Question about Nikon D40x Digital Camera
Has anyone had an issue with the black foam strip inside the camera deteriorating and getting between the upper clear plastic lenses?
    New Friend:
  • 4 Answers
Sorry, Theres no setting to fix that.
Posted on Oct 25, 2010
  • frozenmom485 Oct 25, 2010
    I am fully aware there's not a setting to fix this. I am wondering if anyone else has experienced this problem and if there were any recalls or similar problems others have had, and how they fixed the issue.
SOURCE:
How do I replace the foam padding in my ibm selectric ii typewriter?
The foam was used for sound dampening. Over time, the foam falls apart and can cause problems inside the machine. If it is coming off, we usually remove it with a razor blade. New foam is not available any more. Hope that answers your question.
Sep 01, 2012 | IBM Correcting Selectric Ii Typewriter
My AE1 when I rewind it rips the film yes I pushed the black button on the camera any help?
Like all AE-1's and related models, your camera is gumming up inside as the internal lubricant films are at least 25 years old and are largely dried-out.
The fix is to get the camera to a repair specialist for a CLA service (Clean, Lubricate, Adjust). As a one-off extra cost also get the foam light seals and foam mirror buffer replaced as they'll either be absent by now or will still be turning to a sticky goo. Modern foam is is different material and is will not decay like the old stuff.
A CLA and foam replacement definitely costs more than the residual value of the camera, but they're solidly built and have plenty of cheap high quality lenses so can still achieve results which compare well to even the best modern pro dSLR's. Get the work done and your camera will probably last until 35mm film ceases to be available. Your camera will also withstand conditions which you'd never dare risk a dSLR in.
Mar 24, 2011 | Canon EOS-AE-1 35mm SLR Camera
I have a canon AE-1 35mm camera. When I get film developed some of the pictures have a faint red or some times yellow strip down the middle of the picture. what is the cause?
This is a classic sign of a light leak in the camera. Usually this is caused by the deterioration of the sealing foam on the edges of the back where it closes. Check this foam and see it's condition. If it is sticky or doesn't hold it's shape or is not there at all then you will need to have it replaced. There are kits available for about $20 that you can get to replace the seals yourself or you can take it to a camera shop and they will do it for not too much.
Sep 23, 2010 | Photography
Have had somthing eat the black motion sensor cover on my stealth scouting camera. Looking for a replacement cover
check amazon.com or if you get black foam and cut it into a ring shape you can mount it so that it protects the lense if the lense is lose hope this helps
Mar 04, 2010 | iClick Stealth Cam WD2IR Digital Camera
On my pentax k1000 the black fuzz looking stuff
That's the mirror bumper, it softens the blow and cuts the noise as the mirror flips up.
Carefully remove it and then replace it with a new one. You can get it as part of a foam light seal repair kit for your camera; this also ensures that the sticky black goo which used to be foam and which prevents light from getting past the edges of the camera back gets replaced. Light seal kits are very cheap, and if you buy a pre-cut version then it makes a fiddly job a bit easier and potentially less messy. They're widely available on sites like ebay, just search for "k1000 light seals" and check that the kit includes a mirror bumper/buffer.
If you don't get it repaired the fuzz will get everywhere and can also get onto the film surface causing white spots on your photos or black spots on negatives/slides. The debris can also get into your lenses so remove it asap. Gooey foam light seals are even worse as it's both corrosive and abrasive (due to the grit it attracts) and gradually migrates to gum up the works. It can also result in light fogging on your photos (usually seen as red streaks from the top or bottom of the picture). Modern foam seals do not decompose like the old ones did.
I hope that I've helped you, please take a moment to rate my answer.
Mar 02, 2010 | Pentax K1000 35mm SLR Camera
Small piece of clear white plastic lodged in the viewfinder
Check the mirror in the camera for any debris, or the lens. Sometimes a quick brush off works wonders!
Jun 11, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
The plastic slide @ the bottom of shift lever is deteriorating.
The strip is part of the shifter bezel and should still be available from the dealer. Bezel just pops up and you'll have to remove the shift handle by loosening the set screw.
Feb 20, 2009 | 1994 Chrysler LeBaron
Camera is infared
This is the initial sign of the camera coming loose from the socket on the main board.
If it still in warranty then send it out for repair.
If it's out of the warranty then you can put a foam or plastic spacer to under the battery cover.
Just like the battery foam pad under the battery.
Place few tab of supporting material under the battery cover. Make sure they does not cover the lense or the flash.
Next time the camera give you the error message again or ghost like image.
Take the battery out and press the camera and flash area firmly until you hear a soft plastic snap sound.
Once the camera contacts snap back in place then your are back in business.
Nov 04, 2008 | RIM BlackBerry Pearl 8100
Deterioration of internal components or "o" rings
I tossed the lens out at the recommendation of a local repair shop.
Jun 25, 2008 | Quantaray Tech-10 70-300mm f/4.0-5.6 for...
Fuji FinePix S602 Zoom - Black strip down picture
If you see the black line on your images and it is a very crisp clear line then it is an issue with the cameras image sensor. If the line is less crisp and clear then it may be a more simple of contamination in/on the lens. If the line is crisp and clear and the camera is under warranty get it fixed or replaced. If it is out of warranty look into getting the CCD component replaced at a repair facility. There is an outside chance that it is just the connector which bridges the sensor to the processing board - but that usually manifests all over the image, not just in 1 strip. David Millier Advance Camera Repair
Feb 11, 2007 | Fuji FinePix S602 Zoom Digital Camera
Nikon D40x Digital Camera Logo
19 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
