Question about SMC SoHoware ND4205 Networking Hub
What does the Normal Cascade switch do? - SMC SoHoware ND4205 Networking Hub
I have Whirlpool WDT720PADM I bought this year 2017 (2 months old). Dishes are coming out clean but slimy when touched.
sorry but FIXYA has no fix for this . check with the manufacturer's website and tech support
Nov 30, 2017 | Whirlpool Dishwashers
How can we cascade two switches
cascade? or connect? easy connect the internet in 1 switch and from that 1 connect it to the bottom
Jul 25, 2014 | Cisco Small Business 100 Series Unmanaged...
Can I cascade multiple HDMI Matrix Switchers?
HDMI is a high bandwidth digital signal and you cannot cascade multiple HDMI Matrix units. It will degrade the video quality and you might run into EDID and HDCP issues. For further queries visit KVMSwitchTech or Call at 866-865-7737 (TOLL FREE).
Jul 10, 2013 | Computers & Internet
Rotten smell.used cleaning products. still smells
I had the same problem. I was using Cascade packs (don't remember which kind) and it was moderate. Switched to Finish gel packs and it got really bad.
My husband has a very sensitive nose and he mentionned that there was detergent smell mixed with the rotten smell. He suggested switching back to the good old powder (Cascade).
After 1 wash it was much better and after 2 washes, the smell went away completely.
Hope this helps!
Jul 20, 2011 | Frigidaire FGHD2433KF Builtin Dishwasher
Detergent sticks in main wash compartment. We use cascade complete with bleach (hydroclean action). When this problem started, I switched to cascade complete (liquid) and still same thing happens. The...
Jsmarquez, We would like to inquire further about your post with you. Please respond back to this email address [email protected] with your name, user id (Jsmarquez), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 25, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap not disolving
is it liquid or powder? we had this problem with cascade powder.... tried liquid cascade and the same thing happened even though i'd been using cascade for YEARS.... manual said could be detergent was "old" and beyond its shelf-life, or that we used too much or too little (go figure that one out LOL).... not trying to promote a brand here, but we switched to palmolive ECO gel and haven't had a problem since -- no goop left in dispenser!.... hope that helps... -cynthia :)
Apr 17, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Washer seems normal....dishes and inside of washer are stained and not clean. Using the same bottle of soap that we have been.
What is the manufacturer and model number of your dishwasher? Approximately how many years old is it?
Recommend two things:
1.) Switch to a brand name powder (like Electrosol or Cascade)
2.) Check (or have checked) the heating element in your DW. That will almost certainly fix your problem, unless your pump/impeller is being blocked by debris.
Good Luck!
Apr 01, 2009 | Dishwashers
Model GU2700XTS81 purchased a few months ago. Dishes come out with chalky white film on them. I am currently using Palmolive Eco liquid and Cascade Crystal clear rinse. At first I thought I might be...
Switch your detergent to Cascade powder. Then use Dishwasher Magic (or something similar) to remove the lime/scale build up and to clean out your pump.
SG
Mar 27, 2009 | Whirlpool Dishwashers
Dishwasher leaves soap in dispenser.
Hi Dirty Dish gang.
After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
So, here is what we need to do:
1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
If you are still having problems:
Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
So far it seems to be working.  Good luck.
Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
SMC SoHoware ND4205 Networking Hub Logo
125 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Jeffrey Groves
Jeffrey Groves
Kris
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
