I have a Kerosene Heater manufactured for Canadin Tire (Mastercaft) Touch and Glow Model No. CRF 9. I cannot find a wick. Are they still available ? Richmond Hill,Ontario,Canada
SOURCE:
SOURCE: kerosene heater will not wick up fuel from tank properly
Have you checked the length of wick. May not be long enough to get down into fuel. RON
Posted on Jan 27, 2008
  • 4 Answers
SOURCE: Corona DK 23 kerosene heater won't start
try bringing your wick up to the fully raised position and pinch and bend the wick toward the igniter until they line up right. I have two coronas one of which has a broken igniter due to wear and tear. If you open the little door,press down the start lever,and light the wick with a barbecue grill lighter,you can safely light the heater if lining up the wick fails.
Posted on Nov 02, 2008
SOURCE: Changing Wick in Kerosene Heater
http://www.bobvila.com/wwwboard/messages/284598.html
Posted on Nov 20, 2008
SOURCE: dyna glo kerosene heater
smoking problem
Posted on Nov 23, 2008
SOURCE: I need to change the wick on my dk 23 corona kerosene heater
what make and model is it? They are very simple to change,never heard of 1 "Not" lighting tho,unless you have water in tank and the wick sucked up the water...water don't burn,You can also raise the wick in their now if it has never been raised,as long as it don't have "riviet"looking things attached to sides of wick to fit it wick housing(Sears is good for that)If it a round or square heater it pretty much the same you have to remove the outer shell of heater, its always a good idea to dump out fuel first,at the base of wick their is usually 3 wing nuts or screw that hold wick Assembly in,after removing them you pull housing up to remove ,notice how the old one is on and remove and put new one on,when putting back in make sure wick fans out and goes to bottom tank,put back to gether and your done,most replacement wicks come with directions and height setting for the wick, Its not real hard as long as you pay attention
Posted on Nov 30, 2008
How do you replace the wick in a comfort glow model gr9a kerosene heater?
Post your question on this page , and you shall find the answer .
http://www.searspartsdirect.com/partsdirect/part-model/Comfort-glow-Parts/Heater-Parts/Repair-Maintenance/Questions-Answers/Model-GR9A/0218/0912160?mmlLandingSearch=GR9A&modelNumber=GR9A&diagramPageId=&documentId=
Sep 05, 2015 | Comfort Glow Heating & Cooling
How do replace the wick in a turco kerosene heater
This a very odd question about cell phones, isn't it? There are two videos on you tube to help you do this.
Kerosene Heater Wick Replace - YouTube
How To Replace a Kerosene Heater Wick Tutorial - YouTube
Jan 26, 2014 | Lands Phones
How do you replace just the top part of the wick on a comfort glow GR9B kerosene heater?
    • Remove the base plate from your Comfort Glow heater and expose the fuel tank. Lift the fuel tank out of the heater and set it to one side, well away from the heater. Note that the fuel tank is not connected to anything and will slide out easily.
    • 2 Run the heater until all the fuel in the lines is used, a process called "dry burnicon1.png," which usually only takes a few minutes. The fire will go out when the lines are empty. Turn the heater switch off and allow it to cool.
    • 3 Take the batteries out of the battery compartment on the back of the heater. This is an important safetyicon1.png step that keeps the heater from accidentally coming on while you are working on it.
    • 4 Lift the wick ring up and off, then remove the two nuts that secure the wick. The wick ring fits around the wick and the draft pipe -- the hollow tube that holds the wick -- and serves to hold the wick firmly in place.
    • 5 Slide the wick up as far as possible to reveal the positioning pin -- the small metal pin near the bottom of the wick. This pin is part of the wick and helpsicon1.png to ensure it is installed correctly. Push it out through the positioning hole in the draft pipe and lift the wick out of the heater.
    • 6 Fit the new wick onto the draft pipe and engage the positioning pin in the hole by pushing it in until it clicks into place. Move the wick down into the heater and replace the two nuts to secure it.
    • 7 Measure the distance between the wick and the draft pipe with the clearance gauge. The distance between the wick and the draft pipe should be the same all the way around, to ensure an even burn. Adjust the set screws as necessary to create even spacing. These are the small screws spaced evenly around the draft pipe that, when turned, move the pipe slightly so you can correct the spacing between the draft pipe and the wick.
    • 8 Replace the wick ring over the wick. Return the batteries to the battery compartment and the fuel tank to its compartment. The fuel tank will slide securely into its compartment in only one way. Replace the fuel compartment cover to complete the project.
Tips & Warnings
  • Keep the heater set on medium to medium-high for best results. Setting it too low or too high may cause soot to accumulate on the wick.
  • When operating a kerosene heater indoors, always have a working carbon monoxide alarm and a smoke alarm. These heaters are generally safe when in use, but an alarm will provide a safety backup in case the heater malfunctions
Oct 14, 2013 | Northern Tool 10,600 BTU Radiant Kerosene...
I need to know how to replace the wick and what size wick is required, I guessed a 95mm. The dial that controls the wick wont stay turned holding the wick up so i cant light the heater. would this be due...
It possibly could, if the wick is not installed properly. Also, the height mechanism (the control knob and the gears) may have lost it's tension and will need to replaced.
However, without knowing what brand/manufacturer and model number kerosene heater you have, there's not much more I can tell you.
May 12, 2011 | Heating & Cooling
Need to see pictorial instruction on how to replace wick in a Dyna Glo RMC-95-C2 kerosene heater
I think the Dyna-glow RMC95 series of heaters are equivalent to DH2300 series heaters.
In any event, the wick you purchased should have ahd the installation instructions included with the wick.
If it didn't or you tossed it, Here's a link to the DH-2300 series heater's Owners Manual, which may help you.
http://www.yourheater.com/DH2301-3%20owners%20manual.pdf
Good luck. Be sure to wear rubber gloves when you try to install the wick. Particularly, if you still have kerosene in the tank.
Feb 11, 2011 | Dyna-Glo RMC-8001SS Heater
Hi, I need a users manual for a Robeson Kerosene space heater model # 03-2619-91. I tried to light it with an open flame and nothing is happening. Thanks
DO not try to light with flame. Check fuel an vac lines first.then ck glow plug. to ck plug, remove leave power connected.to plug. ground plug to unit. Turn on switch.plug should glow bright red.
Jan 01, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
WILL NOT START BURNING. REPLACED BATTERIES, GOOD SPARK. CLEANED. NO FIRE
When is the last time you cleaned your wick? A dirty wick will not light, wicks should be soft to the touch look burnt but not hard. Are you burning K1 kerosene? Other grades of kerosene have larger amounts of parafin in them this creates a crusty black hard carbon on the wick making it hard to light and also makes it smell like a semi truck running. I use an old tooth brush and clean the wick, let it set and soak for at least a half hour then try to light. Just a tip if you let your heater burn out every third tank this cleans your wick. Only burn it out in a well ventilated area as this stinks something bad never do this inside. Don't forget let the wick soak for at least a half hour. If your wick is over three years old replace it. Good luck hope this helps!
Dec 10, 2010 | Northern Tool 10,600 BTU Radiant Kerosene...
Kerosene heater will not wick up fuel from tank properly
Jan 26, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
