Question about HP Photosmart C5180 All-In-One InkJet Printer
C5280 I was printing wedding invitations...thick card stock...it was working fine until the printer started to display error message that the paper is loaded face down...now I can't seem to get the printer to print the thicker paper...is there a way to set the printer settings for thicker paper?
    Scholar:
  • 71 Answers
When you hit 'PRINT' the window that opens up to complete the job will have a button called 'preferences'. Check to see that the paper selected isn't photo paper. You will have you choice of paper type thickness and size.
Posted on Jun 13, 2008
What are the custom wedding invitations is it worth paying?
hi
Wedding cards are the most important thing to consider when planning for inviting the guest to wedding functions. It solely decides whether the guests attending the function or not. these designer wedding invitation cards show your gratitude for them and importance of their presence in the function. custom designed invitations also come with the special quotes printed on them they are more effective then a normal wedding invitation. Last month my uncle ordered Wedding Invitations Card by Lavender Paperie.
They are most beautiful ones i ever saw. the design is so clean and beautiful with special message make it more attractive. Wedding Invitations Custom Laser Cut and Lace Wedding Invitations
Oct 21, 2017 | The Office Equipment & Supplies
HP Photosmart Premium c309a series smudging wedding invitation envelopes badly. I can print the invitations and everything else just fine. Any suggestions? Thank you.
when you go to print your envelope and click the print command - a window will open with the name of your printer and a box that says properties. click on properties. Change the type of envelope stock to match what you are printing on in the next window. If you are using photo paper envelope with a glossy finish, make sure that is the print media you have set for your printer. If not, the ink will just keep smudging. it's very important to match the print stock (matte, glossy, premium ect).
Oct 09, 2011 | HP Photosmart Premium C309A All-In-One...
I'm trying to print wedding invitations on my Canon MP460. I'm using a cardstock thickness of paper and have set the ink levels for "Other Photo Paper" on my Mac. The paper has been going through...
Sounds like the ink isn't having time to dry and is rubbing along paper.
Paper may be too thick. If it prints OK on normal paper (test first) but not on thick card, then it doesn't support thick paper settings.
Jan 31, 2011 | Canon PIXMA MP460 All-In-One InkJet...
Problem printing on thicker paper
The error that you are getting is telling you that the paper size or type you picked in setup is not what the printer is detecting. Once you verify that you did choose the right type & size, the next thing to check is to make sure the paper path is clear. If a piece of paper is covering a sensor this might cause the message to appear. If you don't see anything in the way, take a can of compressed air and blow out the path.
Jul 26, 2009 | HP Photosmart C5280 InkJet Printer
Printer won't accept Card Stock
Nothing to adjust feed mechanics. If it's temporaly print, you must feeed paper 1 by 1, and when printer grab paper, push paper by hand. If it's routine print, you can adjust the pick up rubber at paper feedr mechanic. Add double tape ( 1 mm, soft) below top rubber. I have done it, and printer can grab/feed paper up to 350 grams.
Jun 29, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Paper size mismatch - c5280 hp all-in-one printer
I got around this problem by tricking the printer. The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job. What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job. Here is the tricky part... one the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11 I hope this helps.
Deny When the 8.5x11
Jun 03, 2009 | HP Photosmart C5180 All-In-One InkJet...
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
Printing heavy weight invitation stock on Epson R200
The card is probably too thick. Try cleaning the feed roller in the Sheet feeder to improve its grip. Check the GSM of the paper is within the spec of the printer.
Nov 03, 2008 | Epson Stylus Photo R220 InkJet Printer
Paper mismatch
Hi kingwa55,
I have an hp photosmart c4480 and was having the same problem printing wedding invitations. Same size 5.5"x8.5'. Im not sure if this will work on your printer, but this is what I had to do.
Click on Print, then Properties, then features.
About half way down there is a drop down box under sizing options.
Click on custom
Create a name, and put your width and height in.
Click Save and then OK
Completely X out of the print options.
Then Click
File, print, properties,features, click the drop down box under sizing options.
Click more and scroll to the bottom and it should be there.
If your options are different then mine, I'm sorry for wasting your time.
Apr 23, 2008 | HP Officejet 6310 All-In-One InkJet...
HP Photosmart C5180 All-In-One InkJet Printer Logo
504 people viewed this question
Seeker5211
Seeker5211
