Question about Gateway Computers & Internet
Internal cd-rom drive doesn't recognize that a blank cd is in the drive.
  • 3 more comments
  • cejay Jun 08, 2008
    I have tried cd-r and cdr-rw disks. The drive will, however see and open a previously used cd-r.
    Sorry, I forgot to mention that there is also a problem with an external drive which I bought because I gave up on the internal drive.
    The problem with the ext. drive is than when trying to drop a folder onto the icon, a box pops up which states: windows encountered a problem when try;ing tom copy this folder. what do you want windoes to do? retry-skip-cancel. there is no error code.
    Perhaps the two problems are somehow related
    Before winding up at this site, I contacted Wmachines email support and was advised to go into safe mode and uninstall the cd driver at the device manager, then restart and allow os (XP home), to reinstall the "correct" driver. After doing so, I got the same result: please insert a disk....
    The PC is an Emachine which came equiped with a cd-r-rw drive E, and I have no idea what make it is.
    ok, I've tried what ajkill said to try, uninstall driver(s), scan ,etc.
    There is no improvement so far, is there anything else?
    Genius:
  • 2,035 Answers
Checked all the cables to the unit, making sure thay are secure?
and then In the device manager check for any ( !, X or ? ) and Uninstall the driver, then REBOOT and see if it reloads properly. If that doesn't work, uninstall the driver again and try scanning for hardware changes to re-install or (preferably, if available) upgrade the driver. Perhaps you could also run System File Checker: Start -> Run -> sfc /scannow..............
NOTE : CD rom only can read written disk and in play format check if the CD is blank or copyright or pirated one some drive don't read these disk.........................
Please let the operating system and the make of the CD rom ,or its CD wirter?
Posted on Jun 08, 2008
  • 1 more comment
  • Anand Kumar
    Anand Kumar Jun 08, 2008
    You need to uninstall the nero software from you r computer reboot it and then install the drivers again if this did not work you download thew drivers form the inter net and install and check if this cd works if not try buring another cd and read.
  • Anand Kumar
    Then the CD drive could be faulty or dirty use cd lens cleaner to clean the lens ...........................................
  • Anand Kumar
    Are you facing the problem with this disk only?
  • Gateway Master
  • 13,433 Answers
Try another disc, the drive may be faulty or dirty.
  • 1 more comment
  • Ekse Jun 08, 2008
    if there is no ! mark or a error code on the cd rom drive, then its most likely faulty. Most likely a problem with either the lens or in the circuit board.
  • Ekse Jun 08, 2008
    Best to buy a new DVD Burner, they are very cheap these days. Not worth repairing.
    heres one for example
    http://www.newegg.com/Product/Product.as...
  • Ekse Jun 08, 2008
    burns cds and dvds
My compaq presario f768wm isnt recognizing my cd/dvd rom. my camera quit working and also it says it can't find my audio output device.
For that problem, Try first replace that internal DVD-rom drive other good internal DVD-rom drive. if not Also Detected or recognize.
Try this second solution. insert external USB type DVD-ROM. if not recognize also, Your operating system Have internal software device data corrupted. You need to reinstall operating System like windows xp, windows 7 (OS) etc.. to fix data Corrupted of operating system device for hardware software.
Please see sample external DVD-rom USB type.
Just let me know if not yet working your Compaq Presario 700 series DVD-rom Drive.
Thanks for using Fixya.
Aug 19, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
CD driver do not read any file
Does it recognize any cd you put in the drive or is it only one cd it doesn't recognize?
Please check if the cd drive is recognized by your computer:
Click Start go to My Computer (XP) / Computer (Vista/Win 7)
and check if you can see the drive. (if it's not there you may have to reseat the drive to make sure that the cables connecting it to motherboard are tight)
check the status in the Device Manager:
On your Keyboard press and hold the Windows Key then press the letter R
once the Run box comes up type in devmgmt.msc and the device manager should appear.
On the device manager look for the cd / dvd drive see wether it has an exclamation point a red x mark or a down arrow or it looks normal.
if it has a yellow exclamation point press and hold the windows logo then the letter R again and type regedit:
On regedit go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and the delete the upper and lower filters. Close Regedit and restart the computer.
if it has a red x mark right click on the cd drive in the drive in the device manager and the choose uninstall and restart the computer.
If it has a down arrow right click on the drive and click Enable.
If the above steps doesn't work or if it doesn't recognize all types of media you put in it, that might mean that your cd drive is busted and it needs to be replaced.
Hope you find this helpful!
Apr 30, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
Cd drive wont recognize blank cd's and i brought brand new ones and it still dosen't reconize them
Make sure you've loaded blank CD on CD RW device. CD ROM drive has nothing to read on blank CD. Regards
Dec 19, 2010 | Dell Computers & Internet
Blank cd's are not recognized by the Dell Inspiron cd burner
I would first try removing the device in the control panel, system, device manager and then reinstalling the driver. There may be a problem caused by a windows update. In general CD drives rarely go bad. If the CD works say for a music CD then it should work for blank cd. You may also want to check the CD type. If you accidentally used a DVD, that won't work and in some of the older CD drives, they may not handle every type of CD format.
Good Luck
Feb 02, 2010 | Dell Computers & Internet
My CD-ROM drive is not recognizing blank CD-R's. I have tried uninstalling and reinstalling the drives, but it has not worked. Any suggestions?
A CD-ROM will never recognize a Blank CD-R. It is a blank CD. If you want it to burn to the disk you will need to purchase a CD-Burner, and then install the burning program that comes with the CD-Burner.
Sep 17, 2009 | Computers & Internet
DVD/CD-rom 52X cd-rom unable to recognize DVD
the lens inside the cd rom wil hav to be cleaned
then it wil detect
if the problem still remains then u have to replace the lens inside the cd rom
Mar 07, 2009 | Sony (CDU5212) Internal 52x CD-ROM Drive
Cd -ROM does not recognize any disc that is inserted into it.
hi
Okay first does "any disk" mean ANY disk, or any disk in the same pack of blanks ? Some cheap media has this problem.
If not, then you probably have a hardware problem.
Try checking Device Manager for flags. Report them here.
someone will know more .
If none, your optical drive may be bad.
I'm assuming "delete the drive and reboot" means uninstall the drivers Device Manager. Did they have any flags before ?
Make sure to enable "show hidden devices". You might have a non-plug & play device driver in conflict, and they are hidden.
What software are you using to burn disks ? There may be a problem with that. If there are no flags in device manager, uninstall the software (if it's Nero, Roxio or something). You can reinstall the software later.
riz.
Mar 04, 2008 | Gateway (5500778) Internal 32x CD-ROM...
The cd drive does not recognize any discs
That is not a DVD drive, it is a CD-ROM drive. It can not play DVDs.
Jan 20, 2008 | Panasonic CD FOR TOUGHBOOK (cf-vcd721w)...
CD Rom not recognize
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
Nov 18, 2007 | Samsung (SC-152) Internal 52x CD-ROM Drive
Computers & Internet Logo
44 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
