Hi I have a media center pc model number m7664x yesterday the computer was running fine then it stopped booting up it brings you to the esc boot f10 computer recovery screen and the keyboard will not work I have put in new hard drive not that new memory not that new power supply not that either I am at a loss don't know what it is please help if you can thank you.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 12 Answers
Replace CMOS batter and resit ram
Posted on Sep 18, 2017
4 Suggested Answers
SOURCE:
SOURCE: Computer won't boot up
you must hold down the F10 key( for system recovery) when you turn on computer. hold down as computer starts up,hopefully it will then repair itself and boot up. If not,start up computer holding down F12 for advanced diagnostics and run some test!! Good luck
Posted on Mar 07, 2008
  • 1383 Answers
SOURCE: my Compaq sr2150nx desktop turns
Open your cpu cabinet.
Refix your RAM clean all dust from circuit bord.
Reconnect processor fan and processor.
Reconnect power supply from psu to motherbord.
Pull your cmos cell from motherbord for 15 minutes from motherbord so all settings are reset to defaults.
Posted on Aug 01, 2009
SOURCE: My hp pavillion Media center
Welcome to Fixya
You are having that issue because the system is not able to detect the operating system of your computer. This could be caused by two reasons, The hard drive of your computer may already be defective and is no longer detected by the computer or the operating system of your computer is corrupt.
If this issue is caused by a corrupt operating system then you can try to press F11 for system recovery. This would cause the system to restore to its factory condition. Please note that this step would cause you to lose data on you computer.
You can also try to press F9 to run diagnostics on the hard drive of the machine. If it displays an error the hard drive of your computer is defective and you would have to contact HP to check If you still have warranty and get a replacement Hard drive
Hope this helps
Posted on Jun 30, 2011
HP 15-d035dx will not boot even with usb.cannot start because File:\windows\stytem32\boot\winload.efi is missing. I wished that I had the Ubuntu Operating System DVD or USB but I don't.
windows 8? loaded?
What are you asking, ? how to fix windows ? or LINUX>?
how to repair this PC yes. all ways, sure.
5 year old PC, not too old. but... runs UEFI.
so I guess you never used BIOS< ? (esc key?)
and set the boot order correct or the hot key for booting on the fly F9.
ON newer HP, they run UEFI now. the newer BIOS,
to reload windows using MEDIA, and not the F11 magic key below.
Say booting Ubuntu,v17 USB install media made on a good PC.
you must go to bios
power on, hit esc, hammer it and then hit F10 it tells you what to do in the ESC list now, f10
click on tabs for this. screen.
1: turn off Secure boot or it will never boot to usb or dvd. ever.
see photo below..
2: then turn on legacy mode. F10 safe.
it will send you a secret 4 digit code, like 1F1C ?
at the reboot it asks for the code and must be typed blindly.
(no echo of the code happens, just type it and last ENTER.
bingo it can boot anything you want.
wished< why wish, all it takes is the USB stick and free Rufus
to burn the stick 8GB bests sized, cheaper it is.
why wish, does that really mean no 2nd PC there? or at friends?
there are no lack of PCs now.
Answer 2 , page 81 covers this.... real books HP has omg real books.
http://h10032.www1.hp.com/ctg/Manual/c04763947
in all cases I run HDD tests on the HDD first.
or every step past here will be a waste of time, if the HDD is bad.
The trick is hammer F11, the magic, HP recover key
and recover,.end story, PC cured. w8? back working
all personal files gone.
to load any os media, install windows fresh or linux
this must be done.
safe-odw4dyhl4y25qsq4z4srnihs-1-0.jpeg doing this wrong above, and getting the secret number wrong
makes BIOS reset back to secure boot,
so repeat this again, set these 2 items, F10 , see secret code
and then on reboot ask for secret code, type it in blindly
and now you can boot from ANY THING.
Aug 29, 2018 | HP Computers & Internet
Gateway sx series sx2110g-uw318 boot menu
This is an snippet from the Gateway Website.
"In order to access the boot options on this portable computer, press the ESC or F10 key while the Gateway screen is displayed during the startup process. This opens a Boot menu with the option to start the computer to any of the available drives or to enter the BIOS Setup Utility. Use the UP ARROW and DOWN ARROW keys to select a menu option, and then press the ENTER key to start to the selected device.To "boot" (start) to a CD, DVD, or a floppy disk, the media must be in the drive when starting the computer."
Jan 26, 2014 | Gateway SX2110G-UW318 Small Form Factor...
