Question about ASUS Eee PC 1000H Laptop
Screen blank with blinking line left corner...when hit f2 bio utility comes up
    Guru:
  • 689 Answers
Navigate with "tab" and arrow keys,theres just a few pages here save and exit or restore to factory defaults etc press "enter " to select or change option.get to know these pages and the boot sequence--good luck!
Davey Snake!
Posted on Oct 24, 2010
SOURCE:
What is the f2,f8, r f12 want work? only the Ctrl+ Alt+ del that wroks
F2 usually takes you to the BIOS setup screen, you need to hit the keys as soon as you power up.
F12 selects on a Dell instant boot menu to select booting from CD-ROM, USB, etc rather than the BIOS options.
F8 goes to safe mode start up for windows, this must be done before the windows logo comes up (ie when it is a black screen).
Control - Alt -Delete Keys together can be used any time, after windows boots as it tells it to re-boot the computer, back to start up.
Jan 30, 2015 | Computers & Internet
My aspire 5733 goes to a blank screen when i turn it on
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 04, 2012 | Acer aspire 5733z4851 intel pentium...
My coby netbook wont go to my login screen it stops after the coby screen and shows a blank screen with a blinking cursor in the top left corner, how do i fix this?
As you mentioned, the cursor keeps blinking, this means that the system is not able to locate the hard disk so that it can start your operating system. Ensure that there is no disk in the CD/ DVD rom and open the bios by pressing F2, DEL, F10, or whatever key that is assigned to the bios. You can find this at the time the system starts. Enter the bios and restore the bios to default settings. After restoring the bios, save the settings and restart the system. This may resolve the issue.
Apr 16, 2012 | Coby PC Netbook 1ea
Hi i have a gateway mt6705, trying to restore to new. push the on button and gateway comes across the screen. then goes to a blank screen with a blinking line in top left corner thats it. cant use cd to...
The way to restore Gateways is to hold down the ALT Key andrepeatedly hitting f10 then it should bring you to a boot sequence screen thenchoose the HDD and then hold down ALT and repeatedly hit f10 again that shouldprompt the restore feature for gateway. If that doesn't work,the only way to doit is to boot into windows and run the Recovery program.
ALL DATA WILL BE ERASEDON YOUR HARD DRIVE IF YOU PROCEED. YOU WILL NEED TO ENSURE THAT YOU HAVE THEPOWER ADAPTER PLUGGED IN. DO NOT SWITCH OFF OR RESTART YOUR COMPUTER DURINGTHIS PROCESS.
Hope this helps,
Feb 26, 2011 | Gateway MT6705 Notebook
I have a gateway nv5470u,it picked up virurs and went blank,,it would not come on,then one day i hit the turn on button,it come on a blank screen with a white line uptop to the lleft...
That means that the hard drive is not detected properly on the computer.
Start the computer and keep tapping F2.
You will get a setup utility.
Press F9 and hit ENTER.
Press F10 and hit ENTER.
Now restart the computer.
If u still have the blinking cursor on that black screen, u need to check your hard drive.
If u are gettng some other error in windows or just a black screen, try doing recovery.
Recovery will wipe off all your datas in the computer.
For doing it, keep tapping Alt+F10 as soon as u turn on the computer.
If u are succesful, it will give a message that windows is loading files.
Just follow the prompts.
Keep me posted on the status of the issue.
If that helps, dont forget to rate me.
Nov 09, 2010 | Computers & Internet
I know bios password but i want to remove it without removing the battery
log in bios and set bios password again hitting enter
this will reset your current password
Jul 09, 2009 | Acer Computers & Internet
Toshiba Satellite A215-S7437 will not boot up...
Take out the hard drive completely and then see if you hear the clicking noise, if you do then that means the hard drive is bad. Also if it goes right to another message and you don't see the blinking cursor then that also verifies that the hard drive was bad and causing the system to hang.
Jun 12, 2009 | Toshiba Satellite A215-S4747 Notebook
Black screen with blinking curser in left top corner
Hold the power button down and let it fully power off then boot it back up. If you get a prompt saying Windows did not shut down normally, select Last Known Good Configuration.
May 19, 2009 | Acer Aspire 5315 Notebook
Will not go past startup screen
I think u need to updrage ur bios and RE-INSTALL UR WINDOWS
Oct 26, 2007 | Dell Inspiron B130 Notebook
ASUS Eee PC 1000H Laptop Logo
210 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
