Question about Polk Audio PSW202 Subwoofer
Polk Audio PSW202 with low pitch humm when on and rattling as if cone is cracked. Cone is not cracked. On/Off/Auto works properly. What could be wrong?
    New Friend:
Sent to Polk a year ago. seemed like a known issue. fixed for cheap and sent back to me. works great.
Posted on Jan 19, 2011
SOURCE:
I have AIWA NSX-RV85. The sub-woofer surround tore leaving just the cone. When I play, The woofer just makes a rattling sound coming out of vibrating cone.Any advise on how to fix my speakers.Thanks
Refit the rubber, you can find itbon eBay, its called reconing actually in this case the cone is the inlybpart wich you dont want to replace... The rattling is beingproducer due to the fact the rubber normally holds the cone ibto positionering over the coils. This rattling is not good can defect your cone. So dont play it roll you got a new rubber fitted!
Nov 08, 2016 | Aiwa Audio Players & Recorders
Polk Audio RTi4 voice coil burned out
Order a Re-Cone kit from Polk, or have a local company re-cone it. It can be a little tricky if you haven't done a recone before.
Oct 25, 2011 | Polk Audio RTi4 Main / Stereo Speaker
Sub-woofer driver rattle/buzz.
Bad news! It sounds like the coil is rubbing inside the magnet of the speaker! There's no cure, when the cone is warped it it knackers it up. Had the same problem some years ago with a Wharfedale speaker. Someone told me you can hit it on the part where the cone joins the magnet -with a hammer!
Anyway it didn't make a bit of difference! And the speaker was chucked.
Feb 09, 2010 | Polk Audio PSW150 Speaker
My sub is making a rattling sound. I dont know what it is, and I dont play my movies that loud. I also have the sub power only about 40%, I dont know whats wrong with it
First pick it up and shake it, to see if something is loose inside it!
Sometimes the speaker cone can become damaged. If you can get at it, gently press it so it moves up & down. Don't press it from the side, just apply force all over. It should just move without scraping. If it doesn't the cone is damaged.
Feb 06, 2010 | Polk Audio PSW202 Subwoofer
PSW202 now has buzzing sound. Was slight, not it is loud. Saw the fuse solution. What about the 35amp capacitors?
Mine does the same, even at low volume/frequency. Let me know if you ever find out why.
Oct 28, 2009 | Polk Audio PSW202 Subwoofer
BX8A studiophile monitors distortion problem
it could be a loose connection or the cone is cracked inside , the only way to find out is to open and take a look inside ,check the connections , the 2 wires from box to speaker, ALSO CHECK where the cone meets with the magnet , hope this helps AJ
May 14, 2008 | M-Audio Studiophile BX8a Speaker
Polk Audio PSW202 Subwoofer Logo
577 people viewed this question
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
SANDIP MISTRY
SANDIP MISTRY
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
