Question about GE Microwave Ovens
Have ac power. Nothing lights up or responds.
  • GE Master
  • 9,086 Answers
A microwave can be dead for many reasons.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
LG LMV 1680 ST shows error AC-1 and will not heat. The turntable does not turn either. The exhaust fan still works and the control panel still responds. What does this code mean?
Check the fuse. Also check out the safety switch by the unit door. If not closed when door is closed, no power is applied to either the turntable or the tube.
Aug 22, 2017 | LG Microwave Ovens
My Advantium 120 microwave shows the time, but none of the buttons respond to being pressed.
Try turning it off at the power switch,leave off for several seconds then switch it back on, it may reset the control unit, if not take it to a repair outlet,
May 27, 2015 | In Microwave Ovens
I have a Frigidaire Electric smooth top range and oven. when I set turn on the burners they do not light up or get hot. When I try to bake I press the Bake button and set the temperture but the oven never...
HI.CONTROLS MIGHT HAVE BEEN LOOSE.oR LOOSE CONNECTION BETWEEN the control.Check the control connection inside .It might respond but connection has been loose.hope this helps..
Jun 21, 2011 | Frigidaire Microwave Ovens
My GE spacemaker xl1400 model JVM1451BA 001 DOES NOT TURN ON, serial # HT9897895 , it wont make a noise or nothing, not lights, someone told me its a fuse, but I dont know what the fuse is called to go to...
First try plugging it in a different power outlet to eliminate a possible defective AC outlet, than if it still does not work, your friend could be correct it could be a fuse, if you have electrical skills you can verify your self. first unplug the power cable, than unscrew the cover to get to the electronic board, locate all the ceramic fuses and with a good multimeter set to (Ohms) check the continuity of all fuses if it reads 0 ohms it's good if it reads nothing than it is bad, replace that fuse with the same amperage and type than put the cover of the oven back, plug the power cable and give it a test if the fuse burns again than the problem is much worse, it could be a defective safety switch on the door frame or a defective circuit board, take it to a good repair shop...
REMEMBER TO ALWAYS UNPLUG THE POWER CABLE BEFORE OPENING THE UNIT!!!
Hope this helps!
Jun 18, 2011 | Microwave Ovens
665.68601890 Acts as though it is not receiving power but breaker is not thrown. Is there an internal reset. Nothing responds - no lights, fan or microwave. Panel is black and non responsive
ther is on most microwaves a fuse inside usually located behind display panel located in a fuse block or will be on the control board itself.. normally a 20 amp fuse...try that first if not then make sure you have power to control and if so and no display most likely the display control board...
may luck out and be just the fuse though....good luck
Jan 08, 2011 | Kenmore Microwave Ovens
Whirlpool gold series model gh7155xhs-1 buttons not functioning
Remove power to unit, wait 3 min. Plug unit back again try using touch control, If it still not working replace controller assembly, touch pad and board.
Sep 17, 2009 | Whirlpool GH7155XHS Microwave Oven
Will not restart or respond to reset clocks or lights wont work nothing works what should we do
Don't do nothing at all??
If nothing works or no lights come on, try to change the outlet if not working replace the fuse of the MW
May 11, 2008 | Microwave Ovens
Sanyo Super Showerwave out!
Sounds like a bad connection inside. unplug the power, take off the cover, look over all the connectors closely.
Dec 31, 2007 | Hotpoint RVM1435 Microwave Oven
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
