Question about Dell Inspiron E1505 Notebook
My sound doesn't work for my dell inspiron 1505. what do i need to do?
    President:
  • 2,291 Answers
Open the Control panel
2. Open the "Sounds and Audio Devices" icon.
3. Verify the "Place volume icon in the taskbar" checkbox is checked. If this option is not available or is grayed out, skip to the next section of this document.
4. If you were able to check this box, click ok and close out of this window and the Control Panel.
5. Double-click the sound icon in the Systray and verify that all the sound volumes are mid-way or higher.
Check Windows services. Right Click My Computer and Manage. Choose Services and Application > Services. Choose "Windows Audio" and set to Automatic and Start.
Now next you can do is
If you open control panel & click device manager the window that opens will show a list of all installed hardware. Look for anything with an exclamation mark beside it, or to do with sound. If you see anything, right click it, check it isn't Disabled then select "Properties." The next window should have some tabs along the top, the one you are looking for is "Driver," you should now see an "Update driver" button.
Check ur sound card information by doing this
Click on start menu
Click on Run
Type dxdiag, enter
Click on the sound tab
There is button of test direct sound click on this check if there is sound
Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reginout to scan for errors.
Posted on Oct 29, 2010
6ya staff
SOURCE:
I want to install a wi-fi connection to my dell inspiron 6400 laptop
You can use any Dell WIFI cards made for this model or for the 1505 model computer. Do a search on eBay for the 1505 wifi cards.
Jun 08, 2011 | Dell Computers & Internet
Inspiron 6000 PC Notebook: I have a Del inspiron 1505 I had a virus who made ...
If you have some software provided by your ISP. Could be on a CD, then try to install it.
Else
Contact your ISP and they will provide you with gateway, and provide you settings which are required to access internet. Only your ISP can provide you these settings.
May 17, 2010 | Dell Inspiron 6000 Notebook
I can't find the microphone function for our laptop( dell Inspiron E 1505) We are trying to use Skype and can't get the sound to work. Does this lap top have a mic? CD
No, you will have to use an external mic, you can get a USB mic/Webcam for about $20
http://www.samsclub.com/shopping/navigate.do?dest=5&item=383049&pid=_Froogle&ci_src=14110944&ci_sku=975426
Mar 28, 2010 | Dell Inspiron 6400 Notebook
Dell Inspiron 1505 laptop: numlock doesn't work. Any help appreciated!
If the numlock key is not working at all, try to tear down your laptop by removing the keyboard itself out from your laptop. But if your hesitating to do that, just simply call DELL technical support for assistance and in a case that the numlock is not totally working at all, then they can able to replace the keyboard or the motherboard, depending on the troubleshooting that could be done. Make sure that your laptop still under warranty coz if not then it is required for you to buy a keyboard that fits for your Inspiron 1505. And if in a case that bad is the motherboard, then it should be replace. Thank you.
Oct 08, 2009 | Dell Inspiron E1505 Notebook
Muted sound from left speaker, no sound from right speaker
try uninstall/reinstalling audio driver. if it fails contact Dell tech support possibility that the internal speaker is already loose/broken.
May 25, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
The loose connection for the AC adapter means the motherboard needs to be replaced or the AC adapter jack on the motherboard needs to be replaced. (With Labor, it is about the same cost to buy a new motherboard as it is to have the old one fixed)
Motherboards are available on EBay for around $100
Apr 25, 2009 | Dell Inspiron E1705 Notebook
Inspiron 1505 speakers
The static noise may be a defect. If your laptop is still under warrent, contact dell for a warrenty replacement. I had the same problem with my inspirion. Sigmatel
Jan 24, 2009 | Dell Inspiron 6400 Notebook
How to get factory settings for my Dell Inspiron 1505
If you have Windows Vista you can press F8 while booting to access the Windows Startup Repair and then select the Factory Image Restor.
Dec 09, 2008 | Dell Inspiron 1501 Notebook
Sound driver for Dell Inspron E 1505 doesn't work
http://supportapj.dell.com/support/downloads/driverslist.aspx?os=WW1&osl=EN&catid=3&impid=-1&servicetag=&SystemID=INSPIRONI6400%2FE1505&hidos=WW1&hidlang=en&TabIndex=
visit this site chose your operating system
Dec 03, 2008 | Dell Inspiron 6400 Notebook
Dell inspiron 6400/E1505 audio drivers not working.
I can see how vista would screw up drivers through automatic updates. You could not be the 1st.
There are driver cleaners out there.
http://downloads.guru3d.com/download.php?det=745
Make sure you know what chipset you have, probably AC97 and use the driver cleaner to remove it.
Reboot and install the driver from dells web site.
G'luck
Oct 23, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron E1505 Notebook Logo
Ekse
Clive
Clive
Alun Cox
