Question about Polaroid TLA-04011C 40 in. LCD TV
During a thunder storm our polaroid tv went out..we have changed the fuse but it still isn't working..any other suggestions?
  • 1,662 Answers
Call your homeowners' insurance agent. Seriously, if the set is worth more than your insurance deductible, you will want an expert evaluation on whether the set can be profitably repaired so you can make a claim if necessary.
Was the first fuse blown? Did the second fuse blow? If the answer to both questions is yes, then you have a fried power supply switching transistor - at a minimum. You might even see cracked or burned parts on the board that has the fuse on it (look at the parts on or near the finned metal radiators). Lightning typically damages a number of parts. You may find it cheaper to replace the entire power supply board, and hope the rest of the set isn't damaged.
If both fuses are good, that could be worse news, because that implies lightning got in through the antenna/cable input and zapped the main circuit board. This is the second-most expensive part of the set after the LCD panel.
A suggestion for "next time": if a TV set blows a fuse, get the problem fixed first before risking a new fuse on it. It's rare that a power surge blows the fuse without also breaking something else. The fuse is intended to minimize damage and prevent fire in case something in the TV shorts out or the surge protection components are unable to handle a high energy pulse on the power line. It's not guaranteed to protect the set from damage.
Posted on Oct 24, 2010
SOURCE:
Tv does not turn on, after a thunder storm.. tv was off during storm.. but heard a click as if I was turning off tv.. Blueray player , ok Direct tv box ok , all come on that was connected to tv... whi
during thunder storm, is your TV connected to wall outlet, if it so your set have a problem on power supply, you are lucky if is only a blown fuse.
Aug 06, 2014 | Televison & Video
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
Aug 26, 2012 | Frigidare FGB24S5DC Gas Single Oven
HELP! I think my TV got zapped and is ruined from storm!
Check whether the power outlet has power. If it has, I suggest please do not attempt to switch on the TV, unless checked by a qualified service technician.
Aug 16, 2012 | Toshib 46L5200U 46" 1080p LED-LCD TV -...
Kdl40ex401
Hi there!
One of reasons your tv not working, the thunder storm /lighting possibility has burnt your Tv micro processor. get a technician to check the power supply section too because during the thunder storm your TV circuitry received excessive voltage .
If is the main processor is burnt you have to change it for the TV to work .
Jan 10, 2018 | Sony KDL-40EX401 42" HDTV-Ready LCD TV
My Sharp Aquos LC-26D44E-GY in the spare room has stopped working. It worked ok about 2 weeks ago, went to switch it on last night & its dead. We had a thunder/lightening storm last week? Ive changed...
First check your power outlet, try connecting the TV to a different power outlet. Then see whether the LED light on the TV is on or blinking. Anyhow, this might need attention by a qualified service technician.
Jul 15, 2012 | Televison & Video
My wd-60c9 60 in. dlp hdtv quit working after a thunder storm it was plugged into a powerstrip . The only this that wont work are the tv and direct tv receiver.
fried it, unfixable, get a new one. and start unplugging everything during storms. if you still want to watch tv while there is storm get a old crappy small tv to watch while you high priced one is in safe position(unplugged)
May 23, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
During a thunder storm my power went out, when the power came back on my Polaroid 32'' LCD (FLM-3232) would not turn on. where came i find the possible blown fuse?
Go to this repair page - your electrolytic capacitors in the power supply could be failing: http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen If not, then if there is a fuse, you should be able to find it with the back off. I don't recall seeing one though.
Oct 29, 2010 | Polaroid FLM-3732 Television
JVC 48" HDTV Ready Widescreen Projection TV
Terrible thunder storm can create electrict shock to our appliances thats why we recomended that if you donot use your tv pls unplug it, and it mostly if you use outdoor antena when the thunder hit the tv will damage.
Jan 10, 2008 | JVC HD-61Z575 61" Rear Projection...
Polaroid TLA-04011C 40 in. LCD TV Logo
356 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
