Question about Dell P4 2.8 GHz (DELLDIMREF1100) PC Desktop
I just brought this computer to my house from my girl friends grandmas house speakers and all worked fine now i plugged everything in the the exact speakers that were on it are plugged into it and the sound doesnt come out i have tried everything i cant figure it out
  • caleb swenson Oct 24, 2010
    they work on our laptop tho
    President:
  • 2,992 Answers
Assuming something in the computer didn't mysteriously go bad during the move, there are two possibilities. First, make sure the signal cable from the speakers is plugged in to the right place. You may have plugged it into the microphone input or line input jack by mistake. Second, be sure the speakers have power. Most speaker systems require AC power, either from a plug-in adapter or a built-in supply that needs an AC connection. (Some newer systems come with USB-powered speakers that don't need an external adapter.)
A remote possibility is that in the move, the speakers got bumped enough to disturb connections on the circuit board inside. The amplifier chip in the speaker case gets hot (especially if the volume is turned way up), and the heat can degrade solder connections, and sometimes cracks form. The move may have caused connections that were iffy to go bad. But this isn't very likely.
You'll probably find it to be a very simple missed connection. Good luck, and thanks for using Fixya!
Posted on Oct 24, 2010
SOURCE:
My chi straightener
That is impossible unless the breaker for the entire house is out. Did you pay your electric bill? Otherwise it should work.
Nov 28, 2017 | Health & Beauty
Media streamer internet connection problems
This happened to me last night. I took my streamer to a friends house, but when i came back it was recognizing my SSID but not accepting my password. I don't know exactly what happened but i tried unhiding my SSID and redoing my password, but it still wouldn't work. ultimately I renamed my SSID, Password, and PSK. Then on my streamer I found my router through WPS. I just added the router PIN and it connected and brought everything up. Re- entered my password and was good to go.
Feb 26, 2012 | RCA Televison & Video
My speakers were working fine and i unplugged everything to move them. When i plugged everything back in no sound. My computers speakers are working just fine but when i plug in the speakers no sound. I...
I suspect you have not plugged them back into the correct socket. The plug is coloured green and therefore should go back into the green socket. you have probably plugged it back into the blue or pink sockets. Use a torch to check that is in the green one.
May 04, 2011 | Harman Kardon SoundSticks II Computer...
Logitech Z-5300 subwoofer from computer to i-pod problem...
The best thing to do is to contact the manufacturers. From this i understood that your speaker system is new. You surely have the manufacturer's guarantee. So its better to contact them than to get it repaired or replaced for free. Sir please do not try to open the sub as it will void the guarantee policy.
Hope your subs come into play as soon as possible.......
All the best...
Jan 05, 2010 | Logitech Z-5300e Surround Sound System...
Computer keeps turning on and off, plus monitor won't display
Sounds like a loose wire inside the system touching something inside and shorting it out. My brother had this same problem. I brought it to my house to work on it and it was fine, no problems. Open the panel and look for any wires that are touching metal or something else and tie it up out of the way. I won't swear that is your issue, but sure sounds like it.
Jul 27, 2009 | Gateway FPD1975W 19" LCD Monitor
Control Pod for Companion 5 volume control non-functional
I had exact same problem today. I moved my speakers from one room to the next. When I plugged everything back, the mute/unmute worked but the volume control no longer worked.
I got it working now!! I powered down my computer and then unplugged the power to the speaker system. Then plugged in the power to the speaker system again. Powered on computer and all is good again!!
Hope this helps/
Mar 13, 2009 | Bose Companion 5 Multimedia Speaker System...
Computer Speakers
Try and plug your speakers into a friend's computer and check if they work. If they don't, then the speakers are fried, probably because of a voltage surge when the power went out. If they do work on your friend's computer then you most likely have a bad port on your computer because of the power surge.
Dec 14, 2007 | Cyber Acoustics CA-2016 Computer Speakers
No power to speakers
Lol, sounds like that iPod sucked the power out of your house. Just kidding. If it is plugged into a wall outlet, make sure that the conections are not bent or warped in any way (remeber this stuff is very fragile so look for the smallest stuff). If it is plugged into one of those multi outlet devils, make sure that is not too clogged up. For those I always use the Male Bathroom Ediquate rule, never stand (nor plug) next to a guy in another urinal.
Jun 06, 2007 | Altec Lansing iM3 Computer Speakers
Dell P4 2.8 GHz (DELLDIMREF1100) PC Desktop Logo
59 people viewed this question
Ekse
Clive
Clive
