Question about Ricoh Aficio 250 Copier
Error sc391 Hi' I am having error 391 on my copier. Could someone help in how to solve this problem
  • 14 Answers
This error code indicates an electrical problem within the photoconductor unit. The development bias is not correct. TUrn the machine off, wait 10 secs and turn on again. If it was a sensor problem it will reset it. If this does not work remove the Photoconductor unit (PCU) and reinstall it. (bad connection)If that does not work there may be a problem with the high voltage supply board, in which case a service call will be needed.
Hope this helps
Dave T
Posted on Jun 09, 2008
What does error Sc:391 indicate?
Developer weak,replace the developer,if not solved replace TD Sensor
Nov 14, 2015 | Ricoh Aficio 2016 Black and White Copier
Xerox 7335 error code 010-391
Hi Anonymous,
Checkout the Fuser assembly.
Regards.
Jul 29, 2014 | Xerox Workcentre 7335 All-in-one Laser...
Error code 391 paper jam - no paper jam though. Open front cover and close and that resets machine but when you try to print error code 391 again!
Check the area where its showing the paper jam to see if there are bits of paper there. Most of these issues are caused by tiny pieces of paper blocking the sensors.
May 04, 2011 | Oki Electric Industry C6150N Laser Printer
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Unknown error 009-391
Remove Cyan Cartridge. Trun Off the Machine.
Now Insert Cartridge, make it properly inserted.
Trun On the Machine And The Error Is Gone......
Try It
May 20, 2009 | Xerox Office Equipment & Supplies
The 391 code problem
SC 391 is image storage address error. Development BIAS leak. Charge AC output error.
Should be checked out by a technician. It could be a few things going on with it.
Sep 01, 2008 | Ricoh Aficio 450 Copier
Can't fax in or out with my L7680
386
387
388
389
390
391
392
393
394
395 The machines were unable to complete the handshake.
*Try to send the fax at a time when telephone line conditions have improved
Aug 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
Error 391: paper jam
See below for Error 391:
CLEANING THE FEED ROLLER AND THE PAD
Clean the feed roller and the pad when [391: Paper Jam] appears frequently.
(1) Remove the paper cassette.
(2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner.
Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge.
Feed roller (large)
Feed roller (small)
(3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner.
Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way.
• If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose
tray in the same way.
Pad
Apr 04, 2008 | OKI C5200n Laser Printer
Ricoh Aficio 250 Copier Logo
897 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
