Question about Karcher Garden
What oil or gear lube goes in the pump howsing
    Scholar:
  • 100 Answers
It takes a 15w40*1, see attached link to read more
Posted on Oct 25, 2010
SOURCE:
What gearbox oil do I use formy 115 marener
Gear lube part # 92-858064Q01 is (32 fl oz) plastic bottle Quicksilver Branded, (Try Rechecking your wal-mart for Quicksilver part number 92-858064Q01). Or if you want a lot more oil, there is Part # 92-858065Q01 is 9.46 L (2.5 US gal) plastic bottle Quicksilver Branded.This SAE 90 gear lube features improved emulsifiers to help protect gears should water enter the gear housing and tackifiers to improve oil film adhesion to gears and internal components. There are extra additives to protect gears from metal to metal contact and excessive wear. Quicksilver High Performance Gear Lube is recommended for use in
outboards, Jet Pumps and Sport Jets above 75HP and for all sterndrives
Feb 04, 2015 | Cars & Trucks
What kind of lube goes in gear box on a 2005 honda cr85r
If you have a 2 stroke engine this requires SAE 80W/85W gearbox oil about .55 liters. If yours is a 4 stroker then 10W40 lubes the whole engine and gearbox. You can get a user manual online easily for this bike at owners.honda.com
Sep 13, 2014 | Motorcycles
How many Lube pumps are there & & how do they are helpful for industrial purposes?
There are two types of pump lube, oils and greases, have some plus and negative points; grease can only be used in places which are only required to be smooth but the oils are used in situation where you also need performance. Know more about them at, : http://www.fdjohnson.com/ Home FDJohnson
Jul 19, 2014 | Lincoln Lubrication 1293 Hand Operated...
I resently replaced my inner primary with a belt since then i still have problems oil leaking from my primary i shut down all my oilers but i still have a large access of oil leakage
Are you sure it's oil and not gear lube?
Sometimes the seal behind the transmission drive sprocket/pulley goes bad. (I had this problem myself)
Next up could be a seal behind the engine crankshaft sprocket/pulley.
Finally if you have an oil line from the oil pump to lube the primary chain (which you no longer have), remove/plug the line.
Jan 09, 2014 | Harley Davidson Motorcycles
I have a Coleman 2200 6hp green tochemsa engine pressure washer and wanted to know what type of oil is used in the water pump? PLEASE LET ME KNOW.
The recommended oil is determined by the pump manufacturer (usually different from the engine), but most of the "consumer grade" pressure washers say you never need to change the pump oil. Maybe they figure something else will break before it needs new pump oil?
The little jugs of pump oil at home improvement stores are usually SAE 30W (non-detergent) crankcase oil. 75W90 gear oil seems like a better choice; I personally use synthetic marine lower unit gear lube in my pressure washer pump. It's a little more expensive, but I think the formulation gives better moisture resistance. Besides, the pump takes a fairly small amount, and I don't change it very often at all.
Bottom line- you almost certainly want non-detergent oil, around 30W crankcase/80W gear (since they use different scales, these are just about the same viscosity). Synthetics seem to be higher quality, and using marine grade lube gives me peace of mind.
The pump oil matrix here is illustrative- note the many substitutions allowed. The specific oil you choose probably doesn't make much difference, especially compared to never changing it.
Jul 16, 2011 | Coleman Garden
What weight oil goes into the gear box? whats the proper weight oil for the motor?
30 weigh oiltdetergent (if available,if not regular 30 weight oil will perform also), as for the gearbox.transaxle for the tines use 80-90 weight gear lube
Apr 16, 2011 | Troy-Bilt Pony Garden Tiller
The correct oil to use is going to be a 15w40*1, this is a special oil that is made by Karcher, any other oil is going to breakdown much faster and will cause the bearings and wobble plate to not be properly lubed. See link to purchase oil or read more.
Oct 24, 2010 | Honda Karcher G2400HH-R Pressure Washer
How much chan lubricant should be used and what is the grade of the oil
You want to buy Bar grade oil, it is sticky and stays on the chain, it will properly lube the bar and chain with a full tank o gas. People have used, used motor oil but this wears down the chain and gears from the micro sized filings in the oil so use clean bar oil to lube the chain correctly. also if the chain sprocket has a small hole in the tip of the saw you will need to buy a gear lube pump to keep grease in the gear at the tip of the blade. This should be lube each time you fill the fuel tank and once half way threw the tank of fuel to make the bar last longer. The bar oil is a special grade of oil and requires bar oil for it to adhere to the bar and the bar guides. Hope this helps and thanks for using fix-ya.
Jun 13, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Need to put lube for clutch in and I don't know where it goes
Manuel Transaxle uses API GL-5 Hypoid Gear Oil
for Loyale as follows:
SAE90 - Above 30F
SAE85 - Below 30F
SAE80 - Below 0F
degrees Farinheit
Apr 02, 2009 | 1992 Subaru Loyale
Garden Logo
151 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
