Question about HP Photosmart Premium C309A All-In-One Printer
My HP309A has gone off line. How do I get it back online?
  • HP Master
  • 7,733 Answers
Search at http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3737192&taskId=110
Posted on Oct 24, 2010
SOURCE:
My nokia n8 is gone offline I can't get back online please help.
Not sure I understand what is the problem, please add more details.
Sep 23, 2016 | Nokia N8 Cell Phone
I had 400k all of a sudden it's gone and I had
400k what? If you're asking about chips at an online casino or something similar, please contact their web site. FixYa has no control over any online casino, even had you named it.
Jun 28, 2013 | Pool & Spa
All lights on my HP309A are blinking
1. Remove the USB cable (or parallel cable) from the back of the printer
2. Remove any memory cards, USB sticks, or any other media from the printer
3. Remove the power cord from the back of the printer
4. Wait 15 seconds then reconnect the power cord
5. Wait for the printer to finish its power on cycle and then reconnect the USB (or parallel) cable
Oct 07, 2012 | HP Photosmart Premium C309A All-In-One...
My HP309a-m is printing with missing lines of type or only half the thickness of the letters and is evenly spaced down the entire page, can anyone suggest a fix? Best regards, Ian
First reinstall the driver software to be sure it is not corrupted.After that remove the cartridges..and check them not to be empty or dried out..Usually the poor printing is caused by unused cartridges for a long time ...fact that leads them to dry out and not providing the ink like it should ..In this case you have to change them and make a count reset..if it seam not to recognize them new..or if you refill them ...
In case you use refilled ones..check them on a piece of paper to see if they work proper..When they are working they should let a good rectangular impression when they are pressed against a paper ..(one cm long and about 3mm wide ).
To reset it ..follow the manual ..or ..remove the power cable while it is powered and on ..and attach it again after 30 seconds..and when you power it on try to keep the power button pressed for 10 seconds..
Oct 31, 2011 | HP Photosmart Premium C309A All-In-One...
I have an HP309a which I bought just over a year ago. The wireless printing has stopped working with the network test report stating 'the wireless radio is not functioning, contact HP support' Does anyone...
found that clicking to Setup ' Network ' Wireless Radio and then manually turning the radio OFF then back to ON solved the issue. if this does not fix the problem please respond with solution that resolved yours as my sister is currently attempting to resolve issue on her laptop with printer radio not working.. thank you
Nov 15, 2010 | HP Photosmart Premium C309A All-In-One...
Clutch pedal all the way to the floor, bleeding it repeatably, within minutes pressure gone and air in lines. replaced master cylinder. what do i need to do and where can i get a diagram for clutch...
sounds like your losing fluid from the slave cylinder or a leak low on the line. Someone should be slowly pumping the pedal as you close the bleed fitting with an extension hose on it in container of fluid to prevent air being sucked back in. Did you replace both the clutch master cylinder and the slave cylinder? As I recommend to everyone..invest $25 in a shop manual from your local auto parts store or an online access to manuals...
Oct 02, 2010 | 2004 Chevrolet Cavalier
Just f------- get me some some one to help me
what make and model printer have you got, has it got an online / offline button that you can press to bring it back online again ?
What about if you turn it off for about 5 seconds and turn it back on ?
Apr 10, 2009 | Office Equipment & Supplies
HP Photosmart Premium C309A  All-In-One Printer Logo
138 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
