Question about LG C2000 Cellular Phone
Unlock I accidentally changed the nam for my phone and the phone rebooted to my un activated number. I do not know the last 4 numbers of that nam. and my settings are to lock on power up.
  • Anonymous Mar 23, 2014
    Erase my number from nam
  • 29 Answers
Just press 2945#*# the factory reset.
Posted on Jun 10, 2008
I forgot the unlock case to my lg vx9800 does anyone know of a master unlock code or a way to reset it
It may have a master reset under settings..just toggle through all the options until you find master reset... the universal codes are usually the last 4 digits of the phone number or 0000 or 000000. If the phone was someone elses and u dont know the prior phone number, look under phone info or the NAM.
Mar 11, 2013 | Cell Phones
When you change your setting to nam 2 how do you unlock your phone
Go to the keypad, type #43574357* (this number should work) and select system info, and it will display your nam2 phone number on the first (top) row labeled "MDN." The last four numbers is your passcode.This solution ONLY works if you've accidentally set your phone to NAM2 (which means that you've reprogrammed your phone to a completely different phone number, and if you've set up a passcode, that too is changed). Once you've found out your new number and passcode, you are not yet finished, because your phone is still programmed to NAM2. To fix that, you must go to your "Phone settings" and find "NAM select." Then you select NAM1 (and your phone will restart again and prompt you with your OLD passcode, if you set up one). Your phone is now fully functioning again!
Apr 19, 2012 | Samsung Brightside U380 Smartphone Verizon
Changes NAM Settings?
Here's some ideas for unlock codes, most phones use the last 4 or possibly 7 digits of the phone number, 4 or 5 - 0's or 12345.
Basically your NAM settings contain the phone number info for a carrier, and you can put two different numbers in the same phone using NAM1 and NAM2, what you have done is switch it to an empty NAM so it is asking for the rest of the programming info to set it up.If you can switch it back to NAM1 it should work again. Most phones have an option in the menu for phone settings that allows NAM switching without needing a code.
Aug 30, 2009 | Cell Phones
Please find my motorola security code
To enter the secret menu mode: flip open phone and quickly enter: #073887* then enter your Security Code (default is 000000). It has menu items Web Sessions, Browser Reset, User Activation, AKEY, Extended NAM, Vcode, Data Rates, SPC Overwrite, System ID, SID/NID Pair, Test Mode, and Get It Now Config. Note: to get out of test mode (white background and blue text), press CLR then left soft key quickly. User Activation
To enter the secret menu mode: flip open phone and quickly enter: 74663#[CLR][CLR]. You will see the "User Activation" menu and have two items listed: NAM 1 and NAM 2.
Enter Operator Codes
TODO: 3/30/2006 - Find if this is available on the VZW Phone.
Jul 15, 2009 | Motorola Mobility RAZR V3m Cellular Phone
I have a sch U740 samsung phone nam 1 code
The lock code should be the last 4 digits of your phone number or 0000.
If that doesn't work, perform an activation by dialing *228 send. Then select option 1. After this is complete your phone's lock code should be reset to the last 4 digits of your phone number.
Jul 09, 2009 | Samsung SCH-u740 Cellular Phone
I DON'T know what is initial programming is?
initial programming occurs when your phone needs a second roaming based and if you accidentally change the NAM settings of your phone to NAM2. the default NAM settings of your phone is NAM1.
Jul 01, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Can't unlock Samsung Hue?
samsung hue r500 and having problem when accidentally or curiously selected nam2.. after it powers off then on again by itself, it brings u to a little window (initial programming needed) and the enter code (password). as you will notice none of your 4 digit passwords will work, default wont work, u have to push the back or end call button to get away from the enter code window. enter ##626# and hit send button. it will bring u to option to select nam1 or nam2, select nam1.. go to next screen, enter in the sdc code which is 000000, (6 zeros), enter or next screen, make sure that mid is same as ur cell number, go to next screen, it will show ur number again, next screen, will be sid and nid numbers... they are what they should be, go next screen, then i think there is option to be done, view, edit choose done, next screen then it will program by itself. powering on then off, bringing u back to same screen with the same window of initial programming needed, just go to enter code, and enter the last 4 of your cell number, and it will let u through,.. just remember to go back in to your phone options menu and change the nam setting in there back to nam1 also. then it will power off and on again. program should be complete... you can always also dial *228 and option 2 to reprogram your phone again to make sure.
hahah
May 08, 2009 | Samsung Hue (SCH-r500) Cellular Phone
Forgot unlock code
the unlock code is originally the last 4 digits of your phone number. so if a phone number is 555-8743. that means my unlock code is 8743. Hope this helps. If you have already changed the unlock code...then go to a store from you service provider.
Jun 07, 2008 | Verizon Communications LG enV Cell Phone -...
Casio gzone
i set my boulder to nam2 on accident and my code didnt work after searchin for like 4 months on the internet i found this code ##7764726 (PROGRAM), SEND. SPC Enter 000000 after u enter it go to the nam settings select nam2 go to the second one its like MDN or somethin like that the last four digits should unlock it but u might have to take it to the store to get it programmed again but ull have ur phone back without losin any info u mightve saved on it
Dec 05, 2007 | Casio G''zOne Type S Cellular Phone
LG C2000 Cellular Phone Logo
63 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
