Question about Panasonic PT-47WX53 47" Rear Projection HDTV
Panasonic PT-53TW53 is dead,led is blinking 6 times
    New Friend:
  • 10 Answers
Hi, Service Manual says that 6 blinks = IC4518.
Replace this and you should be good to go.
Posted on Oct 29, 2010
SOURCE:
The power light on my panasonic PT-53TW53 blinks 5 times in intervals. The TV set does not turn "on". Could you advise what this means ? Thank you for your help.
5 BLINKS means a short on the 140 volt line inside the set.
Usually this means the horizontal output transistor is shorted.
I can if you are able how to test for this and what to look for that may have caused this.
I am in California and online right now.
SD TECH
Feb 11, 2011 | Panasonic PT-53TW53 53" Rear Projection...
My panasonic pt-53tw53 wont turn on. The power light blinks 3 times then pause then three times....etc. If I unplug the set and plug it back in, it will work again but just for a short time, then shuts...
The 3 blink error is the convergence circuits need repair. The Panasonic repair kit PT53WX53 convergence repair kit is the correct kit for your model. Its available from www.tvrepairworld.com and the kit contains the parts and the CD with instructions.
Sep 22, 2010 | Panasonic PT-53TW53 53" Rear Projection...
The red led flashed 3 times and stops and then repeats the steps. I replaced both convergence IC's. I still have the same problem.
Did you replace the 2.2 ohm 2watt resistors. If the led blinks 3 times its almost always going to have at least 1 of the 2.2 ohm resistors blown.
Mar 30, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Tv not coming on and red led blinking on front panel when I try to power on
the blinking led is a error code. Let me know the number of blinks and I will assist you.
Nov 24, 2009 | Panasonic PT-53TW53 53" Rear Projection...
I have a Panasonic PT-53TW53G that stopped working. Red LED light blinks 3 times. Any advice?
the 3 blink error means the convergence has failed and has shut the set down. You can get the convergence repair kit for your model at the following link www.tvrepairworld.com The kit contains the parts and the Cd with detailed instructions
Sep 12, 2009 | Panasonic PT-53TW53 53" Rear Projection...
No sound, No video, power LED blinking 3 times
had the same problem with mine and I replaced horizontal deflection transistor located by the high voltage tranformer, its the big transistor by the heatsink, check for any shot and replace if you find problem. worked for me
Apr 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
407 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
