Question about Pioneer DEH-1900MP CD Player
Tuner increments hi all, the tuner on my unit can't seem to pick up 'even' numbers. I know this osunds silly, but it only goes, for example, 95.1, 95.3 etc etc, even when automatically seeking. It can't pick up even numbers at all. Hope I've made sense regards Simon
  • 3 Answers
Same problem. Battery went dead and I received the error AO message when I tried to play a CD. The radio & keypad weren't right either. A Circuit City installer pulled my deck with the extraction keys and grounded out the deck by applying one of the wires to the small indentation on top of the deck. That reset the theft prevention on the CD player and I was happy until my battery went dead again. :(
Posted on Nov 24, 2009
    Genius:
  • 1,224 Answers
Those are odd numbers you decribed there
i understand what your saying to get the even numbers you have to use the remote and single click to what you want and if you want to stop a seek for frequencie hit the button back
you know foward select for scan and then back button for stop and then single press in what you need it takes a little fenness to control for even even numbers you just have to stop scan and seek single taps at a time
Posted on Jun 08, 2008
DEH-P7900 BT US model. Isthere any way I could change the tuner frequency to european one. Thanks.
The DEH-P7900BT is almost identical to the DEH-P85BT sold in Europe.
This is a US model and will tune most AM/FM stations in the UK/Europe. The FM broadcast band is 87.8 to 108.0 MHz. so it will not pick up any FM stations outside this range. Also, the tuning is in odd increments (such as 96.1, 96.3, 96.5, etc.) so some stations with even frequencies will be slightly distorted, depending on the power of the signal the station generates.
I found this bit of info for you but ill keep looking and let you know what i find out.
Also have you tried it in europe to see if it does work or not let me know ok
Mar 30, 2008 | Audio Players & Recorders
Td v26 speaker is not bringing all of the radio stations
Hi Rishabh.
Something wrong with internal USB power supply unit.
if you can.please remoove the cover and inspect a diode close to the usb power circuit.
if you are comfertable to repair please let us know.
regards,
nuwan
Jan 10, 2014 | Santai TD-V26 Portable Mini Digital...
Backing out of the driveway brake pedal was stiff and no brakes.
theres a vacuum line that goes to the brake booster, that sounds like tha prob either it came off or had a crack in it, so start there
Sep 23, 2012 | Haynes Toyota Repair Manual Online...
How many tons is this Carrier unit? Model #38AH-034---610AA Serial #OBO1F65263
This is a 30 Ton Hi Efficiency Gemini series unit from carrier you can matched to either of these air handlers.
40RM028 40RM034
Model is broken down in sections
38AH = carrier Gemini series units from 20 to 120 tons the numbers following the dash represent the size 024 = 20 028 = 25 034 =30 044 = 40 054 =50 the list goes on in increments of 10 untill it reaches 130 tons 134=130
Hope this helps
Best of Luck
Jun 01, 2011 | Carrier Heating & Cooling
I have a 25 y. Proton 300 radio, which until recently has been flawless. It now reverberates and seems to have "ghost" sounds, even when sharply tuned. What's wrong????can it be fixed???where could I...
It sounds like the tuner is out of alignment. A number of things can cause this kind of problem. However, a realignment is a very costly proposition, especially when considering the used value of the Proton 320. If you really like this radio, you might want to try buying a used example off of eBay. They come up very frequently. Only... be selective. Don't pick anything from a seller without a lot of good feedback. And don't overpay ($50 tops).
Jun 24, 2010 | Proton R5A Clock Radio
Brother pe150 won't pick up bobbin thread
Hi. This may sound silly, but the most likely reason the upper thread doesn't pick up the bobbin thread is that the needle is in backwards. (Sounds silly, but it's true!)
Needle shanks have a flat side and that flat side has to go in a particular way for your machine. With most modern machines, the flat side goes to the rear, facing away from you. Check your manual to be sure.
The second most likely reason is that your needle may be bent. Check that your needle is straight (or just use a new one).
Hope this helps!
Happy Sewing,
Robbie
Mar 14, 2010 | Brother PE-150V Computerized Sewing...
Tuner not working.
These do on occasion have a bad fm tuner assembly. part number 9630145608. to verify try a fm ant to see if works
Dec 09, 2009 | Denon AVR-1908
Ambiuous Information out there
I kind of think the people that wrote the manuals didn't bother hooking up a unit. Here is some help.
The converter box is nothing more then a tv tuner that picks up a digital signal and converts it into analog so your tv can view it.
The vcr, to record programs has to be set to channel 3 or 4 (whatever the converter box is broadcasting on) to record. The converter for the vcr will have to set to whatever channel you want to record from every time you use the vcr and left on as this is the only was the vcr can pick up a signal. Make sure the power saver on the converter box is set to off.
If your tv converter box has digital pass through, all you have to do is turn the tv converter box off and it your tv should pick up the singal from your vcr when you play tapes. You also use this method to access the menu on the vcr.
Jun 04, 2009 | Insignia Digital-to-Analog Converter for...
How do i reset my timex ironman
There are only 4 buttons. One of them will put you into "reset" mode, but which one? Before you guess, here is the trick: you have to hold it for a couple of seconds (you don't want it resetting accidently, right?) Ok, so start with your 1st guess (ok, pick top left) did the display give you any clue that was the lucky button? (ok, the display --the seconds, will not increment, but instead will just flash the same number) You are over the hurdle...if not try another one of those 4 buttons. Once you get the seconds to flash, you now have to somehoe reset whatevaitwas you needed to reset. Which means you need to pick another button...such fun! Pick the bottom right one and look for the hour display to flash (if the light comes on, this is the wrong button...you know that) and once it does you have found the "mode" for resetting the hour. So only a couple of buttons left: pick one to see if it increments the flashing hour hand (if the light comes on...you know what to do) and push it till you like the hour number. Then push the first button that started you on resetting this thingie to let the watch know you are done messin with it.
Now you are set to fix your daughter's watch...or your grand-daughter's watch...You B so smart now...you can fix anything!
Jul 03, 2008 | Timex Watches
Pioneer DEH-1900MP CD Player Logo
133 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
