Question about Mitsubishi WS-65513 65" Rear Projection HDTV
BLINKING GREEN TIMER LIGHT, TV WILL NOT COME ON
HI PLEASE HELP
MODEL IS WS 65807 2000. I PUSH RESET BUTTON AND I UNPLUGED IT FOR A ABOUT 30 MIN. PLEASE TELL ME HOW TO FIX THIS PROBLEM. THANK YOU IN ADVANCE
  • Mitsubishi Master
  • 8,617 Answers
You can get the repair kit to fix the DM at the following link. Contains the parts and step by step instructions with pictures so you can easilly do it yourself.
http://servicemanuals.vstore.ca/
Posted on Jun 11, 2008
The tv wont power on and the green timer light continuously blinks. I have unplugged the the tv and also hit the reset button.
...OK to begin troubleshooting this. Unplug the set and leave for 1 min then plug up and leave for 2 min push the power button and let light blink for 2 min.... now push and hold at the same time the MENU and DEVICE buton st the same time. this is the self diagnoses feature ... the lights should link then pause then blink again... this 2 digit code will help narrow it down. Also have you check the lamp yet?
Oct 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi-ws55859 power failure flashing timer green light
the capacitors on the DM need to be replaced. Very easy repair you can get the repair kit at this link which is for your model it contains the replacement capacitors and step by step insturctions.
http://servicemanuals.vstore.ca/product_info.php/pName/v21v19-mitsubishi-dm-repair-kit/cName/repair-kits
Apr 03, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Green light flikering
Replace all 7 capacitors in the DM Module on the DM Power Supply Board. If it is similar to the WS-65869 and WS-65513 it will have a metal enclosed DM Module at far left of chassis, looking from rear. About 4 or 5 connectors, screws, and Module slides out. Take top shield off. Take good notes or use digital camera or video recorder to make re-assembly easy. These capacitors are 1000uf@16 volts. They always check good, just replace them! After re-assembly plug AC in and wait 90 seconds or more (green Timer LED will stop blinking), then press Power button. If Timer LED doesn't stop, look for small pinhole (System Reset) and press switch with pen or small screwdriver, then wait for green LED to stop blinking. Then Power On TV.
Feb 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
GREEN FLASHING LIGHT MITSUBISHI WS-65513
On the front of the tv there is a small hole with a push button in it. Take a toothpick and push the button until the light stops blinking. This should reset your tv.....Joe
Dec 21, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Ws 65909
I had a half power outage where everything turned half off, how I still dont know. Anyways I unpluged it and didn't plug it back in until the next day. When I did the timer light was blinking for an hour. I unpluged it for a couple hours more, then I plugged it in and waited for 1 min, unplugged it and repeated, then I plugged it and unplugged it 3 or 4 times in a row, plugged it back in and waited. 1 min. then poof the tv worked. YAAAAAA HOOOOOO!!!!
Dec 30, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Mitsubishi TV WS 65869 blinking Green Light
This is a common problem with Mitsubishi rear-projection TV's.
See my post at http://www.highdefforum.com/showthread.php?t=58189
or email me at pds318@verizon.net. I can send you the instructions I used to successfully repair my Mitsubishi WS-55613 which was doing the same thing....
Dec 06, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Mitsubishi WS-55859
Check any/all fuse devices in power supply.Let me know.....T.
By the way,the tv serial # is 107543. I assume the model # is
as stated==WS-55859.
Oct 21, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
64 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
