Question about Toshiba e750 Pocket PC
Driver where can i get the driver for my toshiba e750.......i can't seem to find it. please help!! emily
  • Emily Ayton
    Emily Ayton Jul 09, 2008
    Thank you Ekse......!!!
  • Toshiba Master
  • 13,433 Answers
RE: e750 toshiba
Are you connecting by wifi or mobile?
Nov 26, 2007 | Toshiba e750 Pocket PC
Help
First when you say messing what sort of things were you messing with on it?
If it was settings or anything like that try to connect it to the computer you may need software, download the software which reads Toshiba e750 Pocket PC or any pocket PC'S prefferably from www.toshiba.com
Good luck. Hope my solution was helpful.
Apr 16, 2007 | Toshiba e750 Pocket PC
WIFI for Toshiba E750
If u use a WLAN access point, you should: 1. configure your wlan router to allow internet 2. choose "WORK" in the network connections configuration dialogs. and maybe you will have to configure the proxy server too.
Sep 11, 2005 | Toshiba e750 Pocket PC
SYNC for Toshiba E750
I suspect this is a powersaving issue: u need to play with the system power saving configuration dialogs, and turn off WLAN card power saving. maybe you will have to give completely up the power saving - only backlit.
SD GPS
I have read some Information about Toshiba PDAs. There is a technique called SD™ IO card. In the technical specifications I found this Info: 1 x SD™ card slot (supports SD™ memory card, SD™ IO card, MultiMedia card) So when SD™ IO card is the same as Bsquare SDIO Now! tecnique...
Sep 08, 2005 | Toshiba e750 Pocket PC
Sdio GPS
as far as I know the e750 supports the SD-Card I/O standard. You can check your system seettings, go to START - SETTINGS - SYSTEM - SYSTEM INFORMATION - DRIVERS There should be seen the SD/MMC Host driver, the SD/MMC Memory Driver and CF Card driver. Also if the gps card needs a driver, it should be installed also! Perhaps a system reset helps you in the end!
NAVMAN GPS Card problems
It is not easy to say what the problem can be. In my opinion you should contact the producer of this GPS receiver and ask them what the problem is. If this has been tested the producer must be able to help the users.
E750 use with Garmin 76 GPS
If no one has any solution for your issue in my opinion you should check the manufacturer’s site. Maybe there you can find out if this unit is compatible with your PDA. Usually you can find it under support or FAQs.
Lost access to Built-in Flash ROM Disk
In my opinion you should try to reinstall the image. Check please Toshiba download site. Other way contact please service partner in your country.
Sep 07, 2005 | Toshiba e750 Pocket PC
Toshiba e750 Pocket PC Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
