Question about Car Audio & Video
I have a ripspeed cmr-2000 but usb or memory card wont work it keeps saying ERROR 06
SOURCE:
Inky
  • 705 Answers
SOURCE: HP photosmart D7300 series, will
Card format may be incompatible with reader or card may be too large for reader to manage. Try another card in the reader to see if it will read that one. If so you know the card is the problem not the reader.
Posted on Sep 19, 2008
  • 234 Answers
SOURCE: Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
Posted on Sep 28, 2008
SOURCE: not reading memory card; keeps
not reading memory card; keeps saying reinsert memory card, diplays error C 1
Posted on May 27, 2009
SOURCE: my sciphone wont read my memory card, it says msdc reader error??
My sciphone wont read my memory card, it says msdc read error
Posted on Feb 13, 2010
Obertelli
  • 3006 Answers
SOURCE: I have a 4GB PMY
Your problem is that you have purchased an incompatible memory card and it's confusing your camera as it is unable to read it correctly.
You have a 4GB SDHC card, but your camera can only use the earlier specification SD cards up to a maximum capacity of 2GB. SDHC cards will fit in the slot, but your camera cannot use them and cannot be updated to use them; the limitation is one of hardware so there is no way to update it via revised firmware.
You have just two ways to fix this: use a 2GB SD card up to 2GB maximum, or change your camera to a later model which is SDHC compliant. Note that SDHC compliant devices can use both SD and SDHC cards without any problem.
I hope that you have found my reply to be comprehensive, informative and useful and that you now have a solution to your problem. Please take a moment to rate my answer.
Posted on Oct 04, 2010
I have taken some new photos on my camera but when I have connected it up to the pc to transfer the photos it keeps saying no new picutures or video were found on this device
TRANSFERRING PHOTOS TO COMPUTER
If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 27, 2012 | Ricoh Caplio GX Digital Camera
What's your problem?My PNY 16Gb sdhc mememry card keeps saying card error in my camera
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Nov 26, 2011 | PNY Attach? 16GB USB 2.0 Flash Drive
My blackberry 8520 keeps on saying my memory card has fatal errors and when I go on the computer the folder 'blackberry' doesn't show. My phone wont let me format or repair the card. I've...
Look on this forum:
http://supportforums.blackberry.com/t5/BlackBerry-Curve/Problem-updating-device-software-quot-Fatal-error-quot/td-p/82515
Jun 18, 2011 | SanDisk 2GB microSD Memory Card
Brought a new memory card and it wont format keep saying error
Hi mr .
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • May 05, 2010 | Olympus Camedia C-350 Digital Camera
    MicroSD card has "fatal errors"
    hi i have a 4GB microSD memory card in my blackbery and it started not reading properly not it says the memory card cannot be accessed due to fatal errors i now cant access nither pictures oe music on it can someone please help me
    Jan 08, 2010 | SanDisk 8GB microSDHC Memory Card with...
    8G SDHC memory card is locked
    there should be a little swith on the side of the card. switch to the opposite and then try
    Dec 25, 2008 | SanDisk 4GB Secure Digital High Capacity...
    Not reading memory card; keeps saying reinsert memory card, diplays error C 13
    Aug 04, 2008 | Cameras
    Memory card wont work
    Open the disk and delete windows media player. It is free online and just get it from there.
    Cynthia Charczenko
    Jan 19, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    Car Audio & Video Logo
    119 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
