Question about LG RUMOR Cellular Phone
When I start my phone it doesn't want to like star. It stays where it says "Rumor Touch" "Please wait.." and the dots don't move, How can I fix that?
    New Friend:
Im having the same problem.
Posted on Oct 25, 2010
SOURCE:
My touch screen on my lg rumor touch phone by sprint stopped working so it doesn't respond yet i can use my keyboard and stuff like making calls and all that. i cant send any messages tho... is th
it's not a battery problem you have please. something has gone wrong with the touchscreen itself and needs to be quickly checked out. if you have an LG service center close to where you work, or live then you can turn it in there. you must be prepared to part with some cash too. they will diagnose the problem easily and even go ahead to get things sorted out with your touch phone.
May 23, 2012 | LG Rumor Touch
I cannot connect to Facebook on my LG Rumor Touch
The service provider you are using is bad.
Nov 17, 2011 | LG Rumor Touch
I droped my lg virgin rumor touch and The touch screen cracked but when I turn it on it stays black. What could I do?
If you won't see anything on screen,check if the phone is booting or turning on,if it turns on,display is probably the problem.but if doesn't power?software problem is the main cause.and with this,need to replace LCD as well as touch screen that was damage too.
If your mobile has a warranty,you can bring it to the service center for spare parts replacement.If you try to open it and it's under warranty,this will void you warranty and unable to benefit free of service charge.
Jun 15, 2011 | LG RUMOR Cellular Phone
Lg rumor touch cell manual
You can download the Sprint LG Rumor Touch manual in this site http://support.sprint.com/global/pdf/user_guides/lg/rumor_touch/rumor_touch_by_lg_ug.pdf
LG Rumor Touch quick start guide: http://support.sprint.com/global/pdf/user_guides/lg/rumor_touch/rumor_touch_by_lg_gsg.pdf
Mar 30, 2011 | Cell Phones
Why does my brand new rumor touch keep restarting itself
You may be able to fix that problem by turning off the phone, then removing the battery. Wait about 30 seconds, insert the battery, and turn on the phone. That should fix the problem.
Mar 05, 2011 | LG Rumor Touch
It wont go past the start up mode. it keeps blinking rumor touch and says please wait. only way to shut it off is to take the battery out.. what can i do. Is there anything i can do???
either you have hads some liquid go inside your fone or the software has crashed. if the software, go to a phoneshop andf get it flashed. will cost around £20
Dec 03, 2010 | LG Rumor Touch
I have a sprint rumor touch and it shut off and is now. Frozen on the start up screen it just says rumor touch please wait and has said this now for about forty minutes
You can get the subsidy code through online..........give your IMEI number and get the subsidy code for ur mobile.... i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Nov 16, 2010 | Cell Phones
My rumor touch wont turn on its stuck on the rumor touch icon screan with the please wait message right before it does turn itself on
First, try to remove the battery and fix it back in then try to turn it on, if it does the same, remove the memory card and try to turn it on again, if it does the same, then the problem is a software problem.
Be sure that you do not have too many files on your phone and have not tried to upgrade the firmware of the phone, if not the phone might be having problems loading the files or might not have the files to power up the phone from either causes respectively. The solution to them is for you to connect the phone to a laptop via its pc suite then try to check all the files you have on it, delete in the case of too many file or move them to your pc, or restore the former firmware if it was upgraded.
Probably the phone have contacted some kind of virus, either from file transfers via bluetooth and other means or from file downloads. There seem to be a corrupt file on the phone.
The solution to that is for you to simply flash your phone with the appropriate software and cable, then your phone will be in good condition once again.
Take care and good luck
Oct 31, 2010 | LG Rumor Touch
LG RUMOR Cellular Phone Logo
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
