Question about Desa International ReddyHeater® R115DT Utility
We have a reddy heater pro 115 kerosene heater. It leaks kerosene. Can you help?
  • Desa Interna... Master
  • 43,501 Answers
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
SOURCE:
Who would have tank cap for reddy kerosene pro 115
Anyone in your area that works on them should have one laying around.
Feb 11, 2015 | Reddy Heating & Cooling
No kerosene to orfice
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
heatman101
Feb 10, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I dont get not kerosene when i turn it on.
heatman101
Nov 25, 2010 | All-Pro Kerosene Garage Shop Heaters - All...
I'm trying to find a owner's manual for my reddy heater pro 115
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the the problem you probably have and where to get the parts to get your unit running like new. Most portable heater parts are the same. Also DESA went into bankruptcy but many dealers still sell parts. This site also sells manuals. It is all in my tip. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Feb 26, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Pro 115 manual
Dave go to www.desatech.com you can down load and print off a copy of this manual, you will need Adolby 6.0.
Jan 29, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Pro 115 Reddy Heater
The ignitor is bad, there are still parts available from reddyparts.com very simple to install.
Jan 24, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Reddy 115 will not ignite
1st check to see if you have spark, 2nd check the pump pressure using the correct pressure gauge, the pressure should be 5.1 psi for model 115. if little or no pressure you may have a air line leak or a defective rotor. if you do have pressure you may have a plugged nozzle. i hope this helps.
Jan 08, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
No fuel but ignitor comes on but no motor or fuel?
You must troubleshoot to see if the motor is getting 110 volts.
The problem could be the board *or* it could be the motor.
Dec 28, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Desa International ReddyHeater® R115DT Utility Logo
392 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
mcijoe
Level 1 Expert
Gil Shultz
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
