Question about Coleman Powermate Powermate 5000W Generator
New never been run but purchased four years ago took out of box yesterday because power was out at my house has spark but doesnt seem to be getting fuel bottom line will not start
  • 10,865 Answers
Make sure you put brand new fuel in it. Fuel that has been sitting for months or years is always a problem. If there is old fuel in in, siphon it out and start with brand new from the pump gas. Also, be sure that the spark plug wire is tight and that the air filter is not clogged with oil [ often the case when the generator gets turned while moving it.].
Finally, get a can of starter fluid and an assistant.. Squirt some starter fluid into the air intake area where the air filter is located, start it up and have your helper continue to spray starter fluid to keep it running till the regular gas takes over. Joe
Posted on Oct 24, 2010
SOURCE:
B2300. What are the probable causes of DTC P0132?
Use an ohmmeter to check your spark plug wires all have very close to the exact same resistive value
Nov 19, 2015 | 2004 Mazda B-Series
P0301
Well the code means the computer detected a drop in RPM for that cylinder. The problem can be spark, fuel, or compression. If you think the cylinder is getting spark, the other two causes would need to be checked.
Jul 03, 2013 | Oldsmobile Cars & Trucks
Suddenly dropped hdmi signal on all ports - sees device but gets
Switch off the TV, switch off power and remove plug and wait for 48 hours and retry.
Jul 28, 2012 | Samsung UN55C9000 55 in. 3D LCD TV
I have a GE Monogram ZIBI240 Bar Refrigerator with Icemaker. This unit is brand new out of the box. We purchased it 5 years ago and it was never installed (for reasons I won't go into). Installed i
is the compressor running if so it is out freoin or compressor is bad or want start may be relay compressor should start after the fan starts
Dec 12, 2011 | GE Refrigerators
Hi, I had the knock sensor changed in my 1997 Legacy Outback by an independant shop. I drove it the one mile back to our house and was amazed at how quiet it was to not have the ticking sound! But, now...
free check engine code read at auto zone. we replaced a sensor 15$ our spark knock sensor is still out but ran fine for two years. a month ago lost power sputtered with ac on , turned out to be a spark plug wire 29$ set of four we replaced ours with one we had from another car runs great again
Jul 18, 2011 | 1997 Subaru Outback
My 2002 gmc sonoma (extended cab sls) will not start i have changed plugs and wires fuel pump and fuel filter i have done oil change and air filter change. the truck will fire if i give it a spray off...
My engine light in my 2002 GMC Sonoma has been on for the past four weeks. Yesterday I had an oil change done on my truck with a local mechanic. He turned the engine light off, but it came on soon after leaving his shop.
This morning I went to start my truck and there was NO power whatsoever. After repeatedly turning the key, I soon saw a slight movement on the battery display, but no lights would come on. It just seemed like it wasn't getting any power. I changed the battery two years ago, so it should be fine.
Eventually, the truck received full power and started, more less out of no where. It wouldn't hold an idle and would just die if i took my foot off the gas.
Hopefully someone has a solution for me.
Thanks.
Jan 03, 2011 | 2002 GMC Sonoma Extended Cab
My ps3 was working fine four days ago. I took it to my brother-in-laws two nights ago and hooked it up. We played it on his tv with an xbox hdmi cord and it was fine. I took it home and plugged it up to...
Ok you must be using a a/v cable at your house? And the hdmi cable at your brother in laws? If this is the problem its not the xbox hdmi cable. It doesnt matter all hdmi cables work the same. Its your settings. You need to hold you power button down and it should come on and beep twice then release it and a settings menu should pop up if it doesnt hold the power button down until it comes on and shuts off then hold the power button down again until it beeps twice. Hope this helps.
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
Isuzu Hombre pickup, 2.2L Vortec, Won't Start.
You need four things for an engine to run. 1. fuel 2. spark 3. compression 4. timing (spark at the right time. By your post it seems you have fuel and spark and you probably have compression unless you blew a head gasket. That leaves the timing. Check the timing and/or the timing belt or chain whichever you have.
Jul 01, 2009 | 1998 Isuzu Hombre
TRYING TO REGISTER NEW GRILL AT WWW.GRILLREGISTRATION.COM RE-THE MANUAL DOES NOT COME UP TO ANY REGISTER. HOMOPHONE IS WHAT COMES UP. PLEASE ADVISE. [email protected] THANK YOU
I am trying to go to www.charbroil.com/register for 30 min now and I always get error messages. I bought the grill yesterday and want to register it. Help, please. Gisela
Jun 24, 2008 | Kitchen Ranges
Damp clothes
the dryer is not the problem the problem is the house vent it is restricted some where
May 02, 2008 | Whirlpool LER6636PW Electric Dryer
Coleman Powermate Powermate 5000W Generator Logo
62 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Sheldon Dedek
Shawn DuRee
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
