Question about Celestron NexStar 8i (600 x 203mm) Telescope
HI, Just purchased a nextstar 8 and when I tried to view thru the main eye-piece, nothing. Even tried to look at the full moon, nothing again. Yes, all the lens caps are off but it seems like the focas knob is'nt doing anything. I started out with a meade 4" telescope and jumped at the chance to buy this bigger scope. It has the gps and 7x50 finder scope with red cross hairs. It came from Colorado so maybe it got knocked out of wack in shipping. Is there anything I can do or try here ? I'm handy around the house and would like to fix this myself, if it's not to hard. Thanks, Chris
  • 3,186 Answers
Check the focus knob and make sure the small "set-screw" is tight and the knob is just not spinning around on the shaft.
DID you turn the knob enough to focus? Sometimes it may take 10 - 20 full turns.
Finally the focuser is attached to a "rod" inside the tube that moves the mirror back and forth to focus the scope. It could have come loose from the rod?
Instructions for disassembly are here:
http://www.celestron.com/c3/support3/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=2220
and here:
http://www.sciencecenter.net/hutech/misc/focuslk/index.htm this just shows how it works.
Posted on Oct 25, 2010
SOURCE:
Cannot see anything thru telescope even daytime
  1. Get Stellarium or another fine astronomy program
  2. During the day, point the telescope at a part of the landscape about 100 yards away.
  3. Use the lowest power eyepiece (highest number) in the focal tube.
  4. Center the landscape object in the telescope.
  5. Align the finder scope so that it points exactly where the main telescope is.
  6. At night, leave the scope out to reach thermal equilibrium (about an hour for small reflectors and refractors)
  7. If the scope is on a EQ mount, polar align.
  8. Point the finder at the moon. The moon should be in the main scope also.
  9. Practice finding the moon before you start on the planets
  10. Once you are comfortable with the moon and planets, you can go for the deep sky objects
Sep 10, 2014 | Galileo FS-102MOH Telescope
I can't see through the eye piece! The finderscope has been adjusted to view the moon but when I looked through the eye piece I could only see black :( its a tasco galaxsee 45-076280
Align the finder to the main scope during the day before using it at night. Use the lowest power (biggest number) eyepiece first.
Mar 10, 2014 | Optics
Jessops 600-50 Junior Astronomical Telescope instructions
try not looking so closely into the eye piece. back off a few inches so the moon is completely in view.
Jan 11, 2012 | Optics
The only object i tried so far is the moon. No matter which eyepiece I used viewing object was always blurry. With 25mm you can tell it is moon but much worst than with ***** eye. With 12.5mm or 4mm you...
This is a VERY small 50mm telescope, the same size as a pair of 10x50mm binoculars. It really is too small to use for Astronomy. These are usually used as simply a display piece or to look at objects on the ground a long way off. ONLY the 25mm eyepiece will be useful-- the others have too much magnification for this very small aperture scope.
Sorry.
Sep 10, 2011 | Tasco 350x50mm Refractor Novice Telescopes
Problem viewing planets using 25mm eye piece. which eye piece works the best? nextstar 80 slt
The smaller the number on the eyepiece the greater the magnification-- the maximum magnification of any telescope is about 50 times aperture. You scope is about 3 inches -- so 150 power is the maximum usable magnification.
BUT-- only under perfect conditions -- perfect sky-- perfect optics -- perfect eyepieces. Usually 30-40 times aperture is all you will get on a typical night with some turbulence in the atmosphere.
Read my tips on my profile page and listen to my podcasts at :
www.telescopeman.us
May 13, 2011 | Celestron NexStar 80 SLT Telescopes 22086...
Hi, a few days back I purchased Nexstar 4SE. I set it up exactly how it says in the manual still I cannot see any magnifying views from the eye piece. While aligning the telescope I can find the moon from...
Stars will always appear as points. It is not possible to magnify them enough to see them as disks because they are all extremely far away. A telescope will however show you stars and other objects that are too dim to see with the naked eye.
You will be able to see the planets as disks, and even features on the planets, such as the bands on Jupiter, the rings of Saturn and the phases of Venus, and also moons around some planets. There are other objects that will show more detail when magnified, such as nebula. You will be able to see a lot of craters and other detail on the Moon.
Your problem is simply that you are not pointing the telescope at these objects. This seems to be one of those telescopes that "automatically" finds objects, but these so called "go to" scopes only do this when they are set up properly. I can't say what step(s) you have missed, but clearly even if the scope thinks it is pointed at the moon, if you can't see the moon, it is NOT pointed there. The Moon will fill the field of view even with the least powerful eyepiece. If you are seeing stars as points, then the eyepiece is focussed and working properly.
Jan 13, 2011 | Celestron NexStar 4 SE Telescope
I cannot sight anything even the moon
The likely hood is, that the scope needs collimating.
If you don't have a collimator, you can easily purchase one, online.
I discovered the same problem with my scope, until I collimated it.
There are many different types available, 'Red Dot' lasers, or just simply a pin hole in a eye piece fitment.
The 'catseye', is the one I got.
It may seem a little complicated at first, but after you have figured it all out works, it will become clear, and once you've collimated for the first time, it takes no time at all to re-collimate.
There ya go, fixedYa!
P.s, don't forget to give a good thumbs up thankyou :)
Jul 29, 2009 | Celestron PowerSeeker 114 EQ Telescope
I cant see. am i putting it together wrong. the instructions
If your telescope looks like the picture, first put the "L" shaped diagonal into the telescope, and then the eyepiece with the LARGEST number on it.
Go outside during the day and practice focusing on a distant object. Your first night time target should be the moon when it is less the 3/4 full.
Apr 14, 2009 | Barska Optics Barska AE10096 - 80060, 600x...
CELESTRON 127EQ faulty magnification
It won't increase viewing power by hundreds of time but it should be able to show you a close up view of the moon and planets where they look closer (or with the moon, parts of it look closer). When you say it looks further away, something is quite wrong as you know. It sounds like the eye piece is backwards in the mount? Can't imagine what else would make it smaller. Also can't imagine you could even get it in backwards. I have a scope by Meade that is essentially the same Newtonian design. Best of luck.
Dec 31, 2008 | Celestron PowerSeeker 114 EQ Telescope
Eye pieces
I'm surprised it did not come with the 20mm eyepiece. That is a good all-around eyepiece that works well for viewing across the bay or looking at the Moon. You may also want to get a barlow to "right" the Earth based images.
I recommend purchasing a 20mm eyepiece for your viewing pleasure. I hope this FixesYa!
Aug 19, 2008 | Vivitar (1607225) Telescope
Celestron NexStar 8i (600 x 203mm) Telescope Logo
149 people viewed this question
Top Celestron Optics Experts
Ekse
Bob Peloquin
Level 1 Expert
Vernon Taylor
Are you a Celestron Optic Expert? Answer questions, earn points and help others
