Auto Channel Setting
This is an under the counter tv/dvd/radio combination unit Model MVUC821 and I am having difficulty Setting Channels Into Memory. When we follow the users guide instructions (pg 23), this process completes but doesn't recognize the satellite (cable) connection? Only local channels are picked up. The Auto Scan processing window does not show (Cable) as depicted in the Users Guide and I cannot find a way to select a setting for this through the menu.
  • 1 more comment
  • Anonymous Jun 08, 2008
    I'm having the same problem!
  • Dave Baarlaer Nov 23, 2008
    This is an under the counter tv/dvd/radio combination unit Model MVUC821 and I am having difficulty locating and Setting Channels Into Memory. When we follow the users guide instructions (pg 23), this process completes but doesn't recognize or refer to any channels after it has scanned. We had a cable engineer confirm if the line was bad and it was not.
    I cannot even locate a single local channel. The Auto Scan processing window does not show (Cable) as depicted in the Users Guide and I cannot find a way to select a setting for this through the menu.
  • nanako Dec 17, 2008
    i have the same problem mines an older modle "panasonic fm radio and omnivision i think" and all i want to do is set up my playstation 2 on there but i cant find any channels there all just a blank blue screen and i cant set with the auto channel set...what do i do?
My remote no longer works and I can't get the menu to come up so that I can reprogram my channels and get all of my cable channels. Right now I only get basic cable channels, even though I have full...
You will have to disconnect the TV from the AC outlet for a few seconds(10-20) then reconnect the TV and press power. You should get the start up menu after you get a picture. What you have to do is use the vol up/dn , chnl up/dn keys to select the autoprogram setting after chosing from cable or antenna signal. the enter key should be one of the DVD keys either play or stop or some other key, you'll have to experiment a little with it. There is an owners manual available at retrevo.com in case you need it, but I am posting a brief description stated in the manual on how to do this. Chapter Summary: The STARTING SETUP function makes installing your TV/DVD easily...It leads you the Language selection, TV/CABLE selection and auto channel memory automatically...... Make sure that the antenna or cable TV system connection is made... ENTER CANCEL... Starting setup... Press POWER...The starting setup function begins and the Language setup menu appears on the screen...Press or to select your desired language, then press ENTER...... Users also looked at: Press or to select the “AUTO CH MEMORY”, then press...... 5S10101A [E] (P13-23) 23... This TV/DVD is equipped with a channel memory feature which allows channels to skip up or down to the next channel set into memory, skipping over unwanted channels...In addition to normal VHF and UHF channels, this TV/ DVD can receive up to 113 Cable TV channels...When shipped from the factory, this selection is in the CABLE position...... Press or to select “TV” or “CABLE...... Press MENU in the TV mode, then press to select option...... Cable TV chart... Press or to select “ADD” or “DELETE”, whichever function you want to perform...... The chart below is typical of many cable system channel allocations...... Press or to select “TV/CABLE...... Press press... TV/CABLE selection Automatic memory tuning... TV/CABLE AUTO CH MEMORY ADD/ DELETE... or... to select “ADD/DELETE”, then...
May 19, 2010 | Toshiba MD20F51 20 in. TV/DVD Combo
I GET TO THE WINDOW TO PROGRAM A RECORDING BUT FOR CHANNEL SELECTION I ONLY GET L- L-2 OR L3 I NEED TO BE ABLE TO SELECT THE CHANNEL LIKE 6 THIS IS A NEW HD TV. I AM ABLE TO PLAY EXISTING SHOW ON THE DVD...
Hi.
You will need to connect an antenna and program channels to internal tuner if you want to use the built in tuner.
It is not clear if your problem is with the HDTV or with the DVD recorder.
Both have an internal tuner, and both can tune channels , L2 and L3 are the input lines used when you connect for example to an external receiver.
Regards.
Nov 14, 2009 | Panasonic DMR-E80H DVD Recorder
Only get two channels
Go in the menu, and do the setup process of auto searching the channel. The tv gotta ''autodetect'' working channel and there is a small procedure that differ a bit from a model to another, usually pretty easy to get in...
Oct 07, 2009 | Coby TVDVD1350 13 in. TV/DVD Combo
How to pre-set radio channels
After some playing!
Use 'Auto-Scan to find required channel
Select 'Memory' ; 'Memory shows on control panel
While 'Memory' still shows, press preset button for required channel number
Programme is set
Jun 20, 2009 | Venturer Audio Players & Recorders
We are receiving channels 1-13 only; don't know how to add more
make sure you have your tv set to cable, if you have a set top box unplug the box plug it back in reboot it, like i said make sure your tv is set to cable then do auto channel scan should work good luck!!
Apr 12, 2009 | Toshiba MD20Q41 20 in. TV/DVD Combo
Program channels
TV SETTING
1. Press the MENU button.
2. Use or button to select the TV setting menu, then press or button.
3. Use or button to select the Channel no. setting and use the or button
to change from AIR (over-the-air broadcasts) to CABLE (cable/satellite broadcasts).
4. Use or button to select the Tuning mode and use the or button.
5. Use or button to select the Auto tune and press or button to
confirm the selection. The unit will immediately search through all possible TV
channels and store those channels with signals in memory. After this is complete,
the unit will switch to the first channel found.
6. To exit the MAIN MENU and return to the normal screen, press the EXIT button.
Note : In DVD mode, this option is not available.
Remarks:
1. Channel no. : 2-69 channel for Air mode, 1-125 channel for Cable mode.
2. Tuning mode : Air or Cable mode are available.
3. Auto tune : Searches for usable stations and stores them in memory.
4. Skip : ON - Skip weak channels. OFF - No channel skip.
5. Fine tune : The frequency changes to allow fine tuning.
6. AFC : Auto frequency control.
7. MTS : Select the Mono sound/Stereo sound/Secondary Audio Program (SAP).
21
TV SETUP
MTS (Multi-channel Television Sound) SETTING
This feature allows reception of sound other than the main audio for the program.
3. Use or button to select MTS menu, and press or button to select the
options (Mono, Stereo, SAP)
4. To exit the MAIN MENU and return to the normal screen, press the EXIT button
on remote control.
Note:
• MTS only operates while in TV mode.
• The SAP (Secondary Audio Programs) feature allows a TV station to broadcast
other information, which could be audio in another language.
RESTORE SETTING
If you reset the TV to the factory settings, all your present settings on picture &
sound will be erased and replaced by the factory’s default settings. However, picture
setting in PC mode and parental setting will not be erased.
Jul 15, 2008 | TruTech PLV1615T 15 in. LCD Television
No display with DVD, VCR, or tuner
It sounds to me without knowing the model or type unit that you may need to unplug tv AND take batteries out of remote for a few seconds, replug and start over. Hope it helps
Dec 09, 2006 | Panasonic PV-DF2004 20 in. TV/VCR/DVD...
Televison & Video Logo
234 people viewed this question
Top Televison & Video Experts
