007
Anonymous
  • 32 Answers
SOURCE: Problem with oki microline 395
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer4.gif.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print4.gif.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints4.gif, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Posted on Feb 15, 2008
Desmond Pillay
  • 40 Answers
SOURCE: Okidata Microline 395 all lights blinking
You may have a blown logic board.
Hope this helps.
Dezzi
Posted on Nov 29, 2008
sys_admin
Milind Shetti
  • 829 Answers
SOURCE: font size
Probably the monitor-chip on the board is working inproperly.
Consult the vendor or manufacuturer.
But before this, you may download new monitor driver from the manufacturer.
Posted on Jan 11, 2009
NEV2DEP
  • 8 Answers
SOURCE: how do you replace an okidata microline 521 printhead?
turn the printer off
remove the ribbon
on the right side of the head you will see a silver lever/tab lift up on that it is hinged on the left side
lift head straight out
reinstall in reverse order
Posted on May 08, 2009
My Okidata 320 microline print cartridge is leaking ink. What does this mean?
The Okidata Microline 320 uses a ribbon. If it smears, just back the tension lever off until it goes away. Smearing will happen with multi-part forms unless you back off the printhead.
Jul 25, 2011 | Matrix Okidata Microline 320 Printer
Microline 391 okidata continous feed leaves a page of space
We have downloaded the manual and will see if we can figure it out.
Thanks
Apr 05, 2009 | OKI MICROLINE 390 Turbo Matrix Printer
Font size
Jan 11, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Squeak
Lubricate the chrome rail with 3 in 1 oil that the print head moves across on.
Jan 06, 2009 | OKI MICROLINE 490 Matrix Printer
Setting up printer for reports & checks
Press SHIFT+MENU together to enter MENU mode
press GROUP until it prints EMULATION - make sure it doesn't shows UTILITY
Best Rgds
KM Hoo
Dec 28, 2008 | OKI MICROLINE 590 Matrix Printer
Alarm light flashing
Is the front cover on the printer(ifs its not the alarm light will keep flashing as there is a sensor that will trigger the alarm if the cover is not on or not on properly.Hope this helps?
Dezzi
Jul 16, 2008 | OKI MICROLINE ML-395 Matrix Printer
Hope this helps.
Dezzi
Mar 03, 2008 | OKI MICROLINE 395 Matrix Printer
Printer not printing the top of the characters
Yes quite possible pin broke on head, check ribbon is fitted correctly and has plastic sheild on front of it intact
Jan 18, 2008 | OKI MICROLINE ML-395 Matrix Printer
Okidata 395ML
Hi ,
make sure the cables to the main logic board are plugged into the correct places???
Dezzi
Jan 09, 2008 | OKI MICROLINE ML-395 Matrix Printer
Need Help!
Sounds like driver problems. Cant solve problems without details like what opperating system, what driver, how it the printer attached, usb, paralel, network? Will it print a test page from the driver ok?
Aug 31, 2007 | Samsung OKIDATA - OKI Microline 590...
OKI MICROLINE 395 Matrix Printer Logo
430 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Clive
Clive
Thomas F. Schneider
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
