Question about Coleman Electrical Supplies
Re: Coleman Ulti Mite (Fuji Robin Subaru) When I give it full (open) choke, it does not keep running. Please advise. Thank you
5 Suggested Answers
SOURCE:
CarlGehrke
  • 169 Answers
SOURCE: Coleman Powermate 6250 only runs with choke closed/air restricted
Hi folks,
You're both right to think that these engines were not intended to work at extreme low temps and that's a factor here.
The dry black soot on the plugs is probably just oil getting into the intake thru the breather, maybe check the air cleaner.
On some of the generators I've worked on there was a small plate in the air cleaner cover that slightly restricted air flow into the carb for low temp operation. Both of you might want to try getting a cardboard box quite a bit larger than the generator, cut a couple of holes in it to let exhaust out, and put it over the generator so that the air going into the intake gets heated a little bit by the engine. You'll want to monitor the generator pretty closely so I wouldn't recommend this overnight. You both should also be extra careful about the right amount of oil in the sump and changing it more often than usual.
My thoughts are with you folks,
Carl
Posted on Dec 15, 2008
  • 4088 Answers
SOURCE: Coleman 6250 generator runs rough
Fresh fuel? Does carburetor have adjustable jets? Turn the high speed jet (at bottom of float bowl) about 1/4 to1/2 CCW (looking at bottom of bowl). If no improvement, carburetor should be torn apart and cleaned. This also applies if there are no adjustable jets. Is there a fuel filter anywhere?
Posted on Jul 14, 2009
  • 909 Answers
SOURCE: 10HP Subaru/Robin gas on generator engine only
Not sure about the "extra jet" on te side of the carb without a specific model, but running smoothly with half choke indicates that your mixture is lean. Choking it richens the mixture.
The extra jet may be your idle stop, or it could be the idle mixture adjustment.
Posted on Jun 29, 2010
  • 185 Answers
SOURCE: I have a coleman Generator 1850. It stalls when i
Hello, I would check the carb for being dirty inside. It sounds like the needle valve is dirty, or not adjusted correctly, or there is rust in the carburator and any of these can cause the fuel not to feed into the engine properly. A good cleaning of the carb and proper setting of the needle valves should clean it up. Also check the screen in the fuel tank on the fuel valve.
Posted on Jan 22, 2011
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
How to start the generator
Hi Joe, I had asked for a little clarification and have not received any information. I will answer this question based on the generator is in good working order and it is a recoil start. Open the petcock, (this is the fuel valve) and give it about a minute to fill the fuel bowl on the carburetor. If your generator has an engine an on/off kill switch, set to on. If the generator has an auto idle switch set it to off. If the engine has a throttle lever located under the carburetor, push it all the way down (full throttle). Pull the choke knob out completely, there is a detent on the choke for half choke, pull it past this for full choke. pull the recoil starter rapidly. As soon as the engine starts running push the choke knob to half choke, this will allow the engine to run smooth while it's warming up. Depending on the climate that you are in, warm up time will vary. After a minute or two in cold climates start pushing the choke knob in, if it starts to run poorly pull it back out too the half position and let it warm up some more. When you can posh the choke in without the engine faltering it is ready to go. In warmer climates you might be able to start the engine without the choke or in the halfway position. Robin Subaru makes some of the finest small engines available. I would choose a Robin over a Honda every time. I hope this gets your generator going, and once again this is based on the generator being in good working order. Good luck, Michael Burke.
Dec 03, 2011 | Coleman Powermate Subaru 5000W Portable...
What's the best choke setting for starting a cold generator
Full choke to start, open choke partially immediately the engine starts to where the motor runs smoothly, continue opening as soon as you can while keeping the engine running smoothly. Be sure to open fully before leaving the unit, running it with the choke partially on can cause a rich fuel condition which tends to wash the oil off the cylinder walls and it also dilutes the oil with gasoline.
lp
Dec 26, 2010 | Coleman Powermate Portable Generator...
I have a coleman powermate premium plus 6250 generator,put in new plug ,new filter ,changed oil,cleaned the carb,put in new gas. runs ok at half choke but when go full choke it starts backfiring and runs...
if you are running the engine at full CHOKE, then it is flooding the engine, but if you meant off full choke, then the carb is still stopped up. Try soaking in carb cleaner overnight after removing jet & all rubber goods. HOPE THIS HELPS.
Dec 17, 2010 | Coleman Powermate Premium Plus 6250W...
10HP Subaru/Robin gas on generator engine only runs smooth with choke half on, what can cause this? also the extra jet on the outside of carb what does it do?
Jun 29, 2010 | Coleman Electrical Supplies
Is Husky 5000w a Chinese product?
Well tricky question ...Coleman factory is out of Wichita, Kansas that is there headquarters. but Subaru's head office is out of Nishishinjuku, Shinjuku-ku, Tokyo. so i think you have a mixed bag...good luck
Apr 17, 2010 | Coleman Powermate Subaru 5000W Portable...
Where can I get an subaru engine manual for 10 hp
Here your are. Subaru engines are made by Robin. I don't know if Robin owns Subaru or Subaru owns Robin. Any time you need a manual you can get it from the Robin America site.
http://www.robinamerica.com/media/manuals/128547541213915000.pdf
Feb 27, 2009 | Coleman Powermate Premium Plus 6250W...
A call to Elliott Small Engine solved my problem - Oil Guard. I had checked the oil and it was just a little low but seemed well within the normal range. I was told to add more, bringing it just over the Full mark. It seems that the low oil protection system is very sensitive and shuts down the engine even when the oil is withing 1/8" of the mark. I added about 2-3 oz of oil and no more problems
Dec 14, 2008 | Coleman Powermate Premium Plus 6250W...
ENGINE OVER SPEEDS WHILE RUNNING
This is almost surely a problem with the governor, check it like this.
Have someone with a finger on the kill switch.
Watch the governor arm while starting the engine, if it does not move almost immediately after starting the engine it is broken.
This is not a simple repair as it involves taking the crankcase apart, you'll have to contact robin/subaru to get a parts list in order to get the right governor spool and weights.
For an experienced technician this is about a 2 hour repair task.
Hope this helped,
Carl
Dec 03, 2008 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
166 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Sheldon Dedek
Shawn DuRee
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
