I have a compaq armada m700 laptop that my dad gave to me as a gift. He said the battery wasn't good anymore but he gave me the power cord and I. Can't seem to turn the laptop on canvsomeone help me.
  • 2,229 Answers
I'm not really sure if the computer can be turned on with a bad battery--if the battery is just dead, it should work. But if the battery has a short in it, that may prevent it from starting.
You can remove the battery and just use the adapter to see if it will work.
You should also check the output voltage of the power adapter (should be about 18 volts).
So--if the adapter puts out the voltage and the computer won't start, it could be the DC adapter on the motherboard or the whole motherboard may be shot.
Posted on Oct 24, 2010
    Guru:
  • 689 Answers
Try pressing the power button down for 5 secs or more,some pc's dont work without the battery fully charged however.
Make sure psu isnt faulty,should "humm"--good luck!
Davey Snake!
6ya staff
SOURCE:
Stuck in standby
Have you held down on the power button for more than 10 seconds to be sure the unit is off?
If not unplug power cord and remove battery if all else fails
Nov 23, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700
Try this: Remove the power adapter and battery from the laptop.
Press and hold the power button for up to one minute to discharge the laptop. Try starting it.
Jun 02, 2008 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
My compaq armada m700 is having problem
this may be because the battery is dead so you may have to keep the charger attaached to the laptop for power. if this does not work then this means that the battery is no longer good so u will need to replace it.
please rate me. thank you,
May 23, 2008 | Compaq Armada M700 Notebook
Battery for Compac Armada M700
Hello Felcen:
It could be just a coincidence...but lets try a few things...
Remove the battery and unplug from the wall. Hold the power button on...and then plug back into power...after 8 seconds release the power button. Once your computer boots to desktop...shut down...and replace the battery.
Changing the harddrive should have anything to do with teh battery...
See if your battery starts charging after this trick.
Let me know and good luck my friend.
Seek PC Repair
Feb 12, 2008 | Compaq Armada M700 Notebook
Compaq armada M700 power on problem
HMMMMMMMMMMM, SOUNDS LIKE SOMEONE NEEDS A INVERTER! YOU CAN BUY ONE OF THESE ONLINE, BUT UNLESS YOU KNOW HOW TO PUT ONE IN DON'T DO IT.
CHECK TO SEE IF THE DISPLAY WORKS BY PLUGGING A VGA CORD FROM YOUR NOTEBOOK TO YOUR MONITOR IF YOUR MONITOR SHOWS WHAT YOUR NOTEBOOK IS DISPLAYING, THEN IT'S YOUR INVERTER.
Dec 17, 2007 | Compaq Armada M700 Motherboard
Compaq armada m 700 was not show battery no go with battery
In ur laptop,U click on Control Panel - Power options.Click on Power meter.There u select the battery show option.
I go for this web address.www.hpfashinontronics.com
U can Laptop skin order through online also.
Oct 31, 2007 | Compaq Armada M700 PIII 700Mhz/ 128MB/ 12-...
Loss of power
this is motherboard problem
Oct 23, 2007 | Compaq Armada M700 Notebook
Compaq Armada M700 Shut Off During Windows XP Pro boot
remove the battery and directly connect to power and see.
Oct 09, 2007 | Compaq Armada M700 Notebook
Battery fully charged, or is it.
Good Day Blunty, It's one of two things, the more likely of the two is that that battery is totaly shot, laptop battery's are usually only good for 1.5 years then loose there ability to retain a charge. It sounds like that one's just done. Unfortunatly that those batterys cost more than there worth, 100 bucks or more. The second possibility is the power cord, is that the original power cord for that? Or was on that was bought aftermaket, some aftermarket chargers will only power your laptop and not charge. Also remove the battery and check for corrison. You can build your own battery fot a a laptop if got a few hours time, and are good with a soldering gun. You get the litium ion cells you need for about 40 bucks. Good Luck L8R
Sep 17, 2007 | Compaq Armada M700 Notebook
Compaq armada m700 power failur...
try removing the large battery and powering off wall supply only...if ok, then replace battery
May 30, 2007 | Compaq Armada M700 Notebook
Open Questions:
Computers & Internet Logo
22 people viewed this question
Ekse
Marvin
Marvin
