Question about Canon imageRUNNER 1023iF Black and White Copier
The copier is flashing at the "error" light and the screen reads "change reccomended size, common settings" I don't know how to change it
    Sniper:
  • 51 Answers
To change paper size on Drawer 1, Go to Additional Functions > Common Settings > Reg Paper Size > Drawer 1 > Paper Size > (Select the correct paper size) > Press Ok
To change paper size on Stack By-Pass, Go to Additional Functions > Common Settings > By-Pass Std Set > (Select ON) > Paper Size > (Select correct paper size) > Press Ok
Posted on Oct 28, 2010
SOURCE:
Unexpected paper size message
go to the printer preference settings and change the paper size to A4 if you are using A4 and paper type to plain paper. and do the same on the printers settings menu.
Nov 12, 2013 | HP LaserJet 4050n Printer
Says "error" and don't know
If the error light is flashing: Check the front door and the fuser door to be sure that they are closed. Also check for any jam including the duplex section. Make sure there is not a sensor flag stuck in the down position. This can indicate memory full, print overrun, size error DX or duplex disabled.
If the error light is not flashing: it can mean there is no paper in tray 1 or the machine may be asking for you to put paper in the multi purpose tray.
Is this the only light that is on?
Jul 06, 2011 | Brother HL2240D Laser Printer
Don't know how to change paper size on LED screen
what is the model
but at model **3 **6
you can try this:
1- press key drawer & copy together for more 5 seconds
2- when all lamps flashing press {drawer} till the drawer you want to setup
3- then press {copy} till the {other} lamp flashing - "the last one" see the number on the LED screen
4- change the LED screen number "13" to "20" for LT size
Jun 28, 2011 | Toshiba Office Equipment & Supplies
Kyocera Printer is not printing. Error is "Add Paper. Letter"
This is a common error due to many printers set default paper printing size as a letter size, and you don't have it in printer.
You need to set the output paper to the one that you have (I guess it is an A4) in advanced setting on the printer.
Hope this help!
May 20, 2011 | Office Equipment & Supplies
Light under memory/alarm is flashing red. Window
if the error is change paper size also, under printer properties set the paper size i.e. A4, by default its ltr and these can cause problems.After that turn off and on.
Hope that helps.
If not, send more detailed description.
Aug 27, 2010 | Canon imageCLASS D320 Digital Copier
Error Message: load the correct paper cassette: A4
check under printer driver, paper size.Usually the default paper size iz ltr. change it to A4 if you wana print on A4.
Jul 22, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Recently I have gotten a message,
The application you are using is calling for a specific size or type paper in tray 1.
For example, you have "Executive" size paper and the job needs Letter size.
Easiest fix is to make sure your "Page Set-up" matches what you have in Tray.
Failing that, you can also, open tray 1, pull it most of the way out and then push it back in. This will force a re-read of the paper size. Then press the "Green" button.
If it still happens, use the "Print To File" check-box on the Printer Properties screen and then name the print file something like "tray1fail" and send it to me at [email protected] and I'll be happy to run it through some of my file readers and tell you what the print job is looking for. There is no fee or charge for this. I actually enjoy reading print files.
Don
Feb 11, 2010 | Lexmark Optra S 1625 Laser Printer
I have a Canon Image runner 1023. when I print i get the message load paper A4, change reg'd size, common settings. and the error light is flashing
Hi
First check the document you are printing from and make sure the paper settings on the specific document are set correctly.Then check the papersize settings on the driver,go to printers and faxes in controll panel,Right click on the ir driver,select printing properties and the printing prefences,change the papersize to the correct papersize.
then check the papersize settings on the machine under the additional usermode.
Clear the job that is stucked in the memory by pressing the monitior button (diamand with a eye sign)select print and clear the job.
Try printing again.
Nov 17, 2009 | Canon imageRUNNER 1023N Black and White...
Machine trouble
Sir,
To clear the fuser error code, perform the following:
1. Power the machine OFF.
2. Press and hold the STOP key.
3. Power the machine ON. Release STOP after 5 seconds.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 16, 2009 | Konica Minolta Di1610 Copier
Cannot print from Tray 1 in Gestetner 6002
First make sure that the machine is reading/ seeing the paper size of the paper that is in the tray ( select tray 1 from the touch screen and see what the paper size reads). If the machine sees a different size then that in the tray, use the 'user tools' and change the paper for that tray. Also, go into your printer settings on/in your computer and make sure that the proper paper size is selected ( the size that is in the tray you want to print from). If the orientation of the paper size is different from the tray -- will not print and give you the error.
May 06, 2008 | Gestetner - 6002 Digital Imaging System...
Canon imageRUNNER 1023iF Black and White Copier Logo
823 people viewed this question
Clive
Clive
old marine
old marine
Ekse
