Question about West Bend Kitchen Appliances - Others
Model 41088 the bearing in one shaft on the bread pan has gone-out. Can this be repaired or order new pan?
  • 433 Answers
Hi, It can not be replaced...sorry Hank
Posted on Oct 25, 2010
SOURCE:
West bend bread machine cat# 41088 parts the bread pan
sounds like a new unit will provide you with all that .search west bend website
Nov 26, 2015 | West Bend Kitchen Appliances - Others
Toastmastter breadmachine model 1186. I used it two days ago, worked fine. Today the drive belt will not turn. It makes a small clicking noise. Can you oil the shaft or are the bearing gone?
Hi, Take the bread pan out of the machine and see if it still makes the noise when you start a kneading cycle. If it still makes the noise then the belt may be loose or a gear has chipped. If everything is normal then it could be the bread pan. There is a sealed bearing on the bottom of it and when that breaks or freezes then the paddle won't turn and it's time for a new bread pan Be sure to unplug the machine when checking belts. They are located in the base of the machine. Hank
Jan 24, 2011 | Toastmaster 1183N Bread Maker
Hi, I had all my ingredients in the pan and was bringing it to the machine to begin making bread. When I noticed the liquid was leaking out from the bottom. I had a mess everywhere. Come to find out the...
Hi, The leaking is from the sealed bearing that the paddle shaft rotates on. It wears out over time. It can not be repaired and you will need a new bread pan. Sorry Hank
Nov 23, 2010 | Breadman TR2200C Ultimate Bread Maker
The liquid leaks from the shaft of the bread pan. Upon further investigation, the shaft drops down slightly from it's original position as I can push it back up but it won't stay up. What can I do to fix...
Hi...The paddle shaft fits tightly on a sealed bearing. This allows the shaft to spin freely. Over time the sealed bearing wears out, the shaft gets loose and liquid will leak through. Unfortunately there is no fix for this and a new bread pan is needed. sorry...Hank
Nov 11, 2010 | Cuisinart CBK-200 Bread Maker
I think the bearing that turns the blade in my magic chef breadmachine has gone bad, very stiff turning. Can I get a part for model # VBM200C-1(200)?
find A SIMILAR BEARING ON BERINGS STORE, GO WHIT THE BERING TO THEY, OR READ ON THE BEARING THE NUMBER: EX: 506, 6001, 6201.....ETC,
Feb 14, 2010 | Magic Chef CBM310 Bread Maker
Rotating shaft is jammed (won't move paddle)
Not quite sure what you mean about rotating shaft, but if you take the bread pan out of the machine and try to turn the paddle by hand and it doesn't move, then the sealed bearing in the bread pan is jammed or broken. Try filling it up with warm water and soaking it for a while. If it doesn't budge after a few tries then the bearing is broken and a new bread pan is needed. If on the other hand it does move, keep the pan out and start a kneading cycle. Look through the lid window and check to see if the motor shaft is turning. If not then the belt inside the machine is snapped, or fell off, or the motor is broken. Good Luck...Hank
Dec 01, 2009 | Black & Decker B2250 Bread Machine
The driveshaft falls out of the pan, even with paddle attached
The shaft is pressed into a bearing that is molded and stamped in the bottom of the pan. This bearing is sealed and allows the shaft and paddle to spin freely. The rest of the parts on the other end of the shaft interact with the motor on your machine. They do wear out and can not be repaired because the worn parts are not available individually.
Sorry to say there are no repairable parts, so it's time for a new bread pan. I don't know the brand of your machine so you can google or check ebay.
Hank
Sep 02, 2009 | West Bend 41052 Bread & Dough Maker
Shaft won't turn.
The bearing that lets your paddle turn freely has frozen up. The bearing is lubricated and sealed at the factory, but as time goes by it freezes up.
One person suggested to soak it overnight in soapy water (warm) and try turning it by hand. If you are lucky this may work, or if not, a new bread pan is necessary.
Hank
Aug 31, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Kitchen Appliances - Others Logo
44 people viewed this question
Top West Bend Kitchen Appliances - Others Experts
Ekse
Irene Tulloch
kltcoco
Level 1 Expert
Are you a West Bend Kitchen Appliances - Other Expert? Answer questions, earn points and help others
