Question about Arcade Raw Thrills Big Buck Hunter Pro Video
How do you calibrate the gun on big buck hunter
4 Suggested Answers
SOURCE:
  • 5 Answers
SOURCE: Big Buck Hunter Pro Arcade game - gun no longer shoots.
Put the game into switch test mode and press the trigger on the n/w gun. If it doesn't register you need to dissassemble the gun as the trigger microswitch has probably failed. You'll need an adapter to remove several security screws. Separate the two halves of the gun carefully as there are springs and other parts that can become displaced and lost. Remove and renew the microswitch adjacent to the trigger. It is a low rolling resistance switch manufactured by Cherry. If you have trouble sourcing one, the same switch is used as a trough switch in modern Stern Pinball machines. You may have to shorten the contact legs on the switch to get it to fit. With care this job can be undertaken by any competent person with intermediate soldering skills.
Posted on Jul 30, 2010
SOURCE: the triger of my gun
Me too! Can't find one, though.
Posted on Dec 27, 2010
SOURCE: i have the big buck
I'm having the same problem. I found that if I put the LED box on TOP of the TV, it will recognize the first target, but not the second or subsequent targets.
It looks to me like this will only work with a smaller TV. The angles seem too large on a big screen TV. I've contacted the manufacturer to see if my guess is right.
Posted on Jan 01, 2011
Need dongle for big buck hunter pro as the one I have is damaged
If it is a wireless dongle, chances are you will have to buy another gun altogether as it's signal is generally programmed to it's specific dongle, much like a remote to a TV, or a mouse/keyboard to their dongles. They do this so multiple devices can communicate within the same space without interference, but the problem is it becomes near impossible to replace it without buying the entire device if a part becomes lost/damaged.
Feb 23, 2017 | Buck Computers & Internet
How to replace a arcade Big Buck Hunter Pro TV?
If your game has a CRT monitor you will have to stay with a CRT. You can get a great picture from an LCD or LED unit but the guns won't work.
May 07, 2014 | Video Game Consoles & Games
Bad gun boards trying to trouble shoot big buck pro gun boards
after open the gun check also the coil or coils in the target if it is open your gun will no work even if the switch's work properly
Nov 27, 2013 | Arcade Raw Thrills Big Buck Hunter Pro...
I have the big buck hunter pro for my tv, ive tried to do the shootgun calibration from multiple tvs and stood as far back as possible and it still wont calibrate, the menu button will not work either
Dec 25, 2010 | Arcade Raw Thrills Big Buck Hunter Pro...
I've lost the instruction manual. How do I set the game up?
Press the test switch inside the coin door. This gives access to the operator menus. Use the start buttons, gun triggers and gun pump handles to move through the menus and select options. It's pretty intuitive once you get in there. First thing is to calibrate the guns, which the game leads you through once you access the relevant menu option.
Jun 14, 2010 | Arcade Raw Thrills Big Buck Hunter Pro...
just curious if you still have that broken gun? I am a sculptor in MN and making a piece that i wanted to put a lazor into a broken big buck hunter gun to shoot up at a sensor on a deer which would make it wink at you. thats the plan atleast trying to find a gun. thanks kari
Nov 25, 2009 | Arcade Raw Thrills Big Buck Hunter Pro...
Arcade Raw Thrills Big Buck Hunter Pro Video Logo
1,044 people viewed this question
Top Arcade Toys Experts
jasbo
jasbo
ray gallant
ray gallant
Demonic-2011
Demonic-2011
Are you an Arcade Toy Expert? Answer questions, earn points and help others
