Question about GE Refrigerators
Ou r ref is very old and it always stop..i just turn it off and then will hear sounds again as it likes working again.after few minutes it wil stop again.but the light inside is always on..hw can you help me with this?
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 25, 2010
SOURCE:
Four year old amana side by side has stopped cooling. Sounds like compressors is not kicking on. what's wrong?
Unplug it for 30 minutes to an hour and it should start up again. Problem is your compressor is no good. Get ready for a new fridge in 3-6 months.
Jul 25, 2012 | Amana Refrigerators
My machine is LG intello washer 7.5kg WD-1025FB the machine can start work, but after few minutes, it stopped and only can hear motor making noise. i turn of the switch start again, same as before: work...
Sounds like you may need new timer. They have contacts in side that control all fuctions of you machine if those contacts start failing or get burnt the machine will hit a certain spot in the timing and then it will stop or stall.
May 04, 2011 | LG Washing Machines
Ranger on a full charge stops working within 5 minutes. After 3 minutes or so, it runs again. Is the battery fried? Or is it overheating? It is aprox 1 year old. It is being run on flat ground. Please help
If power stops abruptly then theres a chance there coul be a loose connection and needs investigting. If power winds down and stopsthen yes the battery is probley fried.
Jul 16, 2010 | Polaris Ranger RZR Ride on Toy
My side-by-side refrigerator freezer, the coils in freezer ice up, and the refrigerator section get's warm. What is the problem?
OK'Lets start with the defrost timer located below refrigerator and front kick plate. Turn timer until it cklick into a position that stops fans and compressor. Leave like this for about 30 minutes. Listen inside the freezer for sounds od sizzling or crackling sounds the sounds of defrost. If timer does not automactically come ou of defrost turns gently again clockwise until the compressor starts. Let me know what you find, Sea Breeze
Feb 21, 2010 | Refrigerators
Whirlpool dryer stops drying on its own.
it sounds like its overheating. there may be lint in the vent hose or even stuck in the machine before getting to the lint trap.
Aug 17, 2009 | Whirlpool LER4634J Electric Dryer
I HAVE 26 CUB REF. FREEZEER ON TOP. A FEW MINUTES AGO THE REF. STARTED TO MAKE NOISE. IT SEEMS LIKE ITS COMMING FROM THE TOP ABOVE MY ICE CUBE MAKER. WHAT CAN I DO BESIDE PULL THE PLUG?
If it is a high pitch sound it may be the fan motor bearings. You will hear the squeal even with the door closed. This problem is solved by replacing the fan motor.
Apr 30, 2008 | Refrigerators
When starting, hear a noise like if the motor has problem rolling. The dryer works but stops during the cycle. Smeling heating after a while. And few minutes later, restarts and works, and stops...
sounds like your motor is on the way out. Hard to start-- when it does go it eventually overheats---- wont restart till cools down. sounds like a motor going bad
Mar 07, 2008 | Dryers
Hoover Whisper HD97E
Try checking the water level, and level switch? Is the outlet hose high enough of the floor? If you tip the machine back you should see one or two clear plastic tubes, take one end of these and blow through them and the do it the other way round.
Nov 26, 2007 | Hoover 24 in. DT999 Free-Standing...
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Brad Goodale
Matt Sicignano
Level 1 Expert
JP Meneide
JP Meneide
