Question about Lite On Laars Lite 2 Heaters: 250,000BTU MV Heater
Laars Lite heater not working
I got the pilot light going but but the red flashing light is not lit. Heater is not lighting. Any ideas.
Paul
  • 2 more comments
  • Anonymous Jun 12, 2008
    i have the same problem
  • Anonymous Jun 21, 2008
    Pilot is lit but the gas won't lite the heater. How cxan I adjust pressure or bleed the gas line?
  • pmcinerney Jun 25, 2008
    Laars lite 2 model lg 250 000 btu. The pilot light is on and putting .495 milivolts to gas valve. Pressure switch is closed and all components ring out. The light on the square black module is not flashing. Any ides?
  • dskeen Jul 03, 2008
    No red led light as well. Jumpered around everything and still no ignition. How much milivolts do you need for the system to work? Could it be the pilot generator? Help!!
1st time this happened to me the filter wasn't clean. 2nd time it was the pressure switch and for the third time they say I have to bleed the gas line, not enough gas to lite. And I also need the on/off switch gone bad.
Posted on Jun 15, 2008
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Hi I am unable to get the pilot light to stay lit even though I have replaced the thermocouple on my laars lite 2 heater ?. I checked te voltage on the pilot geneator and it rose from 300 mv to 600 mv but...
I take it you are talking about the powerphile which will give the readings you have , check pilot is not blocked , do the leads from the powerphile go on to the valve with out any other conections in the wire as this will drop the volts and it will not work , check thermocouple is tight and is in the flame from the pilot ,
Jun 30, 2010 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Lite 2 Pool Heater 250,000 BTU / Natural Gas : I HAVEN'T USED THE HEATER FOR TWO YEARS. THE PILOT...
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
May 17, 2010 | Jandy Laars Lite 2 Pool Heater 250,000 BTU...
We have a teledyne gas furnace whose pilot won't stay lit. Any ideas?
Is this a standing pilot,or pilot always on.
If so a bad thermocouple will cause pilot to go out.
Thermocouple is a small copper tube running from the pilot light area to the gas valve. easy to replace.
Jan 14, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 LG - pilot light will not stay lit. As long as you hold down the pilot light once it is lit it stays lit but when I turn the nob to the "on" position (release the pilot light button) the flame...
It sounds like a thermocouple has gone bad. this is a very common problem with gas powered things ie; water heaters, furnaces, hot tubs. The telltale sign is when you release the pilot light button it won't stay lit. This is a safety feature and is relatively inexpensive and easy to repair.
Aug 08, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a natural gas pool heater. When I release
Replace the pilot generator. For a quote on the part, send us your heater make and model using the contact form at www.arrowpools.net
Jul 16, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool Heater Light main burner then goes out
take millivolt reads while main burner is on.i suspect you will see a drop in voltage until you get to point where it will no longer operate burner(around 200mv).if this is the case you probably have poor pilot characteristics due to dirty pilot,pilot out of adjustment ,obstruction or insufficient gas pressure
Jun 21, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Pilot stays lit, but burners underneathe do not light up or burn.
Check pump is working, if so could be stuck flow switch or gas valve fault get unit serviced
Aug 31, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Lite 2 Spa Heater
it might be the hot surface ignitor. a common problem with gas furnaces also. also, check if there is an code on your screen. it will be called an FL code. call the manufacturer.
Aug 05, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Laars Lite 2 Pilot will not light
If you have not found the problem yeat, it IS the thermocoupling( or pilot generator(same thing))
You may test by placing a multimeter on the red and white leads coming to the gas valve. you do not need to disconnect the leads first but you can
Jun 22, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Heating & Cooling Logo
290 people viewed this question
Top Lite On Heating & Cooling Experts
Paul Carew
Michael Galve
Michael Galve
Craig Butler
Craig Butler
Are you a Lite On Heating and Cooling Expert? Answer questions, earn points and help others
