Question about Acer Aspire One D150-1587 Netbook
Spillage on d150. cleaned as best as poss. will not start without battery. with battery fitted charge light comes on. on power up sometimes get to screen saying press f2 but then nothing else. suspect mother board or keyboard...any help welcome
    Guru:
  • 689 Answers
Spilage hey! I hope it wasnt ministrone soup or nothing too thick and goey,you really must just let it dry out a bit then see what happens.Pressing F2 will or should take you to the bios pages for configuration of boot sequence and other technical data--navigate here with "tab" and arrow keys,save and exit or restore to factory settings etc--good luck!
Davey Snake!
Posted on Oct 24, 2010
SOURCE:
Starting
The battery is undoubtubly defective.
Apr 17, 2014 | Holden Astra Cars & Trucks
Sometimes the car won't start and the dash lights and the radio lights flicker
Best place to start is the positive lead on the battery . Remove the lead and clean battery pole and terminal using sand paper until you have shiny syrfaces. Replace the lead and tighten the terminal . Check the battery for charge condition as what you describe indicates a flat battery
Feb 10, 2013 | Cars & Trucks
Yeah my Trajet won't start,Battery seems fine plenty of power,however when I turn the ignition key there is nothing ,all the dash lights come on by half power sometimes strong sometimes they fade out,all...
Check and possibly clean all connections to the battery(bat clamps/posts)...check to be sure the ground on the block and the body are clean and well connected
Jan 20, 2011 | Hyundai XG350 Cars & Trucks
My 2004 chevy cavalier last week i was leaving the store and the light to pull out of the shopping center my battery light come on and car died. a jump wouldnt start it back up i changed the battery and it...
if the electrical system is not keeping the battery charged you should clean the contacts on the battery terminals and wires and then if that doesn't work your alternator might be fried, its what restores the power to the battery after starting... if the starter won't turn the car over it might need a solenoid or replaced. finally make sure you check the relavent fuses. sometimes the simplest explaination is the best.
Oct 06, 2010 | 2004 Chevrolet Cavalier
1984 D150 truck 318 2brl carb won't turn over...no lights, no hor
I would check your fusible links. The wires that they are on are what power everything in your cab. Usually they're attached to the starter, the starter solenoid, or the positive battery terminal. Hope this helps!
Jan 18, 2010 | 1984 Dodge D150
While on Battery at airport, it went off. Pushed
Try removing the battery from the unit and re-connect.
Do this without the adaptor plugged in.
Next, plug in your a/c adaptor and see if the power light and battery starts to charge.
You may want to try at last resort, after the unit is running without the battery, install you battery and see if the charge light comes up.
Sometimes, just removing the battery and re-installing it cures the problem.
If you do not recv. a charge light and the unit will not start, HP has offered a extended 1 year warranty on top of you the original 1 year warranty.
Contact customer support by email and log your problem.
Hope this info has helped.
Sep 20, 2009 | HP Pavilion dv6000z Notebook
Critical low battery error 190
This sounds like a fail safe in the battery has engaged. See if the machine will start without the battery, on the supply only. If you can get it started then put the battery in and see if it will charge or reset the fail safe. Give it about an hour, then shut it completely down and restart it with the battery in. If it won't start at this point, then you will need a new battery.
Aug 28, 2008 | IBM ThinkPad T20 2647 Notebook
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Acer Aspire One D150-1587 Netbook Logo
57 people viewed this question
Ekse
Alun Cox
