Question about Amana Dryers
Ignitor glows gas valve opens, burns for a while then gas valve closes and ignitor cycles , if dryer is off a while it will light again. amana
  • Amana Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 28, 2010
SOURCE:
Ignitor glows but short cycles
Ignitors don't "blow flames". But a defective ignitor can glow but not draw enough current to allow the gas valve to open to the burners.
Replace the ignitor. It's the "weakest link" and most likely part to wear out through use in the ignition system.
Sep 19, 2012 | Amana NGD5200TQ Dryer
Dryer is not heating up it runs does the ignitor heat up before gas valve opens because the ignitor never heats up
On my gas appliances, either there is a pilot light or the ignitor sparks (like a car spark plug) or glows after the gas valve opens. The ignitor does not heat up.
I've had some gas appliances that have had the valve stick. (On an oven, we tested this by tapping on the valve when the unit should have called for gas. This confirmed that the valve was bad and not the thermostat.)
I hope this helps.
Dec 07, 2010 | Amana NDG7800AW Gas Dryer
I have an Amana LG4319w/l2 gas dryer converted to Lp gas. The ignitor comes on but will not ignite the gas. Theis happened before and the technician replaced the ignitor and said the ignitor must dray a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 11, 2010 | Amana Dryers
I have an Amana Dryer Model # LGD20AW and when the dryer is first turned on the glow plug will heat up and ignite the gas but as the dry cycle continues the glow plug will heat up but no flame will ignite...
The glow coil or glow bar heats up and a sensor on the side reacts to the heat and then sends a signal to a gas valve.(solenoid valve) When the gas doesn't ignite when the coil is glowing... here are some reasons. 1. The sensor on the side of the burner assembly isn't working or sending power to the valve. 2. The valve is getting power but not opening. 3. The ignitor is not glowing hot enough to activate the flame sensor. Usually it is the sensor or the igniter not the valve.
Tom
Aug 10, 2010 | Amana Dryers
Maytag dryer runs but doesn't heat up
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 05, 2009 | Maytag PYE2300AY Electric Dryer
Dryer start up fine then the gas turns off as ignitor continues
Hi Jim. Perhaps this will help you.
The burner assembly consists of the gas valve, the igniter and sensor, and the thermostats. The gas supplied to the appliance is turned on and off by the gas valve, as follows:
  • First--when you close the dryer door, set the timer, and press or turn the Start button--the motor starts. When it reaches full speed (in about a second) a switch on the motor turns on, which allows the electricity to flow through a simple thermostat to one side of the gas valve.
  • The gas valve then sends power to the igniter, which glows bright orange.
  • As heat and light from the igniter warm up a sensor that's right next to the igniter, the sensor circuit opens, then supplies power to the other side of the gas valve. This completes the circuit and opens the valve.
  • Once the valve opens, the gas rushes out and the igniter ignites it. As the gas burns, it keeps the sensor warm, which keeps the gas flowing.
  • When the dryer reaches the pre-set drying temperature, a simple thermostat turns off the flow of electricity to the gas valve and therefore turns off the gas.
  • When the temperature in the dryer falls about 20 to 30 degrees, the thermostat again allows the electricity to flow through to the gas valve, and the cycle starts over.
If you selected the Automatic setting, the cycle continues until the clothes are dry, then the timer advances and turns the dryer off.
If you selected a timed setting, the cycle continues until the time has expired, then the timer turns off the dryer
Jul 27, 2009 | Dryers
Lights once then not again
Hot Surface ('Glow Bar') Ignition System glow-amin.60x20.gif (most common)
This is the most popular system currently in use and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve. What happens in this style control system is that the thermostat or electronic control supplies power to the oven ignitor and gas valve which are connected in series (one after the other). As power flows through the ignitor it heats and allows a specific amount of current to flow to the oven valve which is in the same circuit. If the oven valve senses the proper current flow, it opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
I have a AMANA gas dryer model LGA80AW and it is not heating. I took the front panel off cleaned the lint from within the cabinet and exhaust pipe. What I've noticed is that the starter comes on and lights...
When you say "starter" I assume you are talking about the "ignitor" and it is glowing.If the ignitor stays glowing continuously then the radiant heat sensor, normally closed, is not opening OR if the ignitor lights up than turns off after about 10 seconds but no flame, then the coils (doesn't matter which one of the two) are bad. The coils are located on top of the gas valve and the radiant sensor is located on the side of the burner chute....Good Luck
The Squirrel
Mar 26, 2009 | Amana Dryers
Whirlpool gas dryer won't ignite -no heat
Try replacing the ignitor. The ignitor has to glow red and draw enough current to open the gas valve. When the gas valve opens then the ignitor lights the burner. Replace ignitor.
Nov 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
85 people viewed this question
Top Amana Dryers Experts
Marvin
Marvin
jdthefixer
Android Man
Android Man
Are you an Amana Dryer Expert? Answer questions, earn points and help others
