Question about Bose 3·2·1 II System
Bose 3.2.1 Volume is too low
When I play my 3.2.1 I have to turn the volume up to 35 to listen normally. My other 3.2.1 unit is very loud at that level.
    Genius:
  • 1,224 Answers
Ok on your receiver you have different settings this is not easiest to say and think and type at the same time so here goes
your reciever has different settings example sterio, mono expanded sound game sound etc.
i believe that if in wrong setting or the mpx is not on then you will get a low output of sound
also quite possible the songs were recorded at a lower output sound volume
i hope this made some sence
Posted on Jun 08, 2008
  • Christophe Thompson
    Christophe Thompson Jun 08, 2008
    also make sure in settings the volume is up in the menu sound
It'll work listening to the radio just fine for about 5 minutes, then the sound goes away.
If you are running at high volume for even a short period of time, the overload signal to the microprocessor(computer within your unit) will cause the unit to shut down. If you are running it that loud, try turning the level to 1/3 of your normal listening mode. If it runs, try to keep the volume with reason.
Aug 04, 2015 | Audio Players & Recorders
I am trying to connect my Bose Wave Radio to my Yamaha RX S 70 receiver so that I can listen to the radio through my speakers. Right now the speakers are connected to the Yamaha...but radio isn't playing...
There's actually 2 ways of doing this.
Using the variable out connections on the Bose, connect your L&R channels to the desired input, I recommend the auxillary, on your Yamaha and select that input. Turn the volume all the way down on your Yamaha. Turn the volume on your Bose all the way up; then readjust the volume as desired on your Yamaha.
Optional connection; the headphone jack. Connect a 3.5mm mini to stereo plug cable from the Bose to Yamaha in the manner described as above and use the volume control approximately the same way.
Dec 12, 2014 | Yamaha Audio Players & Recorders
Bose speaker volume is not as loud as it should be
I would check out the output volume of the device that the soundlink is playing first.
Jul 13, 2014 | Bose Soundlink Wireless Mobile Bluetooth...
Denon problems
I'm not familiar with your unit. However, go to systems surround set up and turn up volume for those surround speakers you speak of.
Mar 22, 2014 | Audio Players & Recorders
The sound/volume is not working properly on our Bose 321 system...i.e., whereas, a "normal" volume at (let's say) 35-40 is way loud, but now have to turn volume up to 100 (maximum) to be able to...
Make sure the device it is connected to has its audio properties setup correctly. If this is a cable or satellite box, most of them have a volume output level. Changing this will change overall volume.
Mar 01, 2011 | Bose 3 2 1 GSX System
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
Hi, on my Infinity fx45 2004 Bose system, I'm experiencing a fading cd player volume and sound quality that is triggered or cancelled by car movement. it actually has three different behaviours, 1-very...
With my experience on Car audio systems, the main culprit for electrical trouble is Connectors.
Check the connectors; especially the RCA connectors (Round Coaxail connectors), unplug them and plug them back in while the CD player is playing. Any problem there will be obvious. If that's it, clean them off with a dry cloth, perhaps poke a Q-tip into the receptical to clean that.
Most often, just removing and re-attaching (or even just wiggiling) the connectors is good enough.
This is especially the most likely culprit if you live close the the ocean's salty air, or in a place that had roads salted for snow and ice.
Jun 18, 2009 | Car Audio & Video
Bose Lifestyle 35 Accoustimass module rattles at high volume
Well to be hones 85 sounds pretty loud to me, generally the bose acoustimass module shouldnt really be distorting or crackling unless under extremely high sound levels.
It could possibley be that the speaker cone in the bass module has a slight perforation so it would distort at high levels. However other problems could be loose connections inside the unt or outside the unit. If your friend doesnt have it above 85 under normal circumstances I wouldnt worry to much about it but if there is a tear in the cone the problem could get worse.
Nov 27, 2008 | Bose Acoustimass 15 System
Bose 3·2·1 II System Logo
268 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