Will only run on safe mode
Restart your computer
During the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup this may vary depending on your computers bios other possible keys
F10
Acer: - Ctrl +Alt +Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Press and hold that key during the boot up process to enter BIOS using the arrow keys navigate
load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Jul 08, 2013 | Compaq Evo D500 PC Desktop
I start up my computer and i get a black screen that says "NTLDR is missing Press Ctrl+Alt+Del to restart" at the startup screen pressing f10 doesn't bring up system recovery and I don't have...
what is the model of your computer,? if the recovery software is in a hidden partition there must be a way to access it from boot, otherwise, you will have to buy a windows disk and reinstall windows.
Feb 05, 2011 | Microsoft Windows XP Media Center Edition...
I have a HP Touchsmart IQ500 that is a little over a year old. It was working fine and I went out one day to come back and start it up to find it was only a blue screen with a few options.I found someone...
This might be an issue with the Hard drive or the operating system installed on the hard drive.
Try to access BIOS screen tapping on F10 on restart.
If you are able to access Bios try to run the Short smart self test on the Hard drive.
To run the test follow the steps as follows:
on the main window you will see 1 st drive 2nd drive 3rd drive 4th drive.
besides these drive letters you will find your Hard drive listed.
Highlight that and press enter.
on the next screen highlight Smart support and press enter.
on the next screen select Short smart self test and run the test.
If it gives an error code that means the hard drive has gone bad.
2)If not then come back on the main page by clicking on ESC button till you come back to the main page.then Press F5 select yes to load set up defaults and press enter.Press F10 once to save configuration changes and press enter.
It will boot to windows.
3)Still if you face the same issue then you need to perform the recovery using the recovery cds.
4)If you don't have the recovery cds then you can contact HP support and order the cds and perform the recovery.
This should resolve your issue.
Thanks.
Aug 20, 2010 | HP Computers & Internet
Upon turning on my HP Pavilion Media Center it freezes at logo.
press F10 and format the pc with inbuild pc recovery and if it does not works then format your pc using the recovery discs given to you by HP.
Apr 15, 2010 | HP Pavilion Media Center TV m7360n...
Acer aspire 5610 new hard drive need to load xp operating software help!
hey... to install XP to the hard drive, u need to restart the PC with XP CD in the Drive... When the computer starts up you'll need to press F10 or F12 to bring up the boot menu (it depends upon ur motherboard type).. select boot from CD n follow the instructions....
Apr 02, 2010 | Microsoft Windows XP Media Center Edition...
How to change the Bios Boot on a HP Pavilian a141On
Go into the system BIOS when the desktop boots (usually by pressing del or F10) Go to the boot options tab and follow the instructions to adjust the order of the disks. F10 to save and exit - it should now boot to the required disk
May 07, 2009 | HP Computers & Internet
M y screen reads Boot from CD!!
Hi there.
Go into the bios (F2 on start-up) once in the bios set the first boot device to hard drive or HDD, hit F10, save and exit, the computer will restart and should boot from the hard drive.
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Intel Celeron -D 2.26Ghz Computer System...
Mar 06, 2008 | Computers & Internet
Open Questions:
\Q;- TOSHIBA customer service phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This TOSHIBA USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 TOSHIBA USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the TOSHIBA USA customer service department for problems like Where to buy, Complaint, customer service, Repairs, Returns. As far as we can tell, TOSHIBA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. TOSHIBA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact TOSHIBA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling TOSHIBA USA Calling TOSHIBA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our service call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from TOSHIBA USA customer service can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with TOSHIBA USA's customer service department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare TOSHIBA USA's phone numbers against each other. Contacting TOSHIBA USA in General While [+I8OO-8O3-1O69] is TOSHIBA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact service for you to look at as well. One thing to keep in mind as you try to reach TOSHIBA USA help by calling them, is that other customers give their customer service at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact TOSHIBA USA.
Oct 18, 2019 | Toshiba Computers & Internet
\Q;- HP customer care phone {+1'8OO-8O3^1O69} NuMbEr USA .ANITA This HP USA phone number[ +18OO-8O3-1069] is ranked #2 out of 2 because 7,728 HP USA customers tried our tools and information and gave us feedback after they called. The reason customers call [+I8OO-8O3-1069] is to reach the HP USA customer care department for problems like Where to buy, Complaint, customer care, Repairs, Returns. As far as we can tell, HP USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. HP USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact HP USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling HP USA Calling HP USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our care call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from HP USA customer care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with HP USA's customer care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare HP USA's phone numbers against each other. Contacting HP USA in General While [+I8OO-8O3-1O69] is HP USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that[+ I8OO-8O3-1O69] is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach HP USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact HP USA.
Oct 18, 2019 | HP Computers & Internet
Computers & Internet Logo
44 people viewed this question
Ekse
Alun Cox
