Question about Sansui CDVD9000
Cd player won't open - Sansui CDVD9000
    President:
  • 2,047 Answers
Usually when the CD player does not open it is as a result of a disturbance or discrepancy in the disc tray mechanism. Best way out is to open the unit and examine the mechanism to adjust any discrepancy there. But it is adviced that such should be refered to an expert unless you have previous experience.
Hope this solution has been helpful?
Posted on Oct 24, 2010
  • 1,662 Answers
The drawers on many CD players are belt driven. The belt may have gone bad. Others have a gear drive with a clutch plate that slips if the mechanism is overloaded. An excess of dirt or dust in the gears would be an overload. (The worst case I ever saw was a CD player in a woodworking shop. I had to clean out a lot of very fine sawdust from the plastic gears and lube them with paste wax before it would work.)
Caution: avoid looking into the CD laser lens when you have the unit plugged in. Even though you can't see the beam, it can burn a hole in the retina of your eye, leaving a possibly permanent blind spot. When I work on a problem like this, I turn the drawer motor pulley or gear by hand to test the mechanism so I don't need power. That way I can feel any drag or catch points that need to be addressed. Once it works manually, I avoid putting my face over the unit while I apply power for a pre-closure test.
SOURCE:
How do i get my cd to eject
What make and model player?
Apr 10, 2013 | Audio Players & Recorders
One of the cd trays came out and won't go in it reads d2 open it won't take the other 4 in or out
Its a complex unit you have to get a service tech it is jamming all work or none work. That is the way it was built
Apr 02, 2013 | Audio Players & Recorders
CD player won't open or power off.
The CD may be stuck inside or the tray mechanism may have failed
Dec 08, 2012 | Audio Players & Recorders
Cd player won't open and won't power off.
This means that something in the mechanism is jammed. It keeps on trying to correct for the misalignment- a service technician will need to see the unit.
Dec 08, 2012 | JVC XL-FZ258BK 5-Disc CD Changer
JVC xl-fz258 won't open to eject cd, won't play
The basic problem is that the drive mechanism has failed. The problem with CD ejection can be caused by binding in the tray or a weakened ejection motor
Dec 02, 2012 | JVC XL-FZ258
The door won't stay open when putting in a cd on my Technics SL-PG350
JUust get a different CD- Player ,It will cost you less then to have it repaired, WHere i live i can get a good used one for $10 to $30 at the most, End they are not hot,
Nov 25, 2012 | Technics SL-PG350 CD Player
CD Player Won't open
There are a few reasons, a broken loading belt, jammed gears, or the timing is out of sync causing the system to lock up.
Mar 20, 2012 | Panasonic SCPM29 5-Disc CD Changer
Two cd in same slot won't eject
Try disconnecting the CD player from power,press and hold the open button and the connect and turn player on.Release button after it indicates open on the on player.Tap the top part of the player with your palm while pressing open button.
Hope this helps.Thanks!
Oct 16, 2011 | Audio Players & Recorders
Sansui CDVD9000 Logo
66 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
