Question about 2wire 2700HG-B Router (2700HGB)
Windows live i try to sign into windows live on gears of war for windows and it doesnt recognize my internet ip adress, udmp or anything like that only my local ip address
    Genius:
  • 1,224 Answers
You have to sync router with comp as your internet service and you have to set your router ip settings to allow the game mode
Posted on Jun 08, 2008
Can't get windows xp home edition to recognize wireless printer, even after assigning printer TCP/IP address. Windows 7 computer prints to it, but the Windows XP computer can't even find the...
Hi!
You din't wrote what's the model of your printer, but I think we can find a solution:
1. Try to ping the IP adress you assigned to the printer. If that works, please download the latest drivers or installation software from the manufacturer of your printer (or second option use the installation disk that came with your printer). If it does not reply to ping, be sure the IP adress you assigned to the printer is in same range as the IP adresses on your network.
2. It is possible that the installation software itself manage to find the printer on the network, and that means the problem is solved
3. If not, install the printer as it is local attached (e.g USB or LPT port)
4. After installing as local printer, please go to printer proprieties, go to port, choose add a new port, choose standard tcp/ip port and write for the port the IP adress you assigned to the printer.
5. Apply changes and ...that's it.
Please let me know if it helped,
Aug 10, 2011 | Microsoft Windows XP Home Edition
Unable to configure router. I am using Netgear router, WGR614
first enter to your network connections in control panel, double click local area network, properties, internet protocol(TCP/IP), and tick Obtain an IP adress....Obtain DNS server..... and after that ok...ok..ok.
Now open an internet explorer window and type in the adress bar 192.168.1.1 and press enter . if you are asked for username or password try writing admin on both. good luck!
Oct 27, 2009 | NetGear WGR614 Wireless Router
Attempt to obtain IP adress failure
contact your internet provider and have them unlock your IP address
Aug 24, 2009 | Dmm Call of Duty: World at War
Ip adress failed
u should try ringing ur internet server and u dont connect it to ur laptop u connect it to ur modem and router and btw for some reason xbox live doesnt work for everyone it weird but no one knows why
May 09, 2009 | Microsoft Xbox 360 Elite Console
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Xbox live is not working
How are you connecting Your Xbox console upto your Internet ? if your Connecting Via WiFi, Make sure you have the Xbox compatible WiFi adaptor, if you are connecting Via a Local Area network, Ensure that your Console is hooked up Directly to Your Router, and if your connecting Via a Shared internet connection thru a PC, Ensure it is Hooked up correctly and also that your computer is set up to allow sharing the internet connection, That sometimes makes Xbox live faulty.
Also another problem for IP addresses not working is Due to your Internet service provider, Some broadband companies constantly renew IP addresses changing them every so often which the Xbox doesnt like. I would suggest contacting your Service provider and seeing if they have any Technical Support !
Oct 27, 2008 | Microsoft Xbox 360 Console
Gears of war for pc connecting to windows live
To open TCP ports use these steps below:::
To create an application profile for 4.x and higher:
  1. Open a Web browser and access the gateway user interface by entering http://gateway.2wire.net
  2. Click the Firewall tab -> Firewall Settings link -> Edit Firewall Settings page.
  3. Click Add a new user-defined application in the Application panel to open the Edit Application page.
  4. Enter an application profile name in the Application Name field. It is recommended that you use the name of the application (for example, GEars of War).
  5. Create your application definition in the Definition panel. A definition consists of a series of protocol-specific ports that are to be allowed through the firewall. You can find this information in the documentation provided by your the company that produces the application.
  6. Select the TCP or UDP button in the Protocol field. If the application you are adding requires both protocols, you must create a separate definition for each.
  7. Enter the port or port range the application uses in the Port (or Range) field. For example, some applications require only one port to be opened (such as TCP port 500); others require that all TCP ports from 600 to 1000 be opened.
  8. Optionally, enter a timeout value in the Protocol Timeout (seconds) field for the amount of time that can pass before the application “times out.” The default values are 86,400 seconds for the TCP protocol, 600 seconds for the UDP protocol.
  9. Enter a value in the Map to Host Port field that maps the port range you established in the above step to the local computer. For example, if you set the value to 4000 and the range being opened is 100 to 108, the forwarded data to the first value in the range will be sent to 4000. Subsequent ports will be mapped accordingly; 101 will be sent to 4001, 102 will be sent to 4002, and so forth.
  10. Select the application type from the Application Type drop-down list. If you do not know the application type, select None (Default).
  11. Click Add Definition to the profile definition list.
  12. Click Done.
  13. Repeat steps 1 through 12 for each port or range of ports required for the application profile.
If you need more help:: access this link
http://support.2wire.com/?page=view&article=21
Cheers
Jun 10, 2008 | 2wire 2700HG-B Router (2700HGB)
Signing in
Connect it to your router with an ethernet cable.
Make sure the router is setup correctly to your modem, if you can connect all your devices by ethernet cable to the internet then it's set.
If you are using a wireless connection and if it asks for the WEP or WPA key, make sure that you are entering the correct encryption key. You may want to call your router manufacturer to know the correct key for the wireless connection. FYI, it will say that the wireless network is connected but it will still fail the IP Address.
If you have a wired connection and the IP Address or DNS failed, I suggest you to call your Internet Service Provider to check for the Internet connection and obtain these (static IP address, subnet mask, default gateway, primary DNS server and secondary DNS server). If your Internet is okay, enter the IP settings manually on the console (System > Network Settings > Edit Settings > IP settings).
That should work.
Feb 22, 2008 | Microsoft Xbox 360 Console
I cant log in. PLEASE help me.
I guessing you live close to a neighbor that has an unsecured wireless network. It is possible that they changed their security settings to block out other IP addresses (meaning your PS3). The best solution would be to establish your own internet connection and/or wireless network thru a local broadband internet provider.
Jan 27, 2008 | Sony Playstation 3 (PS3) Console
2wire 2700HG-B Router (2700HGB) Logo
43 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
