Question about Vivitar ViviCam 3720 Digital Camera
FORMATTING I PRESSED A BUTTON FOR FORMATTING BUT APPARENTLY IT ERASED ALL MY FILES AND I DON'T KNOW HOW I CAN RECOVER THEM.
    Genius:
  • 1,234 Answers
#1
Insert your ( memory card , flash disk , cellphone , .... ) into your computer.
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Accepte My Greetings
Posted on Aug 28, 2010
How to reformat the phone?
formatting your phone will set back your mobile to its original setting.
to be able to do this,just go to settings > initial set-up > master reset
* If you choose master reset - this will just reset your setting to default.
* if you choose master clear - this will erase all content of your mobile including your contacts,messages etc. be sure to back up your files first before doing this method.
* if ask for the code
default unlock code is - 1234
default security code - 00000000
good luck.
Jun 18, 2011 | Motorola Mobility RAZR V3i Cellular Phone
How do I delete a recording on my JNC Digital Recorder?
I'm not sure about that particular model, but usually you can press ERASE as the message is playing.
On some other models you have to press ERASE at the end of the message you wish to erase.
In either case, right after you press ERASE it will ask ERASE? (or FILE ERASE? ) then you press ERASE again.
Just make sure to experiment a bit so you don't erase a wrong and important recording by mistake.
I don't believe it can be recovered.
May 25, 2011 | Office Equipment & Supplies
My usb a dane elect 4gb says that a need to format, but 30 min earlier is was working fine, why? and how can I recuperate my date
Don't be panic. you can try some data recovery software. You can see
http://www.asoftech.com/articles/recover-deleted-files-after-format.html
It tells the steps how to perform data recovery.
If above does not work, you may have to format the usb drive (use quick format), and then use above mentioned software to scan again the usb drive and recover your files.
May 20, 2011 | Computers & Internet
I have forget my memory cards pasword. How i can recover or remove it.
formatting is best for ur mobile momery card
bcoz when you delete something that is not erased thoroughly.
it can be experienced by using tuneup utilities in computers.
so formatting is necessary, so use these steps
*#7370# for reset settings
*#7780# for soft formatting
if you want complete format turn off phone,charge fully. then press green button, * button, no. 3 button, lastly I/O(power)button simultaneously.
your phone will be formatted in 3 mins approx.
Enter Default lock code is 12345.
Aug 22, 2010 | Nokia 6233 Cellular Phone
How can I format? I lost the intenal files
Hello Press the FOLDER button to choose a folder
Press and hold ERASE button for 3 seconds or longer.
The ERASE indicator will flashes
Press the ERASE button again.
Done blinks for two seconds and the deletion will be complete
Note AN erased file cannot be restored.
During this process don’t remove batteries. Otherwise data may be damage.
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended
Apr 23, 2010 | Olympus WS-100 Digital Voice Recorder
HOW TO FORMAT WS-100
Mar 09, 2010 | Olympus WS-100 Digital Voice Recorder
I deleted my audio files directly from the computer. Now that I try to record again, the device says that memory is full, even though I have no files on it. How do I reset it to record again?
To erase a selected file, first press the [ERASE] button. Next, press the [+] (plus) or [-] (minus) button to select "ERASE," and then press the [ERASE] or [OK] button.
To erase all files in a folder, first select the folder and press the [ERASE] button for three seconds or longer. Next, press the [+] (plus) or [-] (minus) button to select "ALL ERASE." Finally, press the [ERASE] or [OK] button.
NOTE:
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended. Individual files can be deleted using the computer with no negative effects.
Feb 05, 2010 | Olympus WS-321M Digital Voice Recorder
Erase recorded files on my Cenix VR-P490 voice recorder
You have to select the file to erase hold the erase button and when "ERASE" blinks in the display you have to press the erase button one more time. Do this for each file you wants to erase.
Jan 20, 2009 | Panasonic RR-QR150 Digital Voice Recorder
Need to delete memory
You need to remove the memory card from the camcorder and place it into a pc or photo shops computer. This will allow you to view the saved items on the memory card. You can then save these to disc and delete the contents on the card.
Jun 12, 2008 | Optimus DV-5040 Camcorder
Formatting memory stick.
You can use the MEMORY FORMAT functions to completely delete all images and options on the Memory Card, including protected images. * The format function restores the Memory Card to its initial state. * The Memory Card supplied with this camcorder has been formatted already. Attention If you execute the MEMORY FORMAT function, all images will be erased completely and erased images cannot be recovered. 1. Set the mode switch to MEMORY CARD. 2. Set the power switch to PLAYER mode. 3. Press the MENU button. 4. Turn the MENU DIAL to highlight MEMORY and press the ENTER button. The sub menu will appear. 5. Select FORMAT from the list and press the ENTER button. 6. "ALL FILES ARE DELETED! FORMAT REALLY?" appears on the screen. 7. Using the MENU DIAL, select the item. NO : To return to previous menu YES : To start formatting. 8. Press the ENTER button. If you selected the YES, COMPLETE! appears on the screen when the MEMORY CARD formatting is finished. 9. To exit the menu, push the MENU button.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Vivitar ViviCam 3720 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
