Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
How can i get a owners manual for my toyostove laser 30 ?
  • 674 Answers
You can go to www.toyostove.com and download or print out an owner's manual. Hover over owners' manuals and when the drop down menu appears click on vented heaters. You can download owner's manuals but not service manuals.
Posted on Oct 25, 2010
SOURCE:
I just want an owner's manual for the toyotomi 'Laser 30" gas heater in my apartment. Can't find one anywhere. Carmen Carrion [email protected]
Granny in 40's, you can go to www.toyostove.com and in the drop down menu under owner's manuals, select vented heaters. You can then down load the pdf file for the Laser 30. However, I think they are all kerosene. I have never seen a gas version of one. [email protected]
Dec 01, 2010 | Heating & Cooling
I need an exploded view of the toyo 30 heater. Some thing is loose in the fan and it makes a racket when running... I suspect a vole (I live in Alaska) tried to build a nest....
Go to www.toyostove.com . Click on owner's manuals and look for the pdf file for the LR-30. The parts break down is on page 7. Part #40 is the blower motor, part# 41 is the fan, and the cover it shows behind the fan doesn't give a number. You should be able to just remove the screws from the back and open the blower.
Nov 06, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
How do you get Rinnai energy saver (263FA) out of function lock mode
When you say "Function Lock" I am not sure what you are looking at. If it the Child Lock feature, you should be able to turn the stove off and push the Child Lock button to turn it off. Some of the error codes on Rinnai's look like tempertures,i.e. 60, 68, 11. I am not sure about the 263's but they should be just like a 556F. If you have a owners manual you can find all the codes. The Rinnai web site can help you get a manual if you don't have one.
Tom
Oct 06, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Don't know how to set my toyostove 73 laser?
READ owner's manual
If you don't have one you can get it on-line www.toyotomi.usa
Jan 15, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
We have a p1 code?
p1 is in the testing mode the hour button will click p1 p2 and p3 depending on how many times you click the hour button or minute button . This is to manually test the burner on low , medium, or high p1 being low.To put it in this mode hold the minute and hr buttons down at the same time for 3 seconds.I unplugged the unit to reset.
Dec 20, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 30
Could it have to do with the temperature sensor? If it is still coiled up on the back of your heater, it may be turning the heater off. You need to uncoil the sensor wire, and place the sensor somewhere away from the heater. One sight said atleast 8" off the ground. (I have a Laser 73 and mine is about two feet to the right and about 8 foot up on my wall as I have a lot.) You can attach it to a board if you have to, or any other item. Just put it as far away from the heat of the heater as you can so it will only be sensing the room air temp. If the line needs to be longer you can cut in stereo wire (I read this online too). Then play with the heat settings to see at what temp it is most comfortable for you. Hope this solves the problem.
Apr 12, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove Laser 73
There are 2 fuses on the mother board. You can go to the Toyotomi website download the Owners Manual and look at 49 and 50 in the parts list and picture.
Mar 05, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 73
A manual can be found online by googling Toyostove 73 and owners manual or manual. I use it often. It is at on the rural energy website.
Jan 13, 2008 | Rinnai Toyostove Direct Vent Heater:...
Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Oct 20, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
404 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Thomas F. Schneider
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
