My Vizio VW37L only puts out moderate volume, even at 100% volume setting. It wasn't always a problem.
  • taralundberg Oct 24, 2010
    Thanks welcomejee. I had to go into the setup menu of the TV itself and increase the audio output. I had been working with the settings on the Cable box...wrong.
    I had to get into the setup of the TV itself...using MENU on the TV's remote, not the DVR remote. Changed the audio output which was set to about 30%
  • 10,594 Answers
Sound output from tv speakers is always depends on input of audio signal like dvd disc has low volume level because of surround sound data etc.
If tv gives low sound in all inputs that means its inbuilt sound amplifier is not so powerful, you need to hook receiver with tv to get tv sound in receiver's external speakers.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Oct 24, 2010
SOURCE:
Vizio vw37l hdtv20a standby light on but wont turn on
you either have a faulty power supply or faulty main board. Vizio power supplies on the older sets are pretty decent. It's usually the main boards that go. These older main boards tend to be pricey so it may be better to buy a new set.
Mar 27, 2013 | Vizio VW37L 37 in. LCD HDTV
Can i replace the screen on my vizio vw37l
yes you can, but in most cases cost to replace the panel could cost as much as a new set. If you decide to replace the panel, you will need to get your LCD panel model # before ordering a replacement. You will have to open your set. There should be a white sticker on the back of your panel stating the model #.
Jan 22, 2013 | Vizio VW37L 37 in. LCD HDTV
I have a vizio model vw37l hdtv 10a, got a hit on front panel that made a small crack which messed up the picture in that area,what part needs replacing?
The set is finished- sets like this use a display panel- it is the entire front screen unit and a sealed unit at that.
Cost of the entire panel unit even if available will cost more than the set did when new ( not counting labor to remove and replace it).
Buy a new set and note all LCD and Plasma like sets have this issue as the display panel is very fragile.
May 25, 2012 | Vizio VW37L 37 in. LCD TV
I want to replace my 37 inch lcd screen, Could I get an and Exact price form some one?
To be kind forget this------the cost even if available is more than a new set.
Mar 17, 2012 | Vizio VW37L 37 in. LCD HDTV
Vizio VW37L no power
Check for bad capacitors in power supply, check voltages coming out of the power supply, if voltages are good, bad main board.. Vizio's are notorious for bad main boards.
Nov 23, 2011 | Vizio VW37L 37 in. LCD HDTV
I have a Vizio 37" TV (VW37L HDTV 10A) bought in
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ ///
Sep 03, 2017 | Vizio VW37L 37 in. LCD TV
My son changed the preset password on my vw37L tv i need to reset it plz help me
Well i just want to start off linking you the link to your tvs manual in case you have lost it
vizio VW37L HDTV20A User Manual
YOUR TVS MANUAL
vizio contact info if im unable to assist.
For assistance, please call (949) 428-2525 or email
us at [email protected]
IF its not the parental password option this will work
Under the Menu
Reset All Settings
Press Down the button to highlight the Reset All Settings selection.
Press Arrow poiting right button to reset the TV to the default factory settings.
Press either the MENU button to return to the previous menu display or the LAST key to return to your
program if task has been completed.
Note: This does NOT reset the Parental Control Password.
Their is no instructions on how to reset this.
Oct 11, 2009 | Vizio VW37L 37 in. LCD HDTV
Low volume even when on 100 on a brand new vizio
Try running the cable straight from the wall into the set and see if it's ok. If not, then I would exchange the set.
Oct 10, 2009 | V, Inc. VIZIO RP56 Rear Projection...
Vizio VW37L
720p & 1080P are what you want, the vizio has a higher repair rate than most, check out the toshiba or the samsung
Jul 17, 2009 | Vizio VW37L 37 in. LCD TV
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
